Reload this Page >
Maj. Woody's Ultra Flash
Old 02-13-2017, 06:47 AM
  #151
warbird_1
My Feedback: (61)
warbird_1's Avatar
factory says it's done . made second payment today should see it in 10 days ! Fly Air Force with me dom !
ID:	2200848   Click image for larger version
ID:	2200849   Click image for larger version
Old 02-13-2017, 09:12 AM
  #152
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
Originally Posted by MaJ. Woody
One minor issue...the "Thunderbirds" lettering on the side of the fuse is not paint in the mold but Vinyl Lettering. It was not positioned in the same place from left to right. This will drive me nuts. I sent an e-mail to CARF asking for another set of these decals so I can position them evenly.
Hi Maj. Woody,
This would drive me a little nuts as well. Glad they're vinyl and easy to correct, beautiful jet. thank you for sharing.
Old 02-14-2017, 02:55 PM
  #153
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Looks good Griz. Look out Perry!
Old 02-14-2017, 03:32 PM
  #154
warbird_1
My Feedback: (61)
warbird_1's Avatar
Originally Posted by maj. Woody
looks good griz. Look out perry!
ooohh yea !
Old 02-16-2017, 08:29 AM
  #155
General Jake
General Jake's Avatar
It would seem there will be a few more T-Bird F-16's this year.
Old 02-16-2017, 10:07 AM
  #156
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Thought this was a Ultra Flash thread...
Old 02-16-2017, 10:37 AM
  #157
warbird_1
My Feedback: (61)
warbird_1's Avatar
and ?
Old 02-16-2017, 11:54 AM
  #158
scoeroo
My Feedback: (9)
scoeroo's Avatar
Common denominator - Thunder bird scheme
Old 02-16-2017, 02:46 PM
  #159
warbird_1
My Feedback: (61)
warbird_1's Avatar
Old 02-17-2017, 11:04 AM
  #160
smiller
Not seeing much action Dom, you should have this done already !!
Scott
Old 02-17-2017, 08:30 PM
  #161
jesse2357
how would you plumb the vents if using the saddle tanks? I'm trying to decide if I want the wing tank or the saddle tanks. the saddle tanks hold more but is it all usable?
Old 02-17-2017, 11:54 PM
  #162
Springbok Flyer
Springbok Flyer's Avatar
Fuel in the saddle tanks is all usable and much less hassle than the wing tank to live with. The vents are plumbed the normal way with equal length tubing up to a T-piece before exit/overflow. The feeds are done the same but goes to the vent of the fuselage main tank.
Cheers,
Jan
Old 02-24-2017, 03:51 PM
  #163
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Yep its just how Jan has described it. One exception for this setup is that the T fitting is not required. The main tank has two vent nipples. Each of those will go to one of the saddle tank clunk nipples. This is a less restrictive setup. The two saddle tanks are equivalent in capacity to the one wing tank. But as noted earlier, its less hassle.
Old 02-24-2017, 03:56 PM
  #164
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Scott
Hi Scott. I kind of actually just started two nights ago! I have been enjoying my new snowmobile and managed to get 978 miles on it this season. The warm temps have all but ended the season so I am now switching gears to building mode.
Old 02-24-2017, 04:10 PM
  #165
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Ok so back to building! Having painted all the linkages and the seams on the stab, I am ready to install the elevator servos and linkages. By the way here is how the LE on the stab turned out after my airbrush work. In the end, the juice was not worth the squeeze on this. I will be leaving the wing and fin seams alone (at least for now).
Old 02-24-2017, 04:15 PM
  #166
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I am using the recommended JR 8411 servos and JR HD servo arms. After centering the servo and finding the the side of the servo arm that brought me closest to center, I cut off the the opposite end of the arm and sanded it smooth with my Dremel Tool. I put a drop of thick CA on the servo arm screw for extra security.
ID:	2202660   Click image for larger version
Old 02-24-2017, 04:20 PM
  #167
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
The servos are attached to the composite covers via aluminum brackets and machine screws (painted of course). These come pre drilled and tapped for the recommended JR servos which I have. Well my frustration started when I realized the holes between my "recommended" servos don't line up with the holes in the aluminum brackets.
Old 02-24-2017, 04:25 PM
  #168
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
After enlarging the pre drilled holes on the composite covers, I secured the aluminum brackets to the covers using Loctite on the screws. Here you can see the painted screws to good effect.
ID:	2202663   Click image for larger version
Old 02-24-2017, 04:27 PM
  #169
jesse2357
Were you able to order the jet tech tanks just main and saddle or did you have to buy the wing tang also.? On their website it shows main and wing or all four but not the main and saddle
Old 02-24-2017, 04:31 PM
  #170
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I had to elongate the holes in the aluminum brackets so the holes in the servos would line up. Having done that, I now had to secure the servos to the brackets with nuts under the bolts. Out of 8 holes (between the two servos) I actually had one line up so that did not need a nut. I used Loctite on all the bolts.
ID:	2202665   Click image for larger version
ID:	2202666   Click image for larger version
ID:	2202667   Click image for larger version
Old 02-24-2017, 04:34 PM
  #171
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Were you able to order the jet tech tanks just main and saddle or did you have to buy the wing tang also.? On their website it shows main and wing or all four but not the main and saddles.
I e-mailed Gary with my request and he put this package of saddles and main tank together for me. If I opt for the wing tank later he is only going to charge me the difference between what I paid for the 3, and the full set.
Old 02-24-2017, 04:43 PM
  #172
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Next I glued in plywood doublers in the location of my servo mounting screws using thick CA, followed by thin CA and accelerator. Be sure to sand the gluing surfaces inside the bay since they may have some buildup. Mine did.
ID:	2202669   Click image for larger version
Old 02-24-2017, 04:48 PM
  #173
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Drill a hole in the upper skin to pass your servo wire through. This will later receive a rubber grommet.
Old 02-24-2017, 04:51 PM
  #174
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Some trimming of the recessed ledge will be necessary to clear the aluminum brackets.
ID:	2202673   Click image for larger version
Old 02-24-2017, 04:54 PM
  #175
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I found it far easier to pass the servo wire through the grommet before installing the grommet in the upper skin.
ID:	2202675   Click image for larger version
ID:	2202676   Click image for larger version
