Reload this Page >
Sig Hog Bipe Build
Sig Hog Bipe Build
Old 06-08-2007, 11:13 AM
  #526
jacobezzell
Default RE: Sig Hog Bipe Build
are you talking about the DS8311, the digital heli servos that run ~$100 a pop? [X(]
Old 06-08-2007, 01:30 PM
  #527
ag4ever
Sorry, meant DS821.
They are $30 each.
JR Sport ST47 or ST47BB would be all you need for this plane.
I would get the BB though as the extra $3 each is well worth it for the ball bearing.
Old 06-08-2007, 01:54 PM
  #528
EscapeFlyer
EscapeFlyer's Avatar
Granted, the set up in the instructions make this biplane the docile bipe trainer that makes it soo famous. However..... She can be set up to kick anyones A**!!!!! Put the right power on it, adjust the cg, increase throws, utilize your computer radio, and it is only a FRACTION of a step below the performance of an Ultimate bipe. My next one will have a YS 1.10 on it.
The tail of this plane tracks so straight, I can't stop grinning every time it's airborne. It is the quintessential "Flying on Rails" airplane everyone dreams of. I was flying it in 12+ mph winds and it cut through the wind like butter.
So- Don't be skimpy on your equipment, you'll thank yourself for putting only the best and strongest and fastest in it. I also recommend utilizing a 6 volt battery. It is worth it.
-Bipes
Old 06-14-2007, 06:22 PM
  #529
gumhead
gumhead's Avatar
Ok im finally done! Now I need to find some time to make it up the field and fly her!
Heres some pics...
ID:	704145   Click image for larger version
ID:	704146   Click image for larger version
Old 06-14-2007, 06:24 PM
  #530
gumhead
gumhead's Avatar
a couple more
ID:	704157   Click image for larger version
Old 06-14-2007, 06:32 PM
  #531
Joe Ortiz
My Feedback: (75)
Joe Ortiz's Avatar
Gumhead, nice Hog, is that a fuel filter in the last picture?, if so, where did you get it from?
Joe
Old 06-14-2007, 06:47 PM
  #532
EscapeFlyer
What, no pants? You're half-naked man!!!!!
Old 06-14-2007, 06:54 PM
  #533
gumhead
gumhead's Avatar
ORIGINAL: Joe Ortiz
Joe
Yup....
http://www.horizonhobby.com/Products...rodID=SAI50109
ORIGINAL: Ilikebipes
We'll be running in the grass. I always go pantless for the maiden run...
Old 06-15-2007, 12:04 AM
  #534
EscapeFlyer
a haaa. I would too, but I'd scare all the maidens off............
Old 06-19-2007, 11:33 PM
  #535
chashint
Well my Hog Bipe is getting closer to completion.
I decided to keep the color scheme pretty simple on this one.
I still need to add the pin stripe on the leading edge of the wings.
The landing gear and the cabanes still need to be painted too.
Maybe someday it will actually be finished :-)
ID:	707483   Click image for larger version
ID:	707484   Click image for larger version
ID:	707485   Click image for larger version
ID:	707486   Click image for larger version
ID:	707487   Click image for larger version
ID:	707488   Click image for larger version
Old 06-20-2007, 04:06 AM
  #536
Dauntae
That looks so cool, You should put it on floats and call it a coast guard bipe. Simple yet looks great.
Dauntae
Old 06-20-2007, 07:39 AM
  #537
chashint
ORIGINAL: Dauntae
Dauntae
Thanks Dauntae,
I did not realize why this scheme looked somewhat familar to me, but you are right is does sorta look like a Coast Guard color scheme.
As far as the floats go, it sounds like a good idea on paper, but introducing another moving element into my landings would not be the the best interest of the airplane :-)
Old 06-23-2007, 12:31 AM
  #538
preparation_h
That thing is Sick!!!!
So I've been out of the game a while, but how do you go about covering....are the graphics stickers, paint, coating?
When I usually cover a plane it makes all the hard work I've done end up looking like crap! Any advice?
Very cool pics guys!
Old 06-23-2007, 04:14 AM
  #539
maayan
Hey
I use monokote to cover.
for the trims i used monokote trim. wich is a sticker type.
after i put the trim in place i use an iron to seel the trim in place for good.
if its a trim that has good contact area (leading edge..), without risk of air tearing it off, or fuel breaking it loose- I use regular monokote.
in any way, starting form the back to the front keeping all seems facing backwards.
here is my bipe.
