Powerbox Core radio and set up thread. >
Old 10-05-2024 | 03:30 PM
  #1976
Default Voice commands
Did the update, where did all my voice commands go like “gear up” no more voice.
Angus
Old 10-05-2024 | 04:09 PM
  #1977
BarracudaHockey's Avatar
Did you do the OS update first? Then the application?
Or have you done the OS update at all?
Old 10-05-2024 | 04:17 PM
  #1978
CostasV's Avatar
Angus
Hi Angus,
Just out of curiosity did you press on the the update for the operating system or the application when you started the update process...?
If you clicked on updating the application, you just need to go back and update the operating system.
The whole update process should work ok just by updating the operating system... no need to click on any other update buttons.
Also - just double check your audio settings in the audio menu in case your volume is down too low and you simply are unable to hear the sounds.
Old 10-05-2024 | 07:05 PM
  #1979
Thank you for the replies… read the instructions first 🙄, did not perform the second step.
wow volume is loud😀, need to turn it down a bit
thanks again
Angus
Old 10-09-2024 | 05:07 PM
  #1980
marksp's Avatar
My Feedback: (9)
GPS modelfinder implemented
Anyone have info on this feature?
Old 10-10-2024 | 03:13 AM
  #1981
If you have a gps module on your aircraft, it gives you a little map with the transmitter in the center and dot to the last known location of the gps unit that you can use to walk to your model. Or drive to as the case may be
The following 3 users liked this post by BarracudaHockey:
Len (10-14-2024), skunkwurk (02-22-2025), Springbok Flyer (10-10-2024)
Old 10-18-2024 | 04:19 PM
  #1982
Hi All, I am trying to have the trim to beep when i change the trim but no matter what i do on this model, it does not do it. have you guys experienced this ? Here is my screen. I also have the beep in functions set up.
Behzad
Old 10-18-2024 | 11:05 PM
  #1983
CostasV's Avatar
You are looking in the wrong spot...
For the Trim, audio/vibe controls are setup within the Trim Menu found in the main Functions screen.
Once in the Trim menu the audio and vibration options can be found here in the 'Signal' type selection box.
If you have set it up correctly as per above... are you getting other sounds through the speaker...?
Old 10-19-2024 | 08:23 AM
  #1984
Hi Costas, thank you . I am in correct spots and have correct set-up. The only time I receive any feedback is that if I have it on Vibration and Beep. Then when trim in center, I get vibration and still no beep. But don’t get any sound or vibration once I move the trim. Now that you mentioned sounds, I noticed that I am not getting any sounds from the timer although it is set up for beeps. The radio does not have much use on it. Thanks again.
Behzad
Old 10-19-2024 | 09:29 AM
  #1985
Did you recently update the firmware to 3.40?
if so did you also update the OS to 3.2 at the same time?
Old 10-19-2024 | 09:59 AM
  #1986
Hi Andy, thank you soooo much. I had not updated the OS. As soon as I updated it, it worked. I have the Transceiver 1.46 and Stickcontroler at 1.5. Are these correct?
thanks again.
Behzad
Old 10-19-2024 | 10:26 AM
  #1987
You don't fool with those, they are automatic. Application and OS are the only ones that you should fool with (and the receivers of course)
Now that you're up to date go into the receiver update menu like you're going to update a receiver and use the new button to download the latest firmware available for all the receivers.
And you're welcome.
Old 10-19-2024 | 10:29 AM
  #1988
AEROSHELDON's Avatar
My Feedback: (99)
And you're welcome.
I wish I didn't have to drag out the rebel max and put it together (I have an XS in the fin) just to get to the rx menu.....
Old 10-19-2024 | 10:34 AM
  #1989
Thank you again Andy, I have a lot of receivers to update as well. And Yes, one is Rebel max but mine has not been maddened yet and receivers are in the fuse. 😀
Behzad
Old 10-19-2024 | 01:45 PM
  #1990
CostasV's Avatar
You could just apply power to the lead coming out from the fin so that the Rx can be powered up and not the complete aircraft - You could also just use the Mobile Terminal for this.
Nevertheless there has been no update to the firmware of the 26XS receivers as yet so no need to update it at this point in time.
AEROSHELDON (10-19-2024)
Old 10-19-2024 | 01:57 PM
  #1991
My Feedback: (99)
Yeah I jump it to the XS in the fin, but I still have to get the Max out.
Old 10-21-2024 | 07:11 PM
  #1992
Springbok Flyer's Avatar
Hi all,
It has been a long time since I've had to download a new photo of a new model. In the meantime I've changed computers and now I can't remember the program I used to resize the photo so that it can be transfered to my Core via USB.
Please can you enlighten me?
Regards,
JanR
Old 10-22-2024 | 11:24 AM
  #1993
CostasV's Avatar
Hi Jan... I was just using Paint 3D in Windows but MS are dropping this app at the end of October from memory.
I also use a more complex photo editing program (which is free) called GIMP.
Just remember that you need to scale the image to the following dimensions 215 x 100 pixels and save it as a JPG file ie. the image file must have an extension of .jpg (not .jpeg or anything else).
it is important to save it in the root directory of your USB stick (otherwise the Tx will not locate the file) and then just import the image over using the Image button in the model selection menu.
The following 2 users liked this post by CostasV:
Jannica (10-22-2024), Springbok Flyer (10-22-2024)
Old 10-22-2024 | 12:01 PM
  #1994
.jpg and not .JPG either
Old 11-06-2024 | 07:14 PM
  #1995
I tried updating my Core today and now it doesn’t have all the sounds or shortcuts anymore. I have no System icon to access any of the wifi, software or other info that was there before.
Has anyone seen this or know how to fix it? It’s like it only did part of the update.
Thanks!
Old 11-06-2024 | 07:30 PM
  #1996
Please see post # 1985 and make sure you don’t make the mistake I did. Both have to be updated.
Old 11-06-2024 | 07:33 PM
  #1997
I have read through these, but like I stated above, I no longer have a “Settings” icon to access any of the software info or anything related to the system settings.
Old 11-06-2024 | 11:53 PM
  #1998
David Gladwin's Avatar
A new software update 3.50 was released a few days ago. Several bug fixes including sound problems.
Old 11-07-2024 | 04:57 AM
  #1999
The answer is no, I've never heard of losing the system icon.
The sound thing is common, if you don't update the OS first and only update the application.
If the system icon is gone you're going to have to go to the support forum and ask Richard or Adam
Old 11-08-2024 | 07:23 AM
  #2000
marksp's Avatar
My Feedback: (9)
Default PBR-26D firmware update failure ?
One of my many PBR-26D's fails update. Currently running 4.1, but unlike my other 26D's will not switch to update mode via CORE update. When I try Mobile Terminal update, MT properly detects v4.1 and does not show v4.2 available for this receiver. All other 26D's successfully updated to v4.2 via CORE or MT. This 26D is NOT in the recalled batch.
Always a bit concerned to fly an Rx that isn't playing nice
Any tips???
