C-ARF Ultra Flash build Thread + Video
#1976
RE: C-ARF Ultra Flash build Thread + Video
The only reason a tank will implode is because the inward vent is too restrictive, so long as the space left by the fuel can easily be replaced with vent air and the feed lines through the series tanks to the pump are big bore there will be no issues. My setup proves it, with around 100 flights now with Merlin 140, bored out felt clunks, 1/4 inch o/d Tygon, original BVM UAT. Zero cavitation and the same tiny air volume in the UAT from start to finish.
Rob.
Rob.
#1977
My Feedback: (22)
ME
I have the same struts. I am having an issue with the springs being way too soft especially with full fuel. Is anyone else having this issue? i havent yet found any springs that are stiffer, anyone have any ideas?
ORIGINAL: IFlyEm35
Anyone using the Airtech trailing link struts?
Not much of a fan of the square struts. Aside of looks how do they perform?
#1978
ORIGINAL: cbooth1979
ORIGINAL: IFlyEm35
Rob.
#1979
ORIGINAL: IFlyEm35
#1980
My Feedback: (22)
ME
Hi,
Did you have to heat the spring at all or just cut and bend? Reason I ask is that the springs are pretty rugged and do not bend easily.
Thanks for your time,
-Carl
-Carl
#1981
I maidened mine last week. Unfortunately the first landing was a "Snap Landing". Deceleration was much faster then I expected (100 mm or 4 inches landing flap). Nothing happened but my next landings were way too fast what resulted in bumping and some damage to the nosegear.
After studying the messages in this forum I will reduce the amount of flaps for my landing configuration.
Regards Walter
http://youtu.be/rqWCNXOwuOU
Regards Walter
#1982
Curious what happened there on landing , I will maiden mine in a few weeks . Is it possible that you had one flap extended more than the other , because it looked good until the incident? Any help would be appreciated so as not to have the same thing happen to me. From what I heard the uf is a good flying aircraft and does not snap . Could some one with experience shed some light on this incident.
Thanks all
Thanks all
#1983
ORIGINAL: Walo
I maidened mine last week. Unfortunately the first landing was a ''Snap Landing''. Deceleration was much faster then I expected (100 mm or 4 inches landing flap). Nothing happened but my next landings were way too fast what resulted in bumping and some damage to the nosegear.
Regards Walter
Regards Walter
Rob.
#1984
Looks like it dropping a wing to me. Flat calm wind wise and looks hot. Looks slow enough to me especially if a tad heavy. Did you have much fuel left? Was it balanced nose heavy, and were you running any crow or just flap?
Regards Al
Regards Al
#1987
Regards Walter
Regards Walter
#1988
ORIGINAL: ricardinho
hey man so how is that nice blue angel flying?
You saw this video ?
http://www.youtube.com/watch?v=jTExWRVGQHA
And in this video I'm too short
http://www.youtube.com/watch?v=fIwyV0Inwno
#1989
My Feedback: (20)
CA
The landing speed looked good..but i think the elevator got pulled to hard because of the decent rate. Looked like to much elevator for the flare.
#1990
FL
basil not bad at all.. it will slow down much more. try doing lower flatter aproaches...try to get it to drag in...dont worry it has no bad habits ...i know at pgrc you have to loose lots of speed because of the tree line...go to dcrc and fly it...you can slow it up like a boomer...again great job basil!!!
#1991
ORIGINAL: Ali
Regards Al
Regards Al
Regards
Walter
#1992
ORIGINAL: Ali
Regards Al
Regards Al
Mike
#1993
P.S Hey Pat I was looking for a flying buddy at (June 23, 2012 Heritage Days) [8D]
http://www.youtube.com/watch?v=xPelCR4DrZ4
#1995
FL
basil you fly very nice...the flash is very slick...at the bowie field its hard to get a nice low aproach without gaining alot of airspeed...i have been spoiled at hamburg pa field 2500 feet grass no trees..hahaha..let me know when you fly...
#1997
#1998
Cg set per factory is conservative.
That approach was really fast and that defiantly is not a snap, unless you have it seriously heavy on one side the plane will stall flat.
You absolutely do not need crow on the uf keep it simple, can't stress this enough, use the full 4" of flaps and it's will slow down just fine, I land mine in under 100 feet like this no problem.
Just make sure your flaps are nice and even and it will slow down fine and stable.
#1999
The Answer is there, calm, heavy (2.2ltrs of fuel is another 4lb?) It did not snap, it was a slow wing drop. If it snapped at that height it would be dead now. The UF has fabulous slow speed handling and does not need CROW. It likes lots of Flap, you just need more power to keep it moving! OK each pilot has different throttle/elevator handling timing and "feeling" and this makes a difference to how it will land. Balance point is personal preference, the manual position is conservative, but a pilot who knows what they want will adjust balance and control travel/expo, those that don't will find it handles just fine at the offered settings. Some aircraft benefit from CROW, the UF really doesn't. It won't stop a wing drop, it just delays it till maybe its flying even slower than its stall speed!
My UF is two years old next month, one of the first batch manufactured and it does not have a scrape. 100% reliable aeroplane and i've flown it in some tight sites. Its my favourite sports jet ever.
Dw
Dw
#2000
I had a feeling that the plane might have been heavier than it needed to be ( By the way it looked to come in on the video ) It's amazing the difference landing with fuel will make. If you work it out as a percentage of the total AUW of a flash. 4 lbs of fuel is quite a chunk of dead weight to be carrying on final.
I have not had many models that have "needed" crow ( I think one maybe two tops) However! I have had plenty that have benefitted from it, and for me the UF sure is one of those. Now I am not preaching, or professing that I know any better than the next guy. Just saying that in my humble opinion and based on a little bit of stick time I have found that my UF landed in a way that suited me far better when I ran less flap and introduced Crow.
I am not going to get in a twist if people disagree with me, thats the cool thing about this hobby ( Often multiple ways of reaching the same end result ) I just know that I have had my UF in a similar situation to what I saw on that video on a few occasions before ( Although not often its that calm here in the Uk, but I have landed it 90 deg cross wind with nearly a full fuel load) and it did not react in the manner in which I saw on the vid.
If I can be of any help, just ask.
Regards Al
Regards Al
