RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
The Official Traxxas Slash short-course race truck
Old 08-21-2011, 06:16 AM
  #2651
fastandloud
Default RE: The Official Traxxas Slash short-course race truck
At this point its pretty much a free for all. No limits on mods. Im gonna try the weights and see what i can come up with on the diff mod. Thanks for the input ph.
Old 08-21-2011, 08:43 AM
  #2652
FahrtAutoRC
FahrtAutoRC's Avatar
I came into this late but for the Slash 4X4 I can send my current setup sheets I use for outdoor clay, it works incredible all around, tracks perfectly down the straight, and cuts nice and clean thru corners, also very easy to jump. Most itll ever need is tweeked slightly for different conditions. And for anybody interested, PM me for my FaceBook, as I have thoroghly documented build albums for everything done to my 4X4 and one for my old ladys Blitz
ORIGINAL: phmaximus
ORIGINAL: fastandloud
well I finally got a 2wd slash and have been racing at a buddys barnyard track. Need some advice from you guys. Im running a castle 3800 with a 2cell lipo and currently 23/90 gearing. Not too happy with the speed or tourqe im getting now. What gearing should i be using? Im running against quite a few 4wds which is challenging to say the least. Any tips or advice would be appreciated.
The biggest difference i made was by following a artical dedicated to racing & from my experance it works a treat for bashing, i dont race
All it really involves is move the rear upper arms to the upper position on the shock tower *u need to cut a tiny bit of the tower for full suspension travel
set the rear camber to -3deg
fit around 70g worth of automotive wheel weights under the ESC, Im running the proline chassis saver with 60g weights.
And lastly do u know how to mod the diff to run oil? its easy all u need is oil, 2 o-rings & 2 shims.
these 4 changes make the rear heaps more controllable & highly improved straight line acceleration.
even with out the diff oil there is a very noticeable difference, give it a try, cant hurt & is easly put back.
Also from what ive been reading the stock brushed motor classes are generally pulling more laps than the brushless guys.
what class are u racing & what are the modification limits????
Old 08-23-2011, 02:47 AM
  #2653
phmaximus
phmaximus's Avatar
pitty the 2 wheel drive & 4 wheel drive setups are so different
Dont know how well a high traction setup will go on a low traction track (based on the pic) it looks very loose with no hard packed racing line
I am very intrested in the setup u are running anyway, post it up m8
Old 08-25-2011, 01:17 AM
  #2654
phmaximus
phmaximus's Avatar
Hows i got the RPM 2 stage shock pistons, I put the green in the rear and the purple in the front with some 40wt oil. It took longer than expectes because u have to file one of the c clips down. grrrr
Hows, i did notice that all the shock shafts were slightly bent??? what the hell??? all of them!!!
not really happy, ive looked after this car and havent done anything stupid with it, no kidding thay should not be bent from normal driving. wonder if its worth complaining to traxxas about?
havent tested the shock pistons out fully yet, ill let ya know how thay go
Old 08-25-2011, 07:04 AM
  #2655
FahrtAutoRC
ORIGINAL: phmaximus
I threw the gold colored titanium-nitrate coated shafts on mine, havent had one bend since
Old 08-25-2011, 02:26 PM
  #2656
phmaximus
phmaximus's Avatar
I ordered them last night, just a bit anoyed that thay bent
Old 08-25-2011, 08:16 PM
  #2657
FahrtAutoRC
Just a good starting platform, can be tweaked here and there for different tracks but it works in general, usually the most I do is change the top shock mounting position to lay them down more or stand them up. Parts list goes as follows, for some light reading (at this point its longer than my usual grocery list haha)
Castle MMP SCT ESC
NeuCastle 1410 3800kv 4-pole motor
Savox SC-0251mg 222 oz/in steering servo
Turnigy 40c 2s Lipo
ProLine F150 body
E-Maxx rear springs (TRX progressive)
Venom aluminum shock caps
Losi 50wt shock oil
RPM A-Arms all around
RPM rear bumper
RPM shock towers
King Headz motor mount
Hot Racing sway bars
Robinson Racing pinion and spur
center diff
several combos of wheels/tires, but pictured is below
Hot Bodies Beams tires (pink)
Proline V2 1/8 buggy foam
JConcepts Rulux wheels
Probably a couple other mods Ive forgotten
Truck is raced regularly, never bashed, not bad for starting life as an RTR hehehe
ID:	1653590   Click image for larger version
ID:	1653591   Click image for larger version
Old 08-27-2011, 02:40 AM
  #2658
phmaximus
phmaximus's Avatar
nice, love the body
<- Big Ford Fan
Old 08-27-2011, 03:14 AM
  #2659
phmaximus
phmaximus's Avatar
Here ya go guys, I got some new pics today. As u can see its not made for racing but more for looks.
Still not finished,,,, more to go.
