Official Hobby Zone "Super Cub" Thread
#8902
RE: Official Hobby Zone
Nice paint job there. I think the packing tape is the answer, at least on possible impact areas. Basic acrylic water-based paint like I used comes off fairly easily. although the areas I did not tape are still as good as the day I painted it! The nose cone and wings take the worst beating.
Did the stickers or tape seem to remove the paint if you tried to reposition them? Tape would completely remove mine, so Ionly got once change at it. Turned out well though.
#8903
You can get the prop shaft only, without the gearbox, and it has the nut, bearings, and washers with it. List price is $2.49 I think.
#8905
OK, so here is my CUB finally painted and "decals" applied! I found a nut at Fleet Farm that now holds my prop on. Works just fine!
Pic three is my custom window so I can read my onboard volt/ampmeter, lots easier than taking the wing off everytime!
btw...this is my first time uploading pics, so let me know if they don't show up...thanks!
[img]C:\Documents and Settings\Matt\Desktop\Super Cub LP small 1[/img]
[img]C:\Documents and Settings\Matt\Desktop\Super Cub LP small 2[/img]
[img]C:\Documents and Settings\Matt\Desktop\Super Cub LP small 3[/img]
#8907
OH
ORIGINAL: MCSEVZ
Ok, i think that didn't work....will this???
#8908
Super paint job! I really like the window idea too.
I had mine out tonight for a fly. Despite a bit of a breeze it was great! I didn't scrape off the cowling this time either . I did make one over-shoot of the landing area into a pole which slightly dented one wing , but nothing major. One perfect landing on the gear with no bounce, and I taxied it right up to me...that one was rewarding!!
I'm starting to find that, as mentioned previously by someone, the wing is slowly pushing back toward the rear of the fuselage. Think I'll try the popsicle-stick fix.</p>
#8909
ORIGINAL: Sinai
Belemnoid I'm going to try this too. I Will fly new prop in about an hour (at sunset)... I just put in on today.
I still don't have my new batteries in but we should fly when they come in.
#8910
ORIGINAL: Belemnoid
Yeah, it flies nice with that prop but I think it's got a little less zip than the GWS 10x6. I've got half a dozen of those, but they're orange and for some reason that irritates me. Speaking of, does anyone know which drill bit to use to ream those out to fit the SC shaft?
ORIGINAL: Sinai
If you don't have a reamer, just use a small round file and gently enlarge the hole, from the backside, until it just slips over the shaft.
grubby
#8911
Anyone have suggestions for the best clearcoat? My yellow paint is leaving paint dust on everything it touches! Kinda looks like pollen all over my car's interior...not cool!
#8912
Ihad wondered about this myself. I originally wanted to just clearcoat the stock plane, but no one had any ideas about a clearcoat.
I have found that the acrylic paint I used is holding up well. I will come off if the plane takes a hit, but otherwise it's OK. No paint dust anywhere. Iused a brush-on as opposed to spray paint, meaning that the paint is much thicker, and touch-ups are easy. It worked especially well on the tail section.
It does not stick well to the plastic parts, however.I did not sand or prime the cowl, and just today decided to repaint it. The oldpaint practically fell off when I tried to remove it, like taking wrapping paper off a Christmas present.
#8914
Thanks for the tips....BUT I totalled my plane last night!
Wing snapped off while going into a loop and the Cub rocketed into the ground from about 100 feet. Cowl/nose of the plane is smashed and separated from the rest of the fuselage. The midzone of the fuse is crunched up and cracked. None of the electronics work...(that surprised me). The only good things left are the right wing (which floated away in midflight), the tail section, and my expensive battery (WHEW)! I tried to piece the rest of the plane back together, but it's not looking so hot!
Darn Murphy was right....the amount of time you spend modifying is indirectly proportional to the amount of successful flight time! haha
Oh well...it was about time to upgrade anyways!
#8915
OMG!!! That's a bummer, dude. Glad you have a good sense of humour about it! I've seen some foam flyers at the LHS that had been destroyed but lovingly rebuilt, so there may be hope. Like you said though, maybe better to go ahead and upgrade anyway rather than spend all the time, money, and energy rebuilding a starter plane.
I found a can of white enamel spray paint in the basement, and decided to try it as a primer on the plastic cowl. I took all the old paint off, sanded it lightly, then sprayed it with 2 coats. Worked GREAT. I reapplied the acrylic finished paint in 3 coats, and was impressed enough that I did the wing struts too.
Most likely I'll crash it next flight and be cursing Murphy as well!
#8916
Yea, it's a bummer. Not my starter plane though. More of a anytime-anywhere airplane. I have flown a few trainers and foamie jets. I wanted to try something different. While it lasted it was great! Yea, I tried to redeem the plane, but after I put a whole tube of thick CA, other glue and wood skewers into it, it still wasn't going to be anywhere near airworthy!
Very nice paint job though! Mine didn't come nearly as shiny as that! Good luck keeping it airborne and airworthy!
Best of luck to the rest of you other crazy Cub'ers. It's been good getting and giving advice to all of ya.
Peace.
Peace.
#8917
BTW...I have my Cub batteries for sale...I have 4 minus the one involved in the crash...so 3 are listed here on RCU if you want to check them out. I'm selling them cheap, so don't wait if you want a look.
#8919
OH
I just got my new lipo's today,,cheap off Ebay,,they realy rip,,Lipo is the best upgrade for the SC IMOP....My backyard flyer always
#8921
OH
ORIGINAL: eghershey
What size lipos are you using? 1300's 3 cells?
#8922
CA
Here's a moment of silence for a fellow cubber, and anyone else who totalled their planes. We've all been there. I care. And Sorry to hear about that.
...it was an awesome looking SuperCub in glorious yellow.
And i hope you get up and find wings again , whatever you fly...
gws, great deal ! Man, i'm diggin on that 2 for 30 bucks. I got 2 from "Go Market" on Ebay too. That seller hooks it up!
#8923
OH
Yea Sinai, there Mystery batts,,I'm gonna go easy on them,,see how long I can make em last.... Probably not long, I got a heavy left thumb,,,
#8924
Iwas reviewing my local rc club's membership, flight rules, and training program tonight...gave me a renewed appreciation for having a park flyer!!! I was considering getting a 0.40gas trainer but now I'mthinking twice!!
I made some mods to the wing settings on the fuselage of mySC...the foam was getting a bitworn such that the wing was able to move front to back a bit and not necessarily stay straight. I cut a foam strip to match the plastic reinforcement on the front of the wing and glued it above the windshield area, then cut another piece to match the backof the wing and glued it on, and painted the grafting to match.The wingfits on perfectly now,a snug fitthat stays in place. I used the packing material as a donor.
Also, of interest, here a pic of what enamel spray paint does to foam!! Tested it out on the packing material...don't try this at home!
#8925
OH
Nice work on the SC, looks good...Don't get turned off by one club,,,check around,,,unless none other close by ?? Once you go glow,you won't turn back,,,,wait,I still love flying the SC in the yard,at work,at the field....Oh well,,,best of all,,,,it's all about flying whatever, wherever
