sexton
Old 09-25-2008 | 04:48 PM
bubbajoexx's Avatar
Default sexton
well I have some work done on the sexton but need to find an early sherman daul motor drive and I mean early the old clutch type with daul motors
and am still looking for the outer axle plates as I have not found any on ebay as of yet
here is what is done so far
ID:	1040867   Click image for larger version
ID:	1040868   Click image for larger version
Old 09-25-2008 | 07:41 PM
mailedfist's Avatar
Default RE: sexton
Hey, I may have a set in a couple weeks, do you have any tall (new kind) tamiya gearboxes to trade?
Thats a nice project btw keep it up [8D]
Old 09-25-2008 | 08:48 PM
goldenraven's Avatar
Default RE: sexton
Nice project you got. and good work with it.
Goldenraven
Old 09-25-2008 | 09:55 PM
bubbajoexx's Avatar
Default RE: sexton
the gear box I need is the single gear box with twin clutches and 2 380 motors not the tall 2 singles
Old 09-26-2008 | 01:14 AM
mackem's Avatar
Default RE: sexton
Now that's what I call a conversion, EXCELLENT!
Hope you'r gonna keep the posts and pics coming.
Old 09-26-2008 | 07:23 AM
ArmChairGeneral's Avatar
Default RE: sexton
Good work, keep posting progress, don't see many of these
Old 09-26-2008 | 09:40 AM
astroboycp's Avatar
Default RE: sexton
Do post more picts
Old 09-27-2008 | 12:32 PM
Default RE: sexton
BubbaJoeXX:
You WANT the ones shown, or the NEW ones? I ask because the new ones actually take up less space, and the originals are only 280's - and anything larger won't fit unless you find specific short-can 300+ motors (I tried that too)
Unless you can snag a pack from one of the stored 'collectors' copies, you'll probably be SOL, and if you do get 'offers', they may want as much as DMD's anyway.
Not to mention the gears are the poor Tamiya 'pot-metal' ones, and rarely stood up to use over the 3+ decades that its been out. The 'used' gearboxes often had the optional gears missing - you got either a clutched 1:100 ratio with a central gear-shaft, or a separate-drive setup with two outer gears on a 1:200 ratio (making the clutch pointless) I can post pics of the RT-1601 manual showing this if you like.
As one who HAD the RT-1601 kit (it was NEVER listed as the 56001) I can say its a poor choice over the new gearboxes and the 56014 suspension w/ bearings. Even the HL metal boxes would be better (not to mention CHEAPER) and a HL electronics system could supply more functionality too: traverse (limited but a Sexton did have SOME traverse) and elevation as well as engine noise.
Just my two hundredth-loons.
Old 09-27-2008 | 04:09 PM
bubbajoexx's Avatar
Default RE: sexton
ORIGINAL: WhiteWolf McBride
BubbaJoeXX:
I have many henlong gear boxes but they are way to tall and I have tamtoy gear boxes and they are to wide and I have 2 complete sets of tamiya 560014 sherman gear boxes
and all of them are of no use in this unit as I want to run gear reduction motors longetudenaly with 90 degree of sets to make even more space for the electronics for the gun IE
elevater 17 degree right left and the recoil unit as well as sound and smoke as all my tamiyas are equiped with hl smoke units
Old 09-27-2008 | 06:24 PM
Default RE: sexton
BubbaJoeXX:
How about the new HL Stug gearboxes? Anyone got a set to measure for Bubba?
I'm pretty sure the old Sherman gearbox unit sat as high as the new DMD's. Anyone got one handy to check it?
Only thing I can think of is hacking a Leopard/Gepard gearbox to make it thinner, and doing the 380 reduction-drive mod as was mentioned in the following thread: [link=http://www.rcuniverse.com/forum/m_7990106/tm.htm]Are Tamiya old clutch drive gearboxes worth upgrading?[/link]
I have at least one spare I can look at for hackability (if I can dig out the box) ... and a Sherman chassis I can measure. Want me to look, take some pics, and measure it up for the possible hack?
