 Comp ARF Flash update >
Old 10-08-2009 | 07:52 AM
  #876
My Feedback: (134)
Default RE: Comp ARF Flash update
I have talked to the owner of the one in the marketplace. It is a really well equiped Flash and at a great price. The only reason I have not purchased it is that I have a new Rabbit and ordered a new Flash on the 28th which is in transit now. If you snooze on these deals, you lose.
Old 10-08-2009 | 04:31 PM
  #877
I sent the seller of that great looking flash a PM and he wants to sell it as a RTF. I also have a Rabbit I want to put in it! It is my fav colour also! See what happens!
Mav
Old 10-20-2009 | 02:32 PM
  #878
Knock's Avatar
Do you balance the Flash gear up or gear down
Old 10-20-2009 | 02:47 PM
  #879
RCISFUN's Avatar
My Feedback: (44)
Down
  #880
In as much as the balance is as the model flies i.e. with the gear retracted this is the way I set mine up. However since the critical stage of any flight is the landing with the gear down, it's any bodys' guess. The recomended range for the c of g is very narrow on this model but I cannot say that I have ever felt nervous. Mine is balanced on the forward point and flies a treat. Ron
Old 10-20-2009 | 02:49 PM
  #881
tassos p's Avatar
ORIGINAL: Knock
always down
Tassos
Old 10-20-2009 | 02:56 PM
  #882
Knock's Avatar
I initially balanced the model with the gear down but wiyh the gear up there is quite a difference .
Old 10-20-2009 | 03:16 PM
  #883
ORIGINAL: tassos p
always down
Tassos
that is incorrect, on some setups where the main wheels retract back (such as on a P-40) you balance with the gear up. the Flash is gear down.
Old 10-20-2009 | 03:22 PM
  #884
I tend to balance new models gear down and header full as this is likely the landing phase, when things become more critical.
The Flash 365mm was set gear down and UAT (just infront of wing break) full.
Dave Wilshere
Old 10-20-2009 | 05:11 PM
  #885
Knock's Avatar
Thank you everyone for your replies .
Old 10-27-2009 | 08:54 PM
  #886
gooseF22's Avatar
ON the way, On the way.... e i e i ooooooooooo!!!!
My flash is on the way!!!! Tbird variety.. my little wren SS is crying for a divorce from the rookie I broke the news to him tonight....
Old 11-18-2009 | 03:18 PM
  #887
Keep it light Ron Sweeney
Old 01-29-2010 | 05:20 PM
  #888
PaulD's Avatar
My Feedback: (39)
New Red Checkers Flash is shipped!
Anybody manged to squeeze 8611a's into the stab? Already have the servos so want to use them if I can.
PaulD
Old 01-30-2010 | 06:36 AM
  #889
ORIGINAL: PaulD
PaulD
Iused 8711 servo's in the stabs.
You only need to scrap some foam of the inside of the steps.
best regards Maikel
Old 03-07-2010 | 06:03 PM
  #890
new red checkers to match pauls is on its way we are starting a west coast show team hopefully our powerplants are adequate enuff these are a great value.i cant wait to start on it is it hear yet paul?
Old 05-20-2010 | 08:04 PM
  #891
Hi All,
I just purchased(sent money in) for my Flash, in the Thunderbirds theme. Does the kit come with a UAT, and if so is it as good as the BVM one? I am trying to decide if I should order one.
Also which servos have you been using in the stab for the elevators.
Thank you,
Stan
Old 05-20-2010 | 08:51 PM
  #892
phjoker's Avatar
I was able to get Futuba 9155 in the Stab.. And no it does not come with a UAT
Old 05-20-2010 | 08:54 PM
  #893
My Feedback: (134)
Stan, mine did not come with a UAT. I am using the one from Dreamworks and it is fine. I just just used the recommended 8411's becuase I had them you can use other servos but you may have to modify the stab a bit. 8411's fit pretty good with a little file work. Mine is the Thunderbird scheme also and it is really easy to see in the air.
Old 05-20-2010 | 08:56 PM
  #894
causeitflies's Avatar
It comes with a hopper tank which is used as an air trap.
Old 05-20-2010 | 10:15 PM
  #895
Thanks guys,
I have used the Dreamworks UAT before with very good results also. I will get one.
I have some HT 7955's I believe they are the same size as the 8411's.
Anyone used the JR 3421's for power on the elevators. I have never used them, and they are smaller.
I ordered the Dreamworks gear package after being warned by several Flash Pilots I know.
Looking forward to the build, I am going to order a JC 120 SX for power.
Stan
Old 05-20-2010 | 10:38 PM
  #896
ORIGINAL: causeitflies
My kit also came with the hopper tank.
Still building. Is the kit hopper tank OK as UAT???
Mav
Old 05-20-2010 | 10:47 PM
  #897
I used a different one but it should work fine.
Old 05-21-2010 | 02:40 AM
  #898
My Feedback: (10)
ORIGINAL: PaulD
PaulD
i use 8411 , on my P-160SX flash
more then 150 flights no problems
and i fly it hard....
Old 05-21-2010 | 05:45 AM
  #899
I have the UAT that came with the FLASH and have had no problem for two years.
Both of my FLASH use them.
Old 05-26-2010 | 02:17 PM
  #900
Hi All,
I just received my Dreamworks gear for my flash. In looking it over it appears there will be some modifying to get the gear to seat and fit correctly.
Anyone who has used Dreamworks gear if you could tell me what you had to do to get the gear to fit correctly, that would help me.
Stan
