Air Hogs Aero Ace!
#2778
makg,
Sure. Make a flat wing and do a lift comparison to the undercambered one. Or you could shim the rear of the wing and do an AOA study and its effects.
novielo,
Glad to hear you got one made up and working. Thats 1/2 the battle.
1/8" is small. A lt depends on the strength of the magnet. Neo's or Rare Earth ones are the best. The stronger the magnet the more efficient it is.
I've never loaded a vid here. Sorry
Tony
ARS Software & Innovative Solutions
http://www.falcon1.net/~ars/rcmodels.html
novielo,
Tony
#2779
QC, CANADA
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/4ygdqTvajyo"></param><embed src="http://www.youtube.com/v/4ygdqTvajyo" type="application/x-shockwave-flash" width="600" height="350"></embed></object>
hope this work if not it's at this adress: http://www.youtube.com/watch?v=4ygdqTvajyo
#2780
Hey All!
I found out where they got the design for the AA Jet from!
Check this [link=http://www.alexisparkinn.com/photogallery/Videos/2006-Jet-powered-bat-suit.wmv]vid [/link] out!
Ayrton
Ayrton
#2781
CA
Hi all, I finally got my mono with jet motors flyable.
This was the last option before I yanked the carbon fiber rod out and stuck a traditional tube back in. The wing span is about 12.75" and in weighs in at 25.3g. I suppose this should have been the first wing configuration tried, but I've flown every other config I used successfully with bipe motors. I might play with the rear stabs some. But before finetuning can happen you have to get the thing to fly. Anyway here are a couple of pic's. BTW, I put some shrink tube on the tail boom for a shot of color. Tim
#2782
NY
Aytron, thats an awsome vid!
Presenting the pico-38!
I maidened it today and it flies awsome! Its a real floater, It climbs on the lowest throttle. Its only drawback is its really sensetive to wind. Other than that, It a blast to fly!
#2783
NY
^^^as you can see, the tail booms are made from plastic straws. The whole wing is two sets of bottom wings from my AA's. The center fuse is made from two layers of 1mm depron(foam plate) and the tail is one layer. I was going to mount the motors inside the straw because the fit perfectly, they didnt even need glue but i coulnt remove the motors without cutting the wires so i just mounted the on the trailing edge. I cant get any vid of it because i dont have a video camera[&o]
#2785
NY
I plan on painting it but i dont know what color? I was thinking of olive drab with the military theme but if i lost it, it would be impossible to find
#2786
NY
ORIGINAL: novielo
"The video you have requested is not available.
If you have recently uploaded this video, you may need to wait a few minutes for the video to process."
Tom
#2787
QC, CANADA
the video was added just before i wrote the message. it isn't still available !!!??? you tube seems to be overloaded. it's very long just to get to my page...
#2788
TX
W.A.S.P.S-Flyer ,
the pico-38 looks pretty cool, i've always had a soft spot for those planes. nice job. if the wings are "disposable," you could trim them to more of the shape of the P-38 wings. it would increase your wing loading which would make it a bit faster, and able to take a little more wind.
i'm not sure about EPP, but i know some spray paints will eat foam. it should be fine though, i sprayed my F-27 and it didnt do anything. you could try on a test peice to make sure though.
nick
nick
#2789
Artyon,
That vid is a riot! I want a couple of those engines.
Novielo,
Still file not found error.
Ferndale,
Looks good. It does have a little dihedral since it uses a Bipe wing center. Glad its flying. Should make you a real nice enjoyable flyer.
W.A.S.P.S-Flyer,
Thats unique. Bet it has a ton of lift with the undercambered bipe wings. You should draw it up and submit it to the AA ToolBox www.aatoolbox.no-ip.org so others can build one.
It would look good in military colors............
Tony
Novielo,
Ferndale,
W.A.S.P.S-Flyer,
Tony
#2790
ORIGINAL: MegaByte-2
Neurotex
That jet looks better everytime I see it. I take it since it running the N20's, its on the modded Rx?
I agree on the props. A good GWS prop could up the trust by as much 20%.
