Official HPI E-10 Thread
#651
RE: Official HPI E-10 Thread
ORIGINAL: rx7devil210
Ive had problems with my drive train, i put a brushless motor and kept burning out the spur gear. I replaced it with an aluminum one but it still was tearing up my spur gear i suggest you keep it drift the more traction i got the more my spur gear would ware.
are u running a alloy motor mount, yeah dont wast ur cash on the alloy spur gears thay are T1 alloy rubbish, u cant get a softer alloy.
allso they have a diffrent gear tooth pitch so u cant use the stock pinion
momogt
or even a higher KV rating.....
#652
I just blew my third spur gear out lol even on drift tires... Yea im running the aluminum motor mount from hot racing. what should i do?? Anyone else having problems blowing out their spur gear? Help would be nice thanks.
#654
Don't tell me u used the pinion from the alloy gear with the hpi spur?
How did u set gear mesh and are u sure the mount didn't move casing the gear to strip?
If u can upload a good pic of the worn gear should be able to check for ya
#660
I adjusted the gear mesh with a piece of paper like everyone said to do but it still stripped on me i think those pictures worked thanks for the help.
#661
I was going to wright a big thing about setting gear mesh on the E-10 but thank god for utube, I found this... this is the way i set my gear mesh & i havent stripped any gears, even with a 3900kv motor on 11.1v and rubber tyres.
[youtube]http://www.youtube.com/watch?v=G4TIMyAHrD8[/youtube]
allso see the way he checks it after tightning to make sure it has a tiny bit of backlash, thats another method i use for all my cars, I skip the first step & go straight to that, dont worry about the paper way I never had much luck with that with some other cars
Just rember the ider is to get the mesh as tight as possible while maintaning a slight backlash the hole way around the spur
#662
Hello there, I would like some help with my newly purchased HPI e10.
I heard from most reviews that I need to get a new motor and chasis etc. with it.
Any help would be appreciated.
#664
hey i am new to the whole rc world wanted one for ever and work just started carrying them so i picked up a Scion TC e10. i want to pump this thin up some with out spending a whole lot already ordered my new bearings, drive shaft, and axels. ordering new steering next. mine has the Sc-15wp esc i saw the sprinter has the same esc but running the HPI Racing Firebolt 15T 540 Motor will this also work in the e10? want to upgrade the motor but don't want to have to change a whole lot tx for any info.
#665
hey cool u can run Lipo batteries safely with that ESC...
Yep that motor is ok to use..... just on the limit, u cant run anything under 15t....
IMO stick with the stock motor, & upgrade to lipo's there will be a noticable preformance increase there...
then look into a $80 ezrun 35a combo
#666
FL
I'm sure this has been asked about 10 times in this forum, but for the experienced drifters/ rc enthusiast what would be the best five first upgrades for bang for buck on my E10. thanks for the help guys!
#667
Well if you have a brushless motor i suggest you do the aluminum driveshaft because the stock plastic one will bend at high rpms. But i still cant get my gear mesh right to the point where it doesnt burn out my spur gear.
#668
upgrades
1 faster steering servo & alloy steering kit
2 Brushless setup with alloy main shaft
3 oil filled shocks, swaybars
4 custom chassis brace
5 Universial drive shafts & rear spool
rx7devil210 are 100% sure that the mount is not moving???, did u try setting it like in the video?
#669
FL
no my car is pretty much stock hpi e10 rtr. the only thing i put on it so far is rear and front camber setup, and strut tower bar set. what is a good brushless setup? do you have any preferred brands?
#671
One of the best and cheapest is the 35a Ezrun combos.... wouldent go any lower than the 4300kv combo... They work a treat.
[link=http://www.hobbypartz.com/ezrun-35a-9t-3650-motor.html]check this[/link]
#672
FL
I like that combo a lot, would I need to run larger batteries in the the stock 7.2 1500 mah? Also I have been looking every wheree for your steering setup, I believe it's atomic. Can not find it any where
#673
Thats the thing...
U would need a new cheap charger Imax B6 are great bang for buck [link=http://www.ebay.com/itm/iMAX-B6-AC-B6AC-Lipo-NiMH-3S-RC-Battery-Balance-Charger-/230760071045?pt=Radio_Control_Parts_Accessories&hash=item35ba5f3f85]click[/link]
And a cheap Lipo 2s 7.4v [link=http://www.ebay.com/itm/7-4V-5500mAh-35C-2S-RC-LiPo-Battery-Hard-Case-for-1-10-RC-Car-Traxxas-Tamiya-/290678302775?pt=Radio_Control_Parts_Accessories&hash=item43adc6e837]click[/link]
Steering setup... better than mine Yeah racing [link=http://www.ebay.com/itm/Yeah-Racing-E10-042PP-Aluminum-Bearing-Steering-Set-PP-for-HPI-E10-/290680012931?pt=Radio_Control_Parts_Accessories&hash=item43ade10083]click[/link]
#674
FL
thanks for all of the help! i have been looking at the yeah racing steering setup for a few days. i guess i will go ahead and pick it up. what do you think of the sf-50 servo? would it fit in my car without to much mods. thought it would be much better the the stock sf-1 that comes in e10. do you race yours or just drive for fun?
#675
Steer clear from the HPI servo's.... For cheap digital servos. check these blue bird ones..
BMS-661-DMG+HS 6.4km/cm 60deg0.08sec
BMS-617-DMG+HS 6.8km/cm 60deg0.10sec
BMS-621-DMG+HS 7.2km/cm 60deg0.10sec
BMS-616-DMG+HS 10.2km/cm 60deg0.12sec
BMS-620-DMG+HS 10.6km/cm 60deg0.13sec
BMS-660-DMG+HS 14.2km/cm 60deg0.17sec
HPI SF50 12kg/cm 60deg0.18sec
HPI SF2 6.5kg/cm speed ????
HPI SF1 is around 4.5kg/cm & very slow
For the price of the HPI servo u could get 3 Blue bird ones & they are heaps faster
