official smartech buggy thread
#2626
CA
Hey tiger1431,
I have an extra 2-speed tranny and bell if you're interested in upgrading. $40 shipped to you. Let me know, and I'll send you my paypal address for payment.
#2628
IL
Anyone know of a main spur gear that is the same size as the smartech one only metal? part number 11284 I got another stick jammed in mine and stripped all the teeth.
#2630
IL
Thats kinda what i said i heard the clacking sound and it rolled to a stop with the engine still running. So ive gone through three of them now.
#2631
NY
If you read back about 40 pages or so there was this guy called naturefreak who was talking about replacing gears in the buggy with metal gears from HPI. Don't remember which gears, but it might help you out.
Found this while searching:
http://www.rcuniverse.com/forum/fb.asp?m=4822566
#2633
I wonder what happened to him (naturefreak) he was one of the regulars on here, did lots of good testing with odd ball stuff, was waiting for all his input, he stopped to go hunting and he has never been back on since... Wonder if he converted to another car...
ORIGINAL: docphysics
#2634
dont know. but i read that metal gears would eat up your clutch bell real fast. and he was also taking about whe he got them he had to shave down the points because the gear was actually too big.
#2636
yeah that too. but u guess somthing about the metal on metal makes it wear fast. but it sounds like you would be better off with a metal gear. it dosent wear out fast i dont think, but i think back there somewhere i read theat the metal gear eats up your clutch teeth rather then the original gears(dont know that thy are made of)which dont wear it out as fast, if it wears it out at all.
#2637
im sorry if you cant understand my typing. belive me i dont talk like this. the metal gears dont wear on the clutch teeth as fast as the other kind would. but if you are eating up your gears on sticks and other stuff then it would be an advantage to have metal gears.
#2638
IL
I was thinking about just switching over to just running it onroad ive upgraded to some onroad tires and i dont get much traction for turning offroad anymore.
These are the tires ive got.
http://www2.towerhobbies.com/cgi-bin...?&I=LXM973&P=7
And these are the wheels
http://www2.towerhobbies.com/cgi-bin...?&I=LXKSD3&P=7
#2639
you can buy a hardened clutch bell, and I would think the wear would be good, I run a hardened traxxas bell, with alumnium shoes, but I havent had to replace the main gear yet, I know you can also get a nylon gear that is much more durable then the plastic, it may be worth looking into. I would take your gear into a hobby shop, there is a good chance they can match one up for you. Also I am not sure, but I think you should be able to get a alumninum gear. That with a hardened bell, there would be no wear at all, even not hardened you would have very little wear.
#2640
IL
I think i might check that out tomarrow its 8:30 here and the hobby shop closes in half an hour which is about the amount of time it takes to get there.
#2641
those tires and wheels will look good on the buggy, I was just looking at mine and the only place I can see twigs coming in would be through the hole under the gear box, maybe put a piece of duct tape over the hole would cure this problem. just a thought
#2642
IL
Yeah thats where they keep coming from they get in there when i turn. I was planning on trying to seal it up but forgot about it before i ran it today. And those wheels do look awesome on the buggy i'll have to barrow my brothers camera and take a picture of them.
#2643
IL
Well only one pic that turned out halfway reasonably i will try to take some more in the morning when there's daylight because the flash on the camera doesint work all the time and the inside lighting doesint work very well. But here's what i have.
#2645
IL
Awhile back i upgraded to the duratrax maximum st shocks well i just got the purple springs for them. I put em on and it doesint bottom out anymore i dropped it about four feet and nothin it just bounced a little.
#2646
It may be a bad pic or somthing, but I dont see front dogbones. are you keeping it 2wd, just waiting for parts, or am I just not seeing them in the pic?
#2648
OH
PLEASE HELP I have speedy tiger just bought new motor and when i turn the car on the wheels turn one way and lock. So I replaced the little box and it did the same thing but when reverse the wires plug them in different place on the box and hit hit the gas on the controller the wheels turn. The throttle works fine it is just the steering.
SOMEBODY PLEASE HELP
#2649
NY
So when you connect the servos to the receiver normally, and turn the steering wheel, the wheels turn and then stay locked in that position, and won't return back? Sounds like something is binding up in the servo saver. I would disconnect the steering servo frome the steering linkage, and check to see if it is something mechanical in the steering system or it is electrical problem with the servo.
#2650
OH
When the car is off i can turn the wheels with my hand and seems to be to bindind and when i connect the steering servo wires in the slot where the throttle servo wires go in the little box and hit the throttle tigger on the controller the wheels turn
