Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Drifting
 Question about ESC/Motor Temperature >
RC Drifting Discuss all aspects of rc drifting here!
Old 11-30-2009 | 02:36 PM
Default Question about ESC/Motor Temperature
I recently upgraded my TT01E, three of the changes are,
1. Motor: Orion 19T Modified + Head Sink
2. Pinion: 21T.
3. Metal Motor Mount.
4. Drift Tires, of course.
I am still using the stock ESC (trying to save a few bulks). Now the car drifts so much better , without a doubt. But here are some observations I find disturbing.
1. At 1/2 throttle all the way, ESC gets really hot in just a few minutes, approximately 80 celsius degree.
2. Motor stays approximately at 60 ~ 70 celsius degree.
Are they <span style="color: rgb(255, 0, 0);">overheating</span>? I am planing to add a heat sink to the ESC, and a computer case fan on the transponder mount to blow away heat from both the ESC and the motor.
Thanks.
Old 12-01-2009 | 12:10 AM
Freequensee's Avatar
Default RE: Question about ESC/Motor Temperature
If by stock ESC you mean the Tamiya TEU 101BK ESC, then you are using a motor beyond it's limit. That ESC can only handle down to a 23 turn.
It's best to get a ESC that can handle a 19T motor. Even if you do a fan or heat sink mod, it will only be a matter of time before the ESC dies.
Old 12-01-2009 | 10:06 AM
Thank you, Freequensee.
I have installed a small heatsink +fan, taken down from an old video card, on top of the ESC (yes, TEU-101BK it is). Also, I have installed a desktop case fan on the transponder mount blowing right at both the ESC and the motor. Essentially, the ESC has gotten a heatsink and dual fans.
I believe you are right that it will only be a matter of time before the ESC dies, but this is the idea. Iwould like to max out what Ihave now before Ihave to replace it.
Idid a test run last night with the settings above-mentioned deployed, and the results are quite satisfying. The whole time the throttle was from 1/2 ~ 3/4 all the way for 20 minutes non-stop, at the end of the test, the temperature of the ESC measured at about 45 celsius degree, which is on par with the motor. This seems a big improvement, for now.
Old 12-01-2009 | 03:26 PM
All the cooling stuff you did is a great idea but you have already maxed out the ESC with the 19 turn motor. motors are cheap go back to the stock or a 23 turn motor and save the ESC.
You can drift just fine with the stock motor and ESC.
Old 12-01-2009 | 04:16 PM
ORIGINAL: phantomworks
Ihave heard people using 17T on 101BK for months. Ithink I still have some safety cushion left here.
Old 12-01-2009 | 11:54 PM
BTW:did another test run tonight, after 20 minutes (1/2 throttle), ESC stays cool (almost no heat coming out), and motor stays at about 45 celsius degree.
Old 12-02-2009 | 06:35 PM
Very cool, hopefully you will get some life out of it.
