Reload this Page >
skymaster pc-21
skymaster pc-21
Old 04-29-2016, 12:14 PM
  #201
helifox
helifox's Avatar
Hi Mich,
thank you for replay.
I did follow SM manual oleolegs, but unfortunately there is nothing says about PC-21 pressure, so I decide to follow the F-16 same wheght, between 105-135. I did 110 for now, later will see OK or.....
Esterday she first time sit on she's legs.
Regards,
Sergey.
Old 04-29-2016, 10:22 PM
  #202
mich-67
mich-67's Avatar
Default skymaster pc-21
good day to all we have finished all tests with elevators rudder and flaps installation etc . following are few pictures as well .
ID:	2160015   Click image for larger version
ID:	2160016   Click image for larger version
ID:	2160017   Click image for larger version
ID:	2160018   Click image for larger version
ID:	2160019   Click image for larger version
ID:	2160020   Click image for larger version
ID:	2160021   Click image for larger version
ID:	2160023   Click image for larger version
ID:	2160024   Click image for larger version
ID:	2160025   Click image for larger version
ID:	2160026   Click image for larger version
ID:	2160027   Click image for larger version
ID:	2160028   Click image for larger version
ID:	2160029   Click image for larger version
ID:	2160031   Click image for larger version
Old 04-29-2016, 10:34 PM
  #203
mich-67
mich-67's Avatar
Default pc-21
Also we have made final tests etc with the cockpit pilots etc. see the following video
https://youtu.be/RxWOfL8PZXQ
ID:	2160033   Click image for larger version
ID:	2160034   Click image for larger version
ID:	2160035   Click image for larger version
ID:	2160036   Click image for larger version
ID:	2160037   Click image for larger version
Old 04-29-2016, 10:42 PM
  #204
mich-67
mich-67's Avatar
Sergey .good day i have see the the building of your friend (Volodya rus 23 ) pc-21 looks great.
i do like very much his build ideas and Technics he use .
well is the summer almost on the way ,welcome to Greece to fly all together the pc-21.
we have some great r.c. airfields to fly our jets.
best regards.
Old 04-29-2016, 10:47 PM
  #205
helifox
helifox's Avatar
Hi Mich,
we did almost same but decide to do aileron connections as prototype
Flaps road
Rudder
Also rebuld the shelf for nose landing/taxi light, now it's looks more scale ;-)
And some more
ID:	2160039   Click image for larger version
ID:	2160040   Click image for larger version
ID:	2160041   Click image for larger version
ID:	2160042   Click image for larger version
ID:	2160044   Click image for larger version
ID:	2160047   Click image for larger version
ID:	2160048   Click image for larger version
ID:	2160050   Click image for larger version
ID:	2160051   Click image for larger version
Old 04-29-2016, 10:56 PM
  #206
helifox
helifox's Avatar
best regards.
Mich thank you for invitation, will see!
Now we bit hurry to finish PC before great jet meting/festival RusJet masters in Rostov. Hope to see the new project of Vitaly Robertus. It's going to be since June 10 up to Jun 13.
Welcome to this great meting! (Of course with PC-21).
Old 04-30-2016, 08:10 AM
  #207
mich-67
mich-67's Avatar
Dear Sergey ,
I am interesting to attend this event in Rostov along with Argiris Giannetakis. .
Will be a great change for as to meet all of you in person and Mr Vitaly Robertus as well ,
pls send me all relevant details , location hotels airports etc dates .
looking forward to received this info.
best regards / michael
Old 04-30-2016, 08:51 AM
  #208
mich-67
mich-67's Avatar
Dear Sergey ,
looks great your pc as well i do like very much the aileron work.
Old 04-30-2016, 09:24 AM
  #209
helifox
helifox's Avatar
Thank you.
You also did great job with cockpit, looks like alive!
Regards,
Sergey
Old 04-30-2016, 11:50 AM
  #210
DelGatoGrande
My Feedback: (23)
DelGatoGrande's Avatar
Previet Sergey! Very nice work!
How much is the endpoints of your ailerons now?
Old 04-30-2016, 12:14 PM
  #211
helifox
helifox's Avatar
Kalispera,
We did 25mm Up, 20 mm Down
Kind regards,
Sergey
Old 04-30-2016, 11:59 PM
  #212
DelGatoGrande
My Feedback: (23)
Hello Sergey!
No ,i mean in your radio,in the "end points" menu .
How much your aileron limits are now with this setup? 100% - 100% ? ... 60% - 80% ?
Spasibo!
Old 05-01-2016, 12:28 AM
  #213
helifox
helifox's Avatar
Hi George,
Travel limits is 38-47%.