ID:	709176   Click image for larger version
ID:	709177   Click image for larger version
Old 06-23-2007, 10:32 AM
  #540
chashint
ORIGINAL: preparation_h
Mine is the one that is cream with the simple orange trim. It certainly does not qualify as one of the 'sick' ones but the way it is covered is with Sig Koverall fabric and all of the color is brush painted with dope from Aircraft Spruce.
I just finished the touch up work this morning where the masking was not quite right and I will spray paint a final coat of clear dope on the whole thing in a few days. Since each coat of the dope melts into the previous one trying to brush paint across the different colors would cause bleed over so I plan to use a aerosol can of Sig high gloss clear for that.
There are some amazing covering / paint jobs in this thread that I really admire.
A lot of the folks really make their planes into works of art.
Old 06-26-2007, 05:43 PM
  #541
BipeLuver
Finally got it finished guys. Flew the first flight 3 weeks ago. Been busy on a canard stick. Thought you might want to see it.
ID:	711767   Click image for larger version
ID:	711768   Click image for larger version
Old 06-26-2007, 07:05 PM
  #542
Joe Ortiz
My Feedback: (75)
Joe Ortiz's Avatar
Nice[sm=thumbup.gif], what kind of cowl, engine and prop size you got there?
Old 06-30-2007, 03:54 PM
  #543
chashint
Finally bolted mine together for the first time with the paint applied.
There are a couple of finishing touches to be added like painting the wheels and putting a frame around the windshield but you can see how it is going to look.
I still have to install the control horns but everything else is ready to go.
ID:	714156   Click image for larger version
ID:	714157   Click image for larger version
ID:	714158   Click image for larger version
ID:	714159   Click image for larger version
ID:	714160   Click image for larger version
ID:	714161   Click image for larger version
ID:	714162   Click image for larger version
Old 07-07-2007, 01:21 PM
  #544
rkliemann
I am getting ready to covermy hog bipe, I am using ultracote. Looking at your pics of the engine area, it looks like you just painted that area? Can you just paint over the wood? My astro hog I thinned epoxy and when it dried used dope to paint for fuel proof. You plane looks perfect for covering, mine has small areas that have wrinkles that I could not seem to get completely bout with the heat gun. I really want the hog bipe to come out nice. I have spent alot of time sanding smooth. Always looking for advice on how to cover as I have only 2 planes under my belt.
rkliemann
Old 07-07-2007, 01:34 PM
  #545
gumhead
gumhead's Avatar
ORIGINAL: rkliemann
yup... Just make sure the paint you use is fuel proof.
Old 07-07-2007, 02:21 PM
  #546
gumhead
gumhead's Avatar
Just an update....
I have brought the hog bipe up to the flield 2 or 3 times. With 10 or so flights, I can say she flies like a champ! The saito 100 has oodles of power for this plane.
Im the one who takes the pictures, so I dont have any in flight pics. May be next week I'll have someone else fly it so I can take some pictures of her up in the air...
Old 07-08-2007, 10:49 AM
  #547
chashint
OK I have a question / problem.
I used Koverall, then nitrate dope, then butyrate as the top coat.
My problem is the cured dope dissolves with alcohol.
It is not fuel proof.
Have I missed something ??
Does it require a clear topcoat, and if so how will this really help ?
Old 07-08-2007, 03:51 PM
  #548
gumhead
gumhead's Avatar
ORIGINAL: chashint
I don't know.... I use nitrate dope, then butyrate and i have no problems.
Do you clean your plane off good after flying?
What percentage of nitro are you using?
Old 07-08-2007, 04:23 PM
  #549
chashint
Hi gumhead,
I am using 15% nitro right now and 10% does the same thing, I can't tell much difference between the two.
I think it is the alcohol that is doing it. I found out ISO alcohol will dissolve the butyrate when I used it to wipe off an oily smudge.
My experience with the Slow Poke I bulit last year was about the same, the dope is not greatly affected by the exhaust residue, but raw fuel will immediately "stain" it and if not wiped up quickly will begin to dissolve it.
I wipe the planes down after a flight with a Windex moistened paper towel on all the places that collect fuel residue, and give them a complete cleaning at the end of the day using Windex on paper towels.
Old 07-09-2007, 10:29 AM
  #550
[email protected]
for my .02, why not use solartex fabric ? with a little practice, u can cover a golf ball with this stuff, and it is much easier than mixing up a bunch of paint, and probably weighs less too. see below, solartex wings and century 21 fues's. both have been regular flyers since 1999.
mike
ID:	718932   Click image for larger version
