Reload this Page >
Comp ARF BAE Hawk build thread
Old 12-12-2012, 07:14 AM
  #976
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Default RE: Comp ARF BAE Hawk build thread
ORIGINAL: jkeze
I used a Hitec 645 on the nose gear sterring. Metal gears and enough power and fast enough.
+1
Old 12-13-2012, 06:44 PM
  #977
husafreak
husafreak's Avatar
Thanks for everyone's help. I settled on DS8711's for the elevators and DS8411's for the ailerons for appropriate power and ultimate precision. I am trying out the Spectrum (Savox) A6030 servos on steering, rudder and flaps. They are digital MG servos with 278 oz in of torque and at 68$ a pop very reasonable. They are performing well in another large jet I know of. I personally wanted digital on steering, especially if I elect to use a gyro. The JR 579 is not sold here in the states.
Old 12-17-2012, 09:59 AM
  #978
husafreak
husafreak's Avatar
Has anyone tried an Airpower EV5 sequencer in a Hawk? It is recommended by Todd at Dreamworks and has apparently had some bugs worked out so it is a solid unit now. I looked a a great variety of ways to do the gear/brakes but they all end up costing as much and being a great deal more complicated to assemble than the EV5, this on account that I want air pressure readouts, low pressure failsafe, and proportional braking. http://dreamworksrc.com/catalog/func...lve-p-756.html
Old 12-17-2012, 10:54 AM
  #979
dubd
dubd's Avatar
Eric, the EV5 unit is very popular and has been out for a few years. I have used them in almost all my jets with only one being defective. If you do a search on RCU you will find a number of threads on it.
Old 12-17-2012, 11:15 AM
  #980
husafreak
husafreak's Avatar
Sweet!
Old 12-28-2012, 11:20 AM
  #981
Zetti
Hi Guys,
just got my Navy Hawk right before christmas (ordered in november this year) and started building now.
So fare everything seems fine, but there are two things I'm wondering about:
1.) There's no cut out for the rudder servo
2.) The flap rod hole and especially the flap horn are misaligned
Since the instructions say, that this only occurs on early kits - I'm wondering how this can happen? Is it possible that CARF sold me an "old" leftover kit??? Or are these things still not sorted out, even in the new kits?
Many thanks and greetings from Germany
Stephan
Old 12-28-2012, 12:04 PM
  #982
luv2flyrc
luv2flyrc's Avatar
ORIGINAL: Zetti
Hi Guys,
Stephan
I think if I remember correctly, there's paperwork on or in the CARF box that will tell you the date of manufacture. It's on bottom of the list on contents. I don't think CARF has corrected these problems even in later runs as both my Hawks, Display scheme and Red Arrows are like this. The fixes are very easy though and not much of an issue.
Mike
Old 12-28-2012, 12:42 PM
  #983
Dave Wilshere
ORIGINAL: Zetti
Hi Guys,
Since the instructions say, that this only occurs on early kits - I'm wondering how this can happen? Is it possible that CARF sold me an ''old'' leftover kit??? Or are these things still not sorted out, even in the new kits?
Stephan
Stephan
The fins are normally cut, but if yours is not follow the pictures and put a hole in the rough centre and Dremel out to the plywood. I thought the flap horns were sorted, I'll talk with the factory and see what's up. Easy fix even if you shouldn't have to do it.
Almost no chance its an old kit!
regards
Dave Wilshere
Old 12-28-2012, 02:44 PM
  #984
Zetti
Hi Mike, hi Dave,
just looked and the quality seals say 05/2011 - so it's over a year old! Nevertheless should it be "young" enough not to have the reported issues!? Interesting that other points which are reported in the manual are okay - e.g. the double control horns on the elevator are factory installed.
So the cut in the fin shouldn't be a big deal, but cracking the flap horns makes me nervous! Should I mill the bondig first and hope that the horns stay in one piece, or is the cut meant to be breaking the horn in two and glue the upper part in again!? The later is nothing I would trust in!!!
Regards
Stephan
Old 12-28-2012, 04:43 PM
  #985
luv2flyrc
luv2flyrc's Avatar
Stephan,
Some people have moved the horn but, my "fix" was simply to "raise" the flap servo in it's pocket by blocking it up enough to move it over in proper alignment with the horn. You have to elongate the opening in the the shear webbing to allow the control rod to move over and line up with the horn as well. I hope you can follow what I am saying without a picture.
