JetJoe OWNERS thread
#1151
I was able to strip down the turbine as was discribed. The brgs look in excellent condition. I strongly believe that the problem is with the preloading. However, I ran across a bigger issue. Upon removing the turbine from the housing, I noticed a piece of the CC & lots of small burnt pieces. It tuned out that the inner part of CC was deteriorating - that would explain the few "sparks" I saw. I was told that the turbine had INCONEL CC, so I don't know what happened. So I will be sending it back to Gabe at JetJoeUS for repair. I hope it will be covered under warranty. The funny thing was it was running great the whole time. Idle at ~40k @ 498-500 deg & FT at ~160k @ 618-625 deg. It had a total of 18 cycles & 165 min.
#1152
I wonder if this is a re-badged JetJoe?
Looks like a JJ-1400 but they call it a JLT750.
[link]http://shop.rotor.com.sg/show-detail.asp?prodid={C0C1B461-0808-4CA9-B476-845A463ADC81}[/link]
#1153
ORIGINAL: MAX NITRO
http://www.modelengines.com.au/
Shame with all the thousands of colours available they have to use Wrens.
Paul
#1155
My Feedback: (13)
NJ
Hey,
Anyone have experience with either the 1200 or the 1400 in the .46 size 51" Nitroplanes bobcat?
I know they fly well, justt wondering what kind of performance I could expect out of one of thes motors.
http://www.nitroplanes.com/newsibo5051a.html
Brian
Brian
#1158
My Feedback: (13)
NJ
Yeah, just a lot more money. Once you add up the retracts, high torque servos, and the fact the engine is twice as much when you go from the 1200 to the 1400. I could go with the fill manual start 1200 for $800 on the smaller jet. A friend has the 120 and says its very heavy.
#1159
My Feedback: (69)
ORIGINAL: TUMBLER
"Ye know not what ye speak of"
Seeya....
Dave
#1160
My Feedback: (13)
NJ
Yeah you are right, I have a Kangaroo with a Ram 750, so was looking for something smaller as just a beater(even thought my kangaroo is beater for most people. haha)
#1161
ORIGINAL: TUMBLER
Hey,
Brian
Hey,
Brian
I have the 1400 in my nitro bobcat, great combination goes ballistic, rockets off grass and my turbine is not putting out the thrust quoted, weight without fuel is 9lb I never fitted retracts for simplicity.
#1164
Hi,
I'm trying to get opinions on the JJ-1800. It seems that almost all of the discussion here is on the 1200 and 1400. Can anyone share their experiences with the new 1800?
Thanks, Ken
Thanks, Ken
#1165
ORIGINAL: JustABigKid
Hi,
Thanks, Ken
Hi,
Thanks, Ken
take the step and let yourself hear
.someone has to be first...
#1167
So Gabe from JetJoeUS replaced my jj1400 CC with the "new style" design - which supposed to run cooler. The engine runs great except at idle (set at 45k) it appears to "crackle & pop". Also, there seems to be a hot spot at the 2 o'clock position (looking from the rear). What's the cause of the "crackling & poping" at idle? I've read of this problem on other manufacturer's turbine as well, i.e., Artes...How can I eliminate the hot spot?
#1170
My Feedback: (10)
I have a JJ1800 I bought a couple of months ago. I ran it fot the first time this past weekend. I have the semi- auto version. My first start attempt I couldn't get the propane lit, even with what I thought was a freshly charged Ni- starter. I changed the plug to the same type I use in my other turbines and it lit. It idled at 30k rpms as advertised. I could only get 96k rpms at full throttle as opposed to the advertised 115k. I almost certain that this was due to my fuel pump/ ecu battery not being fully charged.The HDT was indicating around 6.7 volts at full throttle. Also, I hadn't charged the battery since I had it. I ran it just to make sure it would run. I'll run it again this weekend with everything fully charged and post my results as far as full throttle rpms. I guess in a nutshell, I'm very happy with it. It appears to be a good engine. It's a gas guzzler unlike my Wren.
#1171
My Feedback: (13)
NJ
Not sure if its normal, but a lot of the engines I have seen do that at idle.
ORIGINAL: topgunhobbies
How do you eliminate it then? Would this also be the cause for the hot spot?
#1173
I agree that the idle popping is usually not a big deal as long as it is minor popping. To cure it, you need to take apart the turbine and re-point the fuel needles (the ones on the vaporization tubes that are dripping) so that they are squirting fuel properly into the vaporization tubes in such a way that you get full vaporization before the fuel/air enters the primary combustion zone. Best left to an expert on that engine.
#1174
Hello guys,
I am very interested in this turbine, i am planning to have a jj1400 or 1800 on a Composite-ARF Kangaroo, what are the recomendations?
Also where could i buy this turbine on the Web for the US????
Alfredo.
Alfredo.
