C-ARF Ultra Flash build Thread + Video
i am in the process of gathering enough info to but the Ultra Flash
i am flying a JR9303 2.4G radio
i see someinstallation pics with Jr equipment and especially JR or Spektrum receivers
however people are warning me that if i use the JR radio and spektrum receiver , i am signing my new Jet to its death
any comments ? or just taboo .....
thanks
Here is what I am using. Overkill I know but I love the simplicity of the all in one package since I am using 7.4 volt 2S LION batts and need a regulator.
[link=http://www.spektrumrc.com/Products/Default.aspx?ProdID=SPMAR12200]Spektrum AR12200[/link]
For your installation, if you need regulators, look at this:
[link=http://www.spektrumrc.com/Products/Default.aspx?ProdID=SPMAR9210]Spektrum AR9210[/link]
I am about to install the new JR DMSS XG-11 in the original Flash, its been a JR "work horse" since built and with have gone through Mhz, DSM-2 and now DMSS. All systems seem perfect.
No wing tank supplied as std-just the fuse tank at around 2ltrs. Fuse and wing tank is the ideal set-up. Easy and works...
Dw
As for 2.4ghz, I've flown nothing but that since it came out (JR and Speckrum) and in all that time, in hundreds of airplanes with thousands of flights I've never had a single radio failure that wasn't my own fault.
I still say no CROW is best on the UF. You have to be really hamfisted to get this model to snap! It gives loads of warning and will touch down at walking pace in a light breeze.
With std 2 tanks, I fly mixed 8 1/2-9 minutes with a P-120SX. 6 minutes is a wide open flight hard flight with a P-120. The model is clean and if you are trading height you want the power off before you get the nose down.
If it starts to bounce-snatch it off the ground again with a pull of up...means its still flying!
Dw
John
I have the Jet 1-a main legs on mine with the behotec retracts which work well, no issues or compliants.
The trailing link is the only way to go, really helps for those not so good landings.
I cant find a price on the ones through CARF.
[link=http://www.carf-models.com/public_carf/pages/shop/accessoryDetail.html?root=accessory&proId=2416]http://www.carf-models.com/public_carf/pages/shop/accessoryDetail.html?root=accessory&proId=2416[/link]
Ultra Flash | ||||||
Component | Price | Qty | Total | Store | laceholder;border:none;padding:0in 0in 0in 0in"> | |
$1,890.00 | 1 | $1,890.00 | Composite Arf | laceholder;border:none;padding:0in 0in 0in 0in"> | ||
$2,450.00 | 1 | $2,450.00 | Kingtech Turbines | laceholder;border:none;padding:0in 0in 0in 0in"> | ||
$210.00 | 1 | $210.00 | Dreamworks R/C | laceholder;border:none;padding:0in 0in 0in 0in"> | ||
$189.00 | 1 | $189.00 | Composite Arf | laceholder;border:none;padding:0in 0in 0in 0in"> | ||
$749.00 | 1 | $749.00 | Composite Arf | laceholder;border:none;padding:0in 0in 0in 0in"> | ||
$178.00 | 1 | $178.00 | Air Power | laceholder;border:none;padding:0in 0in 0in 0in"> | ||
$93.99 | 4 | $375.96 | Servo City | laceholder;border:none;padding:0in 0in 0in 0in"> | ||
$114.99 | 3 | $344.97 | Horizon Hobby | laceholder;border:none;padding:0in 0in 0in 0in"> | ||
$46.99 | 1 | $46.99 | Servo City | laceholder;border:none;padding:0in 0in 0in 0in"> | ||
$219.00 | 1 | $219.00 | Aircraft International | laceholder;border:none;padding:0in 0in 0in 0in"> | ||
$279.99 | 1 | $279.99 | Horizon Hobby | laceholder;border:none;padding:0in 0in 0in 0in"> | ||
$45.00 | 1 | $45.00 | Dreamworks R/C | laceholder;border:none;padding:0in 0in 0in 0in"> | ||
$31.95 | 2 | $63.90 | Troy Built | laceholder;border:none;padding:0in 0in 0in 0in"> | ||
$159.99 | 1 | $159.99 | Harris Smoke Pumps | laceholder;border:none;padding:0in 0in 0in 0in"> | ||
TOTAL | $7,201.80 | laceholder;border:none;padding:0in 0in 0in 0in"> |
On a side note, everyone raves about how great the Ultra flys over the Classic...that is not my experience at all. It flys good, no doubt, and I think landings are easier but it does have some traits that the classic never had. I am no expert, but I am in range of 350 flights on my flash....and I fly my ultra and a friends classic all the time, sometimes back to back and if given the choice I am not so sure I would stick with the Ultra....
Nonetheless, the Flash..Classic or Ultra is a great jet....