Old 09-27-2008 | 06:35 PM
bubbajoexx's Avatar
Default RE: sexton
BubbaJoeXX:
any help is welcome as I need the setup as small as posible to get all the electronics in
here are 2 of the gear boxes I have out right now they are brand new
the small ones are tamtoy the other is tamiya as most of use know by the size
ID:	1041949   Click image for larger version
Old 09-27-2008 | 06:51 PM
bubbajoexx's Avatar
Default RE: sexton
here are the out drives and reducers that i can also use to build the early 3 piece gear housing used on shermans
ID:	1041963   Click image for larger version
Old 09-27-2008 | 07:07 PM
bubbajoexx's Avatar
Default RE: sexton
if any one needs the gear reduction units for 380 motors here is the link I buy them from 10 dollars not 130 from the tank outlets
http://cgi.ebay.com/Gearbox-for-moto...2em118Q2el1247
Old 09-27-2008 | 08:28 PM
Default RE: sexton
Bubba:
That 540 powered one is tall, yes. Too wide 'cause it was designed for the King Tiger, 5604/56004 I believe.
Going from memory, if the 540 gearbox is too tall (yes I know its too wide) you're going to be SOL on the RT1601 boxes too, they are even taller.
Let me dig out the Leopard boxes tomorrow and the sherman, and I can take some measurements.
Old 09-29-2008 | 09:06 PM
bubbajoexx's Avatar
Default RE: sexton
Bubba:
I just bought these today 2 sets
Old 09-30-2008 | 03:16 AM
Default RE: sexton
BubbaJoeXX:
Look to be standard Tamiya DMD gearboxes, the ones on the right with the tab in the opening seem to be Type Two gearboxes (first black-cover'd ones) I blew the pics up, could see that annoying plastic gear (someone have the repair/replacement gear packet #?) They should fit fine inside a Sherman (and motors sit even lower with the 3:1 reductions)
You can apparently adjust the ratio on the new boxes ( on the left) manually by removing the cases and adjusting the spacers on the gear-shafts, or so I think I remember reading on ArmorHut a while back. You may still want some 2:1 reducers on 'em...
I gotta salvage more soda bottles to make covers for my Type 1's w/ their now-rare HPC gear-sets. Even have a Wroe reduction assy laying about I think.
Old 10-03-2008 | 02:56 PM
bubbajoexx's Avatar
Default RE: sexton
just finished designing the new gearbox for the sexton it uses tamtoy gearbox with pershing gear housing so that I can make the 3 piece trans cove for the right look
just added a finished pic of the gearbox for the 3piece trans the pic shows thw 3 piece trans I am makin
ID:	1045398   Click image for larger version
ID:	1045399   Click image for larger version
ID:	1045400   Click image for larger version
ID:	1045401   Click image for larger version
Old 10-03-2008 | 04:43 PM
Panther F's Avatar
Default RE: sexton
Well, I'll say something first ... they look very nice! How do they sound? Pretty cool thought, hope it works out for you.
Old 10-03-2008 | 05:22 PM
bubbajoexx's Avatar
Default RE: sexton
ORIGINAL: Panther F
nice and quiet they are all bearing even the out drives are ball bearing and all metal gears
Old 10-03-2008 | 05:48 PM
Banned
Default RE: sexton
Looks fantastic bubba those tamtoy boxes are pretty good by themselves but you have made them 10x better with the bearings
got those in my T34 and they sure are sweet boxes
Keep up the good work will follow this with great interest
Kind regards Rob
Old 10-03-2008 | 08:17 PM
Default RE: sexton
bubba:
Where did you source your TamToy gearboxes? I might wanna give a set a try... Think we can talk Mato into carrying 'em?
Old 10-03-2008 | 09:15 PM
bubbajoexx's Avatar
Default RE: sexton
ebay.co.uk is where i found them 45 pounds not cheep
mato toys wont stock these
and your cable went out this morninng
Old 10-03-2008 | 09:18 PM
bubbajoexx's Avatar
Default RE: sexton
started the 3 piece trans cover here it is so far
ID:	1045574   Click image for larger version
Old 10-03-2008 | 10:46 PM
Default RE: sexton
Bubba:
I searched under 'tamtoy', and not even google found anything. I even searched eBay UK for gearboxes in General, and only found the regular HL metal boxes and a set of Tamiya Pershing ones, nothing like yours. Those look customised... thicker metal walls...
Old 10-04-2008 | 08:34 AM
bubbajoexx's Avatar
Default RE: sexton
sent you the link for the gear boxes
look harder when lookin for parts they are not that hard to find
ID:	1045726   Click image for larger version
ID:	1045727   Click image for larger version
ID:	1045728   Click image for larger version
