The Official Traxxas Slash short-course race truck
#2576
NY
RE: The Official Traxxas Slash short-course race truck
Ok, i stand corrected. Just did some research on the Protrac suspension. theres more to it then i thought. longer arms, beefier turnbuckles. negative offset wheels to make up for the longer arms.
so here's my next question...which do you think would get me the most bang for the buck? Lower CG or Proline Pro trac suspension kit? I'll probably wind up doing both eventually, but which one should i do first?
#2577
Hey, I am starting to convert my stampede into a slash, and was trying to debate between aluminum bellcranks and the stock plastic bellcranks. I will be going the the Slash 4x4 version bellcranks either way. I was just wondering if the plastic ones are actually pretty strong, or if there has been some durability problems. The aluminum ones are going to be about 3x more money. Thanks
#2578
NY
i race my 2wd slash with the plastic bellcrank. through the jumps, bumps, crashes, cartwheels, you name it, knock on wood hasn't given me a problem yet. we had a guy snap his servo today, but the bellcrank is fine.
about the only thing you can gain from going with the upgraded version is precision.
#2580
VA
in a drag race all things equal motor,gearing, battery and tires which would be the fastest and win the racetruck the slash 2wd or the slash 4wd
#2581
NY
ORIGINAL: stampedevxl
Are you racing with the 2WD bellcracranks, or the 4WD bellcranks?
the stock 2WD unit. is the 4wd that huge of an improvement?
#2582
NY
4wd- more traction. in order to have the same motor, you're talking VXL. the 2wd with the VXL has to be feathered off the line to get traction.
ORIGINAL: momogt
in a drag race all things equal motor,gearing, battery and tires which would be the fastestand win the race truck the slash 2wd or the slash 4wd
#2583
AZ
4wd is also heavier which slows down, i would say it would be pretty close
ORIGINAL: godofcable
ORIGINAL: momogt
#2584
VA
im thinking about getting a slash 4x4 im also trying not to spend alot i have a extra tacon 2950kv motor would this motor with a mamba max pro and a 4s lipo be a good setup i gonna set the truck up mainly for onroad
#2585
MD
Just picked up some new 17mm wheel adapters, my old ones finally gave up. I ended up going with the Pro-line wheel adapters very good quality. Had a snow run so needed to give the Slash some cleaning to.
#2587
MD
They are left over springs from my Evader ST. They fit perfect and come in ex soft, soft, medium, and hard.
#2589
How does the 4x4 slash handle tall grass, my kid wants one and I was wondering how much the tall stuff slows it down, might go stampede for more ground clearance.
#2590
ORIGINAL: gflight37
#2591
MD
ORIGINAL: rc awesome
My slash's rear shocks are sticking what can I do to fix that?
#2592
ORIGINAL: airmayle
Rebuild them if you haven't. I would check the shock shaft to see if they are bent at all.
#2593
Hey guys, take a look at this video I made, took my Slash to some sand dunes and got some slow-motion footage. Enjoy!
http://www.youtube.com/watch?v=QTGV5J065Z0
#2595
ORIGINAL: Andyjk
#2596
OR
What's up everyone? I picked up a Slash 4x4 not long ago, and it's great. Absolute blast.
I was wondering though, since (like everyone else...) I like to tinker, what should be the first upgrades that people normally do to these? Thanks, and everyone have a great rest of their day!
#2597
NY
ORIGINAL: B192734
#2598
Hey where did every one go???? lots of good info here, lets keep it going.
Well any way Ive got the Mike Jenkins Slash 2x4, this brang my r/c collection to 12
I cant get enuff of this car, compared to my others it handles like......[X(] But thats what makes it fun, ive smoked 2 stock motors & a yoke fell apart. apart from that its been great. ive since fitted a proline chassis saver & a yeah racing 35a esc & a 3900kv motor on the higher gear setting. heaps good fun but uncontrollable over 1/2 throttle on 7.4v & no kidding on the right surface it pulls wheelies on 11.1v (the ESC fan is soldered into the ESC's BEC) my latest mod was... ive cut the rear shock towers to allow room for the arms to be mounted in the top holes, set the rear camber to -3deg & have put 60g of weights under the ESC. My god talk about a diffrence, power slides are now controllable, & heaps faster take off now. im not joking definatly a noticable differance.
Well just the other day i had a head on crash with a hyper 7 that was going flat out, BANG LOL [:@]
well it shattered the castor block, shered of part of the "A" arm, bent the hell out of the "a" arm pin, snaped the side nerf bar & cracked the rear "A" arm
Well in short ive gone nuts with my tax refund, lots of goodies on there way
#2599
FL
hey guys sorry this is my first post on this thread. I am having a pinion/spur gear problem with my Slash. I know this is not enough information but the spur gear and pinion keep eating themselves up! They look like worn out Chinese stars after a day of running. I have tried every distance in a mesh. Very loose, very tight and all the spots in the middle. I use a 14 tooth pinion and the stock spur gear. i Have tried Steel Spur gears and it wears just as fast. I have tried to put washers on the motor mount to make sure the mount is as even as possible. I am going to try and post up some pictures here very soon. Any ideas?
This has probably happen over 20 times =( I am starting to wondering if something in my setup is defective or something.
#2600
hummmm, 9 times out of 10 its from incorrent adjustment
How do u set the gear adjustment??? and whats ur setup???? how tight is the slipper clutch????
Check this out
[youtube]http://www.youtube.com/watch?v=Dmm5hQBfAyQ[/youtube]
I set mine by sound & fell. never had any problems, but untill u get a feel for it use the method above
Just intill u get the hang of adjusting the gear mesh it might be worth leaving the gear cover off for the first run so u can keep on checking the mesh.
once u have got this problem worker out, spen $10 and get the rpm gear cover the stock cover lets dirt in., dont wast ur time on metal/alloy spur gears
Oh i cant stress get the motor mounts tight & use locktight
Check this out