Mass produced props aren't the best. They are usually poorly balanced among other things.
Tony
Neurotex
Tony
and take the extra load no problem. No more worries and well worth it!
Found a block of building foam they use in construction and carved a canopy for
it. Sands easy and it's really light.
I'm going back to making some more props. They're not really that hard once you
get the hang of it. Just takes a little time.
#2792
CA
Megabyte, I'm working on tail stabs. The plane will swoop into stalls really easy. I'm into my second round of cutdowns, but I'm going to get some depron plates. I'll run out of balsa quickly.
for all that are building off the AA bipe frame, CF rod is heavy and could screw up your plans.
Djstinger, can you post what you did to the tail of your mono/jet mod?
Tim
Tim
#2793
Neurotex,
Didn't you start a thread on making props? My models just keep getting smaller and the stock AA prop is getting heavy on mine. Besides, Less mass = more rpm!
If you get time and are the one that started it. Mind posting the link and posting some updated tips?
Ferndale,
Have you tried shimming the rear of the wing up abt 1/16" ? I had some similar problem like that and it fixed it by reducing the AoA.
Tony
Ferndale,
Tony
#2794
Does anybody have any pics of the two new AAs? I can't find any other than the box art photo, I want to see what the actual planes look like...Thanks
#2795
MN
Megabyte, I am now a micro solderer, Mosfet/resistor mod successfully completed on 2 rx's =).Mono/jet no.1 is back in the friendly skies. Now I just need some n20's for my jet. Thank You again...
Tim, glad to hear your OK..Did your life pass in front of you for a split second? I didn't change my tail, I just added a skid made from a beer can and the provided silver tabs. I did angle the tail or pulled it out at the top of the plastic holder about 1/16th",to give it more lift. My tail is very beat up,I made anew one out of a plate but all it did was nose dive. The tail I made weighed in at .7 grams my old tail was at 1.5 grams. It flies great with old tail. I am working on a tail made from .007" shim stock I will keep you posted. I will try to post some pics of my tail later. That didn't sound right...
Makg, I have an '06 bipe channel C ( RED/BLACK) , will post pic
#2796
Djstinger
Thats great! Glad to hear it. 2 for 2! When you first see the size of the parts, it can be a little intimidating.
Sure cheaper than 2 new AA's!
Tony
Tony
#2797
QC, CANADA
djstinger, the parts are small but when you set up correctly it can be done nicely. great job!!
megabyte, the magnet used was a piece of the "donut magnet" that was part of the ear bud. here's pic while i'm still waiting for the video on you tube, it says : "Status: Uploaded (processing, please wait) ". the chimp is pretty slow today!!
#2798
Neurotex,
Tony
Neurotex,
Tony
I was going to post how I made a prop from basswood but got side tracked
into the canard project and foam jets. There seems to be no interest in it
so I never got back to it.
[link=http://www.rcuniverse.com/forum/m_4504373/tm.htm]props[/link]
Here's a pic of the foam canopy I made for the Rx.
I found simular foam at Home Depot that comes in 4'x8' sheets used as building
insulation. It's almost an 1" thick and once cut and hallowed out is strong and
feather light. They also had a smaller 6 pak of the same material cut in smaller
sheets for about $8- but you could probably find some scraps at a construction
site.
Sands almost as easy as balsa and the canopy took about 10 minutes to make.
Would work great for a fuselage.
#2799
QC, CANADA
finaly, got it work... the video not the actuator... well it's working but not enaugh. i will try to use the half of the magnet to make it work... it was a first try...
http://www.youtube.com/watch?v=RCgE-Kdb3Tk
#2800
CA
Makg, here are pic's of the yellow/green, I refer to it as the green lantern. I would show you the red/black, but currently it is stuck in a tree 1/4 mile away at an altitude of 150+ feet. The really anoying part is that I can see it from my porch and my main launch point.
I got another picco z today. C ch, and it is better out of the box that the A ch. Do I keep trimming out the mono/jet, or trim out the picco z? These are good conflicts to have
