Reload this Page >
Skymaster F-104 Assembly USAF style
Old 01-06-2015, 05:51 PM
  #101
757Driver
My Feedback: (90)
757Driver's Avatar
Steering design needed a redesign and it was an easy fix. I Hope to have these in production soon for those wishing to improve their jets with more steering resolution and mechanical advantage. Material is 6061T6.
ID:	2061793   Click image for larger version
ID:	2061794   Click image for larger version
ID:	2061795   Click image for larger version
ID:	2061796   Click image for larger version
Old 01-06-2015, 05:55 PM
  #102
757Driver
My Feedback: (90)
757Driver's Avatar
The result. Servo wire shielding added.
ID:	2061798   Click image for larger version
ID:	2061799   Click image for larger version
ID:	2061800   Click image for larger version
ID:	2061801   Click image for larger version
Old 01-06-2015, 06:11 PM
  #103
757Driver
My Feedback: (90)
757Driver's Avatar
Dad didn't like the tight clamp I located the servo wire with so we changed to a clamp with a larger hole to prevent the wire from work hardening. Small Robart air tank fitted for chute system. I didn't have the SM tanks but a bit of fuel line took care of the fit. Hot glue to fix them in place. Nose gear doors hooked up. I'm gonna sequence with a button valve.
ID:	2061803   Click image for larger version
ID:	2061804   Click image for larger version
ID:	2061805   Click image for larger version
ID:	2061806   Click image for larger version
Old 01-06-2015, 09:23 PM
  #104
MorseAircraftDevelopment
MorseAircraftDevelopment's Avatar
Looking great Jason!
Old 04-17-2015, 11:31 AM
  #105
gapellegrini
Jason,
Have you installed the D4S drogue chute? If yes do you have pictures?
Thanks in advance
Gabriel
Old 04-20-2015, 03:10 PM
  #106
757Driver
My Feedback: (90)
757Driver's Avatar
Sold it. Too heavy for my application.
Old 04-22-2015, 03:03 AM
  #107
gapellegrini
Have you maidened your plane? What's the total weight?
Old 04-22-2015, 05:41 AM
  #108
757Driver
My Feedback: (90)
757Driver's Avatar
No maiden yet. It seemed that not many were interested in my thread so I quit posting. I had some life interruptions to my build as well.
I split the accessory bays earler and the latest update, I now have them hinged properly so they can be opened in a scale fashion. Also installed a locking wire. Additionally I removed the canopy air valve because it leaked. Skymaster tried to take care of me by sending me a free replacment but it leaked too. Real 104's never had a powered canopy so I decided to eliminate the air system. I wanted the ability to close the canopy by hand and then lock it from the TX. I'm now installing a small servo in the nose with a small wire to actuate the factory canopy lock. All of this will allow me to keep all access panels attached to the airplane during pre/post flight servicing. I will be gluing the canopys in next and completing the empennage to an airworthy status.
ID:	2091048   Click image for larger version
ID:	2091049   Click image for larger version
ID:	2091050   Click image for larger version
ID:	2091052   Click image for larger version
ID:	2091053   Click image for larger version
Old 04-22-2015, 05:52 AM
  #109
757Driver
My Feedback: (90)
757Driver's Avatar
The pilot I had made is totally wrong. I don't know why this 1/4 scale pilot looks so small in this 1/5 airplane. My plan is now to have taylored pilots make one to specific dimensions to get the proper fit to the airplane. Really frustrating but one of the pics shows an actual pilot in the airplane. The 104 has a small cockpit so the pilot should really fill up the space to be right.
ID:	2091055   Click image for larger version
ID:	2091056   Click image for larger version
ID:	2091057   Click image for larger version
ID:	2091058   Click image for larger version
DenisFerrari (09-13-2020)
Old 04-22-2015, 07:24 AM
  #110
gapellegrini
Nice progress. Thanks for the update. What scheme are you going for?
Do you know where should I used there carbon reinforcements on the chute system?
Old 04-22-2015, 07:28 AM
  #111
757Driver
My Feedback: (90)
757Driver's Avatar
No idea.
Old 04-22-2015, 07:32 AM
  #112
JJP
Gapellegrini what chute system is it? I have the D4S and it does not contain any carbon rods.
Old 04-22-2015, 07:33 AM
  #113
gapellegrini
Nice scheme. Will you use flite metal?
I will probably maiden mine earlier than you. I let you know about the igyro setup.
Old 04-22-2015, 07:47 AM
  #114
gapellegrini
It's D4S.. Dan is not answering my emails about where to put it.
Old 04-22-2015, 01:28 PM
  #115
757Driver
My Feedback: (90)
757Driver's Avatar
Super news about your maiden. You know guys are using 100mm from leading edge for CG now with pleasant results. This is where I'm setting mine.
Another issue I ran into was the wing bolt holes not aligned with the wing. See pic.
I'm going to use a metal coating process. The tip tanks were done as a test and they are acceptable. I want my airplane to have an extremely high polish look like these birds did. The last pic shows my tip tanks.
ID:	2091131   Click image for larger version
ID:	2091132   Click image for larger version
ID:	2091133   Click image for larger version
Old 04-22-2015, 03:59 PM
  #116
George
My Feedback: (57)
Which process?
DenisFerrari (09-07-2020)
Old 04-22-2015, 04:19 PM
  #117
david surick
ok have a Avanti 180 turbine need to see if can get maiden from someone jr dmss I m in ca san jose
Old 04-22-2015, 05:23 PM
  #118
gapellegrini
I was aware about the cg. The tip tank looks fantastic. How much weight you believe this process will add?
Old 04-22-2015, 05:24 PM
  #119
gapellegrini
Jjp,
Where will you attach the chute wire to fuselage?
Gabrie"
Old 04-22-2015, 08:20 PM
  #120
757Driver
My Feedback: (90)
757Driver's Avatar
Originally Posted by George
Which process?
https://www.facebook.com/pages/Chrom...38519112877442
Old 04-22-2015, 08:39 PM
  #121
George
My Feedback: (57)
Are you sending it to them, or do they have DIY kits?
Old 04-22-2015, 08:47 PM
  #122
757Driver
My Feedback: (90)
757Driver's Avatar
I sent the tips to him but now there is a shop in OK that can do them. Added 2oz per tip so not much.
Old 04-22-2015, 09:00 PM
  #123
mistermnkim
My Feedback: (153)
mistermnkim's Avatar
Great build!! Please keep the post coming!
Old 04-23-2015, 06:57 AM
  #124
JJP
Gapellerini it is not installed yet but plan on having it attached to a bulkhead which I will install with the release mechanism.
Old 05-22-2015, 01:02 AM
  #125
dubd
dubd's Avatar
Jason, how is your F-104 coming? I just maidened mine. I had the igyro turned off for the maiden flight. I'll fly with the igyro turned on for the next flight and let you know how the plane responded. I put the plane through a basic aerobatic routine for the maiden and there were no bad tendencies.
