Glascat >
Glascat
Glascat
Old 01-04-2006 | 10:35 AM
  #451
Banned
My Feedback: (119)
Default RE: Glascat
ORIGINAL: Gordon Mc
Good to see that he has an extensive preflight check-list tho....
I saw that! He needs to add:
3: Check for clean underwear
4: Check that insurance is paid
Old 01-04-2006 | 10:41 AM
  #452
causeitflies's Avatar
Default RE: Glascat
C'mon guys, this thing could work really well. Though he could have saved some weight by using a lawn chair.
Old 01-04-2006 | 10:55 AM
  #453
Guest
My Feedback: (73)
Default RE: Glascat
thats around 400lbs of thrust on that pack ... hey, if a turbine fails ( which it very well might, as looks like these are USA-AMTs ) the thrust ofset between the 2 sides will flip him over .... i would actually add one of these to run the left/right side ECUs with, and that would add a little bit of compensation to any thrustofset by automatically varying the throttles ...
http://www2.towerhobbies.com/cgi-bin...?&I=LXXF88&P=7
Wojtek
Old 01-04-2006 | 10:59 AM
  #454
Banned
My Feedback: (119)
Default RE: Glascat
What about chimichangas? For extra afterburning lift?
Old 01-04-2006 | 11:17 AM
  #455
Gordito Volador's Avatar
Default RE: Glascat
Someone needs to introduce this guy to Tracey. Then he could have a suitable airframe for his project.
Old 01-04-2006 | 11:38 AM
  #456
Default RE: Glascat
Are you kidding me, this guy is Tracy's cousin!!!!!! Look on the front of the
control panel, www.skywalkerjets.com, and check out the questions on ebay.
This is good stuff!!!!!!
"good for Sky Diving" yeah, now thats a good idea, maybe him and
tracy can tandem!!!!!!!! Nothing like melted harness and canopy
before you pull that red cord!!!!!!!!
(that price on ebay is only to NAME the thing, not buy it)
Crater Maker 2 fits the bill!!!!!!!!
Old 01-04-2006 | 12:33 PM
  #457
Default RE: Glascat
SkyWalker? I think TerraImpactor fits the bill MUCH better!
Old 01-04-2006 | 12:41 PM
  #458
lov2flyrc's Avatar
My Feedback: (24)
Default RE: Glascat
Smack Pack
Old 01-04-2006 | 12:43 PM
  #459
Default RE: Glascat
hope that cracker has those RPM sensors screwed down tight!!!!
Old 01-04-2006 | 12:45 PM
  #460
Default RE: Glascat
If he wants to man-rate that booster he's gonna need triple redundant RPM sensors and everything else!
Old 01-04-2006 | 12:53 PM
  #461
Default RE: Glascat
ORIGINAL: lov2flyrc
The budget is 1.7 Mil for 100 units with 50% up front. Can you pass the background checks for clearance?
Todd,
I was born in the US, had a secret clearance in the Navy, and worked for the Federal Government for 21 years, so I don't think there will be a problem.
Old 01-04-2006 | 12:58 PM
  #462
Default RE: Glascat
If they read R/C U there may be [X(]
Old 01-04-2006 | 01:00 PM
  #463
grbaker's Avatar
My Feedback: (29)
Default RE: Glascat
You left out the part about being involved in a lawsuit against your Federal Government employer.
Old 01-04-2006 | 01:08 PM
  #464
Default RE: Glascat
OK, the only major concern on the aircraft sent to Richard was the aluminum spar tube size and location, and the hinge issue, and that he would have had to do some work to get the canopy attachments done. As I said the aluminum tube issue has been fixed for a stronger wing. I will post the photos proving there were proper hinge blocks. Mark can be honest and verify that it is the same wing, showing the holes that Richard cut.
Old 01-04-2006 | 01:13 PM
  #465
Default RE: Glascat
ORIGINAL: Woketman
What does anything on R/C U have to do with a background check?