If ya hate it let me know, i know it needs lots of work but its a start. Next i wanna mount 2 spare tyres at the back but its like $35 for 2
Old 08-27-2011, 06:16 AM
  #2660
thehuntingterminator
what about these? www.ebay.com/itm/Traxxas-5875A-Front-2-2-Tires-Wheels-1-10-2wd-Slash-/290481828730
Old 08-27-2011, 06:21 AM
  #2661
phmaximus
phmaximus's Avatar
cheerz bud, but ill problary get rear ones tho,
Old 08-27-2011, 06:45 AM
  #2662
godofcable
ORIGINAL: phmaximus
the only difference between front and rear is the offset, but if you have to have rears, here ya go
http://www.ebay.com/itm/TRAXXAS-5873...item3f06bbfa8b
Old 08-27-2011, 02:20 PM
  #2663
CUHRYTDUH
My Feedback: (12)
Hey guys have a problem need some help. I was running my slash 4x4 yesterday and doin some big jumps, until the last jump. It had rolled a few times after it landed and was on its top. I turned it over and no response from steering or throttle. The light was red, so i turned it off and back on, it was then green. I've tried resetting transmitter to esc to no avail. I hold the button until green, then red and i release. The light blinks red once and immediately goes green. It doesnt allow me to hold throttle and then hold reverse as stated in instructions. Any suggestions? It is a vxl-3s (unfortuneately). Thanks for looking
Old 08-27-2011, 02:36 PM
  #2664
momogt
momogt's Avatar
where did you get the replica motor with the super charger on it
ORIGINAL: phmaximus
Old 08-27-2011, 05:20 PM
  #2665
phmaximus
phmaximus's Avatar
ORIGINAL: godofcable
ORIGINAL: phmaximus
Yeah i do know that, cheerz
To me it made more sence to have spare rear wheels because thay are the ones that wear the most. make sence now?
PS that link... well thay dont post to australia.....
Old 08-27-2011, 05:22 PM
  #2666
godofcable
ORIGINAL: phmaximus
ORIGINAL: phmaximus
doesnt much matter. they are both the same price.
Old 08-27-2011, 05:31 PM
  #2667
phmaximus
phmaximus's Avatar
ORIGINAL: CUHRYTDUH
ummm... where to start, but the transmitter does not work with the ESC, the transmitter controlls the reciver witch controlls the ESC.
Sounds like u have been pushing the button on the ESC, all that does is changes the running mode, and the LVC, & correct me if im wrong it only goes forward???? it thats the case its in race mode.
Do u have a link radio or just the stock one????
If nothing is working at all try binding the controller(TX) to the reciver(RX) i would try this first
Old 08-27-2011, 05:32 PM
  #2668
godofcable
Old 08-27-2011, 05:38 PM
  #2669
phmaximus
phmaximus's Avatar
ORIGINAL: momogt
Its a old Parma 1/10 Hemi V8, got it a few years back from ebay
Old 08-27-2011, 06:03 PM
  #2670
CUHRYTDUH
My Feedback: (12)
I actually have a cheap 27mhz rx/tx. I didnt switch modes, i followed the vxl-3s programing instructions. It says to hold button until green and then red, let go and when it blinks once, hold the throttle, blinks twice, hold the reverse and its set. Well.... when i let go it turns back green and doesnt allow me to hold throttle or reverse. The truck doesnt move at all, nor the steering.
Old 08-27-2011, 06:58 PM
  #2671
make sure that everything is correctly plugged into the receiver.
Old 08-28-2011, 03:58 AM
  #2672
phmaximus
phmaximus's Avatar
hummmmm, sorry i dont know enuff about the VXL-3 to help..
Hows I bashed the living hell out of my slash today at a skate park....
The fake motor came off & fell appart, I lost 2 grills of the RPM front light bar but damm it was fun.
not to shure about the roll cage, it needs stiffer springs. might sell it.... or get some new springs, but where to start..
Old 08-28-2011, 07:33 AM
  #2673
momogt
momogt's Avatar
i have came close to selling my slash a few times but i just cant do it i love to experiment with my truck yesterday i did a 5s run yes 5s i set my slipper loose 90% punch control 8% torque control and nothing broke system ran cool this was with 13/52 gearing with my tacon 2150kv 4074 motor traxxas anaconda tires i also have a gyro in my slash the control is great i just took a few a pics of my slash i trimmed the rear fender because they were damaged but it looks ok
ID:	1654384   Click image for larger version
ID:	1654385   Click image for larger version
Old 08-28-2011, 01:49 PM
  #2674
CUHRYTDUH
My Feedback: (12)
I've tried everything. Nothing happenin, I'll call traxxas tomorrow. Thanks alot. Any suggestions on new lipo friendly esc?
Old 08-28-2011, 04:58 PM
  #2675
momogt
momogt's Avatar
any of the castle creation esc would be good but i would get mamba max pro