The length of aileron horn- 31mm, servo horn -25mm
Kind regards,
Sergey
Old 05-01-2016, 02:02 AM
  #214
DelGatoGrande
My Feedback: (23)
Originally Posted by helifox
Hi George,
Thanks for information, but will try to do inner pushroads as manual sais. Will try to find solution (may be somebody help with pictures). My friend will install JR8911 all around.
Харистополи,
Kind regards,
Sergey
This is what is was trying to say in my previous post.
With 38%-47% end points your aileron servo travel will have very poor resolution in compare to your aileron stick travel.
"When set up for maximum resolution(maximum end points), the control response is much smootherand more closely matches the precise inputs and intentions of the pilot "
http://www.rcflightschool.com/SetupPDFs/Resolution.pdf
Maybe if you try drill a new hole on your servo arm as closer you can to the servo arm center so you can increase your %-% end points .
The your Aileron feeling during flight will improve dramatically .
Old 05-01-2016, 03:17 AM
  #215
helifox
helifox's Avatar
George,
thank's for information, but we check aileron movement - it's looks very smooth (maybe it just first view). Anyway, will check these on maiden, in case will it be uncomfortable will rebuild.
So the PC-21 is not 3D bird, it's should flight as more scale. I hope everything be OK.
On my UltraFlash the same servo travel (39-45%) plus 45 Expo and I like she's flying.
The servo horn has maximum length to be inside wing now, with maximum possible hole from center for pushroads.
Kind regards,
Sergey
Old 05-01-2016, 09:31 AM
  #216
DelGatoGrande
My Feedback: (23)
George,
Kind regards,
Sergey
Hello Sergey,
actually the 3D planes do not have good resolution because of 3D setup.The best knowledge in resolution setup you will find it in precision aerobatic planes like F3A and helicopters.
When you have wide end points ,meaning wide servo travel in compare to the stick travel, then you can experience a superior feeling while flying the plane.
In the SkyMaster F-104 i did hidden links like you i drilled new hole on the servo arm closer to center to gain resolution.I attach you photo.
All the best with your maiden my friend.
Paka from Greece
George
Old 05-03-2016, 06:29 AM
  #217
pilot tw
test flight the PC-21 again yesterday.,
https://www.youtube.com/watch?v=eyLk80M90bI
Old 05-04-2016, 05:32 AM
  #218
helifox
helifox's Avatar
HI to all,
Today we did weigh PC-21, dry weight with full UAT is 21 kg- well-fed bird :-) (take-off weight will be 22,5).
Frends, what about yours?
Also I think to add pressure to main legs, to be 120PCI (now 110).
Kind regards,
Sergey
Old 05-04-2016, 06:07 AM
  #219
argyris
argyris's Avatar
https://www.youtube.com/watch?v=YrlGHVUYcGY
Old 05-04-2016, 09:12 AM
  #220
David Jackson
My Feedback: (15)
WOW! Very nice, thanks for sharing.
Old 05-06-2016, 10:02 AM
  #221
helifox
helifox's Avatar
Today we did first RunUp of K-60TP, with 5 blades prop is very powerful unit.
The PC-21 almost ready for maiden, keeping fingers are crost it will be soon.....
http://youtu.be/bFJ45v6xJ-M
Kind regards,
Sergey
Old 05-07-2016, 01:59 AM
  #222
mich-67
mich-67's Avatar
Sergey good day , soupeb start up , lights looks fantastic as well , I Have the same on my plane.
My is almost ready few things left prior maiden flight .
thanks for sharing.
Old 05-07-2016, 02:33 AM
  #223
helifox
helifox's Avatar
Hi Mich,
i have a couple question:
- what pressure you put to your PC legs? (I'm afrade 110PCI is too soft)
- what is the dry weight of your bird (expecting take-off weight)?
Thank's
Kind regards,
Sergey
Old 05-07-2016, 04:35 AM
  #224
argyris
argyris's Avatar
ID:	2161238   Click image for larger version
ID:	2161239   Click image for larger version
ID:	2161240   Click image for larger version
ID:	2161242   Click image for larger version
ID:	2161243   Click image for larger version
ID:	2161244   Click image for larger version
ID:	2161245   Click image for larger version
ID:	2161247   Click image for larger version
ID:	2161248   Click image for larger version
ID:	2161249   Click image for larger version
ID:	2161250   Click image for larger version
ID:	2161251   Click image for larger version
Old 05-07-2016, 05:12 AM
  #225
mich-67
mich-67's Avatar
125 pci regarding dry weight I don't know yet keep you posted
