F-16XL ARF by Global Knight Models from Global Jet Club
#451
It will be great to catch up… been too long. I am making some changes to mine to help the factory understand what is needed in the Pro version… just moved the turbine back 30mm and added a third tank (small header tank) right in front of the turbine sitting on my carbon FOD cover. Trial fit today looks good so hoping to get out and test very soon.
I will let you know when and where in case you can make it. All the best mate.
Yoda
#452
Hi Yoda,
My main gear FOD shield does not interfere with the wing tube clamps. See pics in post #368 above. My 3D printed shield fits in from the top of the turbine rails and does not get near the wing clamps or bolts. Yea, working from the bottom is a PIA, especially for the old fart here.
Did your kit come with the wing tip AIM-9 missiles? I would like to get some tip missiles since full scale XL always had them on. I would also like to make some AIM-120 missiles to hang on the underside to give the jet some teeth! But, I seem to never have time to do the extra stuff.
Looking forward to seeing your photos, your up to 6 posts now, 4 more to go!
Gary
Gary
I just had a reply from Air Knight re the AIM-120 mould progress. They are definitely going to produce them and have design and decals ordered. I will post details as soon as available.
Regarding posting photos… I just tried to add six jpegs to show you my FOD cover, close ups of the wing attachment points (beautiful carbon work) and some recent changes I am making… BUT, blocked again haha… difficult site to work with. Had an error saying I didn’t have a security token. Contact administrator. Unfortunately I am very time poor at the moment as we have guests and then I’m away for the weekend. Will try again Monday. Have a nice weekend mate.
Yoda
#453
![](/forum/images/badges/premium_member.png)
My Feedback: (20)
...Regarding posting photos… I just tried to add six jpegs to show you my FOD cover, close ups of the wing attachment points (beautiful carbon work) and some recent changes I am making… BUT, blocked again haha… difficult site to work with. Had an error saying I didn’t have a security token. Contact administrator...Yoda
I just sent Andy (BarracudaHockey), the RCU Community Moderator, a PM asking to fix it so you could post photos. Hopefully it will start working soon.
Best,
Gary
#454
Got my FOD cover printed (thanks again Gary and Keith!). It was about 1/4" too tall for my print platter, so I had to slice it in half and then CA together.
And it turns out that I'll be getting a Feibao F-15E before the XL arrives, so I'm going to be busy! Now I'll have both planes from the Air Force Enhanced Tactical Fighter competition.
![](https://cimg5.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/1296x864/img_8274_ae4e717f3608c613f064243cc7ce90e9c066b16a.jpg)
![](https://cimg6.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/1296x864/img_8275_227df472b93b5691689c1227e2f2b45ba764842a.jpg)
![](https://cimg4.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/275486937_10208993719677978_5376324997619872023_n_be0db68fc5c596f687967e87b5e24125e81a4125.jpg)
Viper1GJ (03-11-2022)
#455
Hi all… hopefully now RCU will let me post some photos. Gary asked to see my carbon FOD cover so I will start with that to test the system.
I started by making a simple mould from a cardboard tube that I found in the shed. I added two pieces of 3/4inch square timber at around 10 and 2 (as if looking at a clock face) that I calculated would make flat mounts to sit on top of the turbine rails. I then wrapped the entire mould with clear packing tape… and added tape to two steel rules to allow me to clamp the carbon to the mould.
I used a single layer of fairly heavy carbon weave. Marked my temple on the outside of my clear plastic. Laid the over size piece of carbon onto the plastic. Poured on my mixed resin then folded the plastic side with my template onto the top. Then squeegeed the resin throughout the carbon using an old credit card ensuring all wet and then pushed as much resin out as possible. Using a rotary knife I then cut along my template, peeled one side of the plastic off and laid it over my mould and clamped it in place after removing the outer layer of plastic. It worked so well. Light and strong… plenty strong enough to double as a third fuel tank mount.
I did need to trim some carbon out with a dremel to allow the turbine mounts to fit and also for the main gear door servo arms to move full travel in the closed position. I have since filled the gaps left at the front with black foam and mounted a small header third tank onto the foam.
I also made a thin plastic FOD cover that fills the large holes behind the front gear bay
I can’t wait to back out to test it now.
cheers,
Yoda
Just tried uploading photos again… rejected again. Maybe something to with using my iPad instead of computer? I will try starting a new thread under Air Knight F16XL to see if that works
cheers,
Yoda
#456
I have a thread started in RCGROUPS… photos and links working there… I will monitor this thread, but will be posting all info and pics in the other. Uploaded photos of my carbon FOD cover today.
I will add more of my XL tonight and during this week.
Air Knight factory has been designing improvements for the Pro version and I will share pics, drawings and details as they become available.
Please feel free to join me on RCGROUPS and let me know if you would like to know anything specifically about this great aircraft.
regards,
Yoda
regards,
Yoda
Yodes65 (03-15-2022)
#458
I have a friend that does super scale AIM-9 and AIM-120 missiles so I'm having him print some for me, and I'm working on printing up a bunch of Mk82s in ABS. The hard part on the Mk82s will be adding structure in the wings for the hard points. Not sure what I'm going to do yet.
#459
My Feedback: (20)
Is your friend willing to share the 3D print files for the AIM-9 and AIM-120 missiles? I was hoping to get some from the factory but have not been able yet. I wanted to put AIM-9 and AIM-120s on since the full scale flew with them most of the time. I read that the full scale AIM-120s were wooden dummy mockups since the real deal was not yet made when the XL was first flying.
Gary
#461
Hi Pat,
Gary
Gary
Unfortunately, he sells them as a side business, so no file sharing. However, there are files on Cults3d and thingiverse for the AIM-9, but they would need to be scaled up for this 1/6 XL.
#462
First Mk82 is off the printer. Came out pretty good. Now I need to devise a mounting system and pylon. I will probably do a slide lock system like Freewing does on their pylons and ordnance. Will make it much easier to take on and off instead of having to screw a bunch of stuff in. The 3rd pic illustrates how that works. Frontal air pressure keeps them locked in place.
![](https://cimg2.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1333/img_8282_323809ab75404b3709f0288dca486d60c2586b0a.jpg)
![](https://cimg3.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1333/img_8283_d4eb164bdb3ac6e09eba92e0afe8e2235d33baef.jpg)
![](https://cimg1.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/1020x680/fj31111p_18_b3a891d0addef0cc6db4ec254e567c9b88a68d17.jpg)
#472
They may not be super scale but there are several available on Thingiverse, it might be worth experimenting with scaling them up.
https://www.thingiverse.com/thing:3592144
patf (03-17-2022)
