Reload this Page >
C-ARF Ultra Flash build Thread + Video
Old 05-25-2016, 12:34 AM
  #5151
Dave Wilshere
It would be a pig to fly like that! :-)
Dave
Old 05-25-2016, 04:58 AM
  #5152
FMRR
Hi Dave, Some people claim pigs can fly and witness to it...after a long night of heavy consumption In this case pretty sure Vr wouldn't be achieved ... good catch sorry I made the error.
Old 05-26-2016, 10:36 AM
  #5153
737Driver
737Driver's Avatar
OK, here come the questions. I started my build today, I'm starting on the wings 1st. To drop the Pro-Link electrics in, it looks like it needs some dremeling to fit to whole unit in. Where the electric gear meets the top of the wing, the factory formed U shape needs to be dremeled/sanded to fit it in right? I don't want to remove to much material.
Old 05-26-2016, 10:46 AM
  #5154
Dave Wilshere
The stock gear is designed to have 1/8" packers under the mounting lugs. (C-36-2) There are pre cut plywood rectangles with holes ready for the behotec gear.
Depending on the lug thickness/mounting screw type, you should be able to pack. With CSK screws you have more clearance on the cover plate
Old 05-26-2016, 10:51 AM
  #5155
737Driver
737Driver's Avatar
Thanks Dave, you must have your fingers on your keyboard and mouse, spring loaded for posts!!! Amazing. OK, back to the garage. Thanks again, and standby for more questions.
Old 05-26-2016, 11:39 AM
  #5156
Dave Wilshere
Evening here, so article writing. Fingers pre warmed ;-)
Old 05-26-2016, 02:10 PM
  #5157
Steve N.
Well the big day has finally arrived :-) It's finally in my garage. FedEx delivered to Oroville WA on Friday, the broker brought it across on Tuesday, but I couldn't pick it up from them until today. Like others,,, it's been a long wait. Big shout out to FedEx.... Only a couple of minor scuffs on the top and bottom of the shipping carton - nothing that would cause any damage. Unpacked the works and an initial inspection found that everything listed on the packing slip was accounted for,,, and there was no damage to anything. I'm a happy camper.
Couldn't resist throwing the wing and stab on for a quick look see. Mannnn... I have never installed wings and stab with such little effort for a proper fit. Everything lines up perfectly and the four bolts drop right in. If the rest goes together as precisely and easily, I'll be a real happy camper.
ID:	2164305   Click image for larger version
Old 05-26-2016, 02:41 PM
  #5158
737Driver
737Driver's Avatar
Wow StevyN! Good on ya! I do like that color. The fit and finish is second to none. How exciting eh???? I just started mine today! Now the fun begins Steve
Old 05-26-2016, 09:07 PM
  #5159
737Driver
737Driver's Avatar
Well, I got the main gear temp installed. Had to remove a bit of material to get it to fit properly. I'm installing the Pro-Link Electric gear. Here's a photo just to let you know the amount of material that needs to be removed
Old 05-26-2016, 10:39 PM
  #5160
Dave Wilshere
Break out the dremel and remove a lot of that ridge, if you lay the aileron/flap servo plate in place you will see. It leaves around 3/16 lip and tabs for the screw fixings.
Dave
Old 05-27-2016, 07:01 AM
  #5161
Steve N.
[QUOTE=737Driver;12218375Here's a photo just to let you know the amount of material that needs to be removed[/QUOTE]
The amount that you had to take out of the u-shape former.... was that in addition to using packers under the retract units, or not?
Steve
Old 05-27-2016, 07:56 AM
  #5162
737Driver
737Driver's Avatar
My Pro-Links lay flat on their own with the material removed. I'll take a photo with them in when I get home. I did grind pretty much that U shape to accommodate the square shape of the retract housing
Old 05-27-2016, 09:01 AM
  #5163
Dave Wilshere
Steve
Sorry, not the mount. The wing skin lip. The servos mount to the U/C carbon cover plate and that ply assy needs to clear the wing skin lip
Dave
Old 05-27-2016, 11:17 AM
  #5164
Steve N.
Hi Dave. I think your last post was for 737 Driver, but I think the wing skin lip was already clear. I remember you mentioning that some time back in this thread. Thanks.
Steve.
Old 05-28-2016, 03:01 AM
  #5165
FMRR
Hi Steve, Glad your jet arrived in pristine shape. It almost looks as good as mine ! Lol ..... Won't be able to get started on my untill after this Memorial weekend, You and 737 will have a head start. Looking forward to the build....cheers to all .
Old 05-28-2016, 05:15 AM
  #5166
Steve N.
Hi FMRR. Yeah, you must have a good sense of awesome colour schemes :-). I'll be getting a later start as well. I've got a Jet Rally in Princeton Jume 2-5 and my goodie box is still at Dreamworks waiting for special order battery and Jet Tech tanks.
Old 05-28-2016, 06:02 AM
  #5167
BlueBus320
My Feedback: (57)
Originally Posted by gooseF22
Back in the day we dialed thrust and used a radar.. we hit 200 with 22 lb thrust in a flat out blast with out the bypass.. so it will fly on 22lb P80 all day nicely.. It will fly on a 100 size engine and break 200 and go uphill nicely too, same as a bandit.. we have had them in the same pattern with identical 100 engines, and they were basically the same speed.. 200 passes all day.
What I like about it over a bandit is its toughness, and it lands easier without the bandits tendencies to tip stall because of the washout
Agreed.. And don't forget the U-Flash is quite a bit bigger than the bandit (almost linearly like bandit vs Electra). It can just do all of the same stuff off of the same sized turbines, & take the stresses of the larger turbines also.
Jay
Old 05-29-2016, 07:33 AM
  #5168
cool3d
cool3d's Avatar
My new Rocket is ready for meiden P180RXI NX8921 all around
ID:	2164862   Click image for larger version
ID:	2164863   Click image for larger version
ID:	2164864   Click image for larger version
ID:	2164865   Click image for larger version
Old 05-29-2016, 12:25 PM
  #5169
scoeroo
My Feedback: (9)
scoeroo's Avatar
Neat install -
Old 05-29-2016, 02:42 PM
  #5170
Steve N.
Hey Cool, it is cool! Very, very nice with a great install. My second favorite color scheme :-)
Old 05-29-2016, 03:27 PM
  #5171
737Driver
737Driver's Avatar
Cool3d
Ok, that's just jet porn right there, totally not fair!!!!! I now need to rethink my install plans
Old 05-29-2016, 09:41 PM
  #5172
737Driver
737Driver's Avatar
OK, main gear temp installed. One main centers in the wheel well perfectly, the other one is off center slightly. Any ideas how to center up that one main?
Old 05-29-2016, 09:46 PM
  #5173
737Driver
737Driver's Avatar
Just a photo of the main gear mount surface. Dave, are you referring to the flange pointed out by my arrow, as far as taking a dremel to it? Also quick question. Servo arm length for both aileron and flap servos? I'm sure it's pointed out here somewhere. Should have wing done here in a few days. Thank you all
Old 05-30-2016, 04:50 PM
  #5174
737Driver
737Driver's Avatar
Aileron/Flap servo mounts are done. Pictures are worth a thousand words. Did I use enough epoxy?
ID:	2165138   Click image for larger version
Old 05-30-2016, 07:18 PM
  #5175
dbsonic
dbsonic's Avatar
hysol looks good Tom.