Old 01-04-2006 | 01:16 PM
  #466
Default RE: Glascat
What about the flexible, floppy large aspect ratio outer wing panels? True, a proper spar will stiffen them a bit, but I was awfully concerned that those babies were gonna turn out to be an in-flight flutter laboratory in action! If you limit Vmax to 100 mph, it might be OK. But don't try to go faster! Now if you put some span-wise carbon fiber in the top & bottom: problem solved.
Old 01-04-2006 | 01:17 PM
  #467
Default RE: Glascat
ORIGINAL: grbaker
What does excersizing my right to take a Federal Employer to court when they have violated pay regulations, and committed a wrong against me (and others) have to do with a background check? Are you saying the courts were established for this purpose, but if you use them then they hold it against you?
Old 01-04-2006 | 01:22 PM
  #468
grbaker's Avatar
My Feedback: (29)
Default RE: Glascat
I am quite positive that they would not hold that against you.
Old 01-04-2006 | 01:26 PM
  #469
Default RE: Glascat
Yep loose an engine and you'd be like the multi engine bomber that
landed in the windshield of Frank T's rental car. (crasher 2, I think)
Thats if it got off the ground???????? The parachute thing gets me thinking,
where would you put it, what would happen when you pulled the cord?
Would you squeeze the fuel out of the tanks, get covered in Jet-A, have
a smoke on the way down and turn into a human para-flare?
ORIGINAL: wojtek
Wojtek
Old 01-04-2006 | 03:03 PM
  #470
Default RE: Glascat
ORIGINAL: Woketman
Mark,
I just went in a got the wing you are talking about and put it on my lap, with the root edge over my right leg, and the 1/3 point over my left leg, and pushed as hard as I could downward on the tip (wing upside down). The wing is 30 inches long, not including the protrubing tubes. With a metal yardstick over the surface, pushing as hard as I could, the outer tip deflected between 1/4 and 3/8 inch. I tried to twist the wing and it is VERY stiff, maybe offsetting the trailing edge at the tip about 1/16 inch, and it was as hard as I could try to twist. Keep in mind that this is the OUTER wing. At least HALF of the lift is accomplished by the wing center area (between the booms). So from the centerline of the airplane to the wing tip is about 45 inches. When a 737 flies you can see a considerable amount of flex to the wing. Granted this is not an aluminum structure, but stiffer composite, but 3/8 flex over 45 inches from center to tip is not bad at all. I suppose with more carbon fiber you could get it to 1/16 flex, but I don't think that this wing, with 50% lift accomplished by the center, and each wing panel contributing about 25-30% of lift would fail at all. Improvements can almost always be made, so I will make the future wings more bulletproof, and there has to be a certain amount of "overkill", but it can also get ridiculous.
Old 01-04-2006 | 04:05 PM
  #471
Default RE: Glascat
To all,
Please check out the new ad for the StarCat kit.
Old 01-04-2006 | 04:31 PM
  #472
Default RE: Glascat
ORIGINAL: Woketman
I think AirChair Sandpounder would be good. I think we will have a Darwin Award winner in Cable, Ohio. Looks like the main problem, other than the obvious, is his CG and Center of Thrust. Doesn't look very controllable. Hey, how about "Sooey Sider 3000".
Old 01-04-2006 | 09:21 PM
  #473
Default RE: Glascat
What new ad, where?
Old 01-04-2006 | 09:52 PM
  #474
Countryboy's Avatar
My Feedback: (25)
Default RE: Glascat
ORIGINAL: Woketman
What new ad, where?
That would be here....http://www.rcuniverse.com/market/item.cfm?itemId=147435
It's the one that has been changed for the umpteenth time. Now he is only taking deposit's and upped the price. Desperate Housewife's doesn't hold a candle to Tracy. He's still cutting you a hell of a deal if you make a deposit though.
Oh, I'm sorry Mark...I missed the
Old 01-04-2006 | 10:18 PM
  #475
Default RE: Glascat
Oh, that ad. That photo is VERY old! I love this line "CANOPY WILL BE PRODUCED WITH PERFECT FLUSH TO FUSELAGE FLAT MATING SURFACES WITHOUT EXTRA FIBER CONTENT." No "extra fiber"!!! Woj, Tracy needs you to contribute, HA!