Also, I slipped carbon fibre tubes of the appropriate size over the flap push rods to stiffen them as I found they can flex under load with out the reinforcement.
Mike
Old 12-28-2012, 08:13 PM
  #986
afterburner
My Feedback: (18)
afterburner's Avatar
Stephan,
I received my Hawk last May 2012 and it was a 2010 production. I had the same issues. The cutout for the rudder is a two minute fix. The flap misalignment not so fast. I tried the "cracking' of the horn but that didn't turnout so well for me. I ended up dremeling the entire horn out and making new horns and re-seating them into the wood and then used blocking wood on each side of the new horn and aeropoxied it. It was time consuming and a little frustrating trying to get the correct shape of the replacement horns but in the end it was worth it. I also used carbon fiber tubes on all the threaded control rods for all the surfaces.
Marty
Old 12-29-2012, 02:21 AM
  #987
Stig Andersen
Stig Andersen's Avatar
Hi.
I got my Hawk kit the week before Christmas. I had the same issues as Stephan. But is was an easy fix. The Q-seal is dated 6/2011. I used brass tubing over the 3 mm threaded pushrod for the flaps.
Is there a good alternative to the sport gear from CARF?
Old 12-29-2012, 02:32 AM
  #988
Stig Andersen
Another question.
The carbon tube for the all flying elevater is oversize. I cannot find any procedure in the manual for this carbon tube. What is to be done with it?
Old 12-29-2012, 03:03 AM
  #989
fireblade5437
fireblade5437's Avatar
Stig
How much is the carbon tube out by? mm?
Mine was tight I just 'polished' with 1000 wet/dry paper
Some pics of the fittings I made for end of carbon tube also the servo mount I made out out FG board as the wooden ones in my kit.... well I would not use them for what they were intended for...
Also made bushes for the purple servo arms (Phosphor bronze) so there was zero play in clevis. Grey glue is Hysol 9461 same tear strength as 9462 but works out a lot cheaper I buy it in tubes of 200ml (400ml total)
Loctite® Hysol® 9461 A&B 400ml (451233) 1 £36.84 £7.37 £44.21
Sub Total: £36.84
Delivery: £3.50
VAT: £8.07
Total: £48.41
From site:
Description
Loctite® Hysol® 9461 A&B is a toughened, 2K-Epoxy adhesive, suitable for applications requiring gap filling and high peel strength. Ideal for bonding dissimilar substrates like GRP, SMC and composites.
This product requires: Loctite® Dual Cartridge Dispenser
Specifications
• Non-sag paste
• Heat accelerated (4 min. @ 120°C)
• High peel strength
Typical Properties
• Mix ratio by volume: 1:1
• Mix ratio by weight: 100:100
• Working life: 40 min.
• Fixture time: 240 min.
• Colour: Grey
• Viscosity: 270 Pa.s
• Shear strength (GBMS): 24 N/mm²
• Peel strength (GBMS): 10.0 N/mm
• Operating temperature: up to 100°C
Description
Code
Price
(Inc. VAT )
Est. Delivery
50ml
451231
£13.72
In stock
400ml
451233
£46.67
1 week
Alan
ID:	1834481   Click image for larger version
ID:	1834482   Click image for larger version
Old 12-29-2012, 05:34 AM
  #990
Dave Wilshere
The horn crack I literally got the horn held in some bull nose pliers, bent it the direction needed till they cracked, soaked in some thin CA and ran a bead of hysol.
The fibrous horns generally hang together.
The carbon pivot, I cut flush and pinned inside the bearings.
Dave
Old 12-29-2012, 06:06 AM
  #991
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Stig,
My tube was cut flush and pinned, it looks like an extra inner piece of plywood was added to take up the slop.
In the photos the pins are removed I need to install before the final assembly.
ID:	1834534   Click image for larger version
ID:	1834535   Click image for larger version
ID:	1834536   Click image for larger version
ID:	1834537   Click image for larger version
Old 12-29-2012, 07:29 AM
  #992
afterburner
My Feedback: (18)
I had some hardwood dowel in my wood box that was a perfect slip fit inside the CF tube. I epoxied that in the tube, cut it flush to the outside of the fuse and then pnned it inside the fuse on both sides with small diameter CF tube. I felt more comfortable drilling through a solid tube.
Marty
Old 12-30-2012, 02:15 AM
  #993
Stig Andersen
Thanks for the input. [8D]
Can anybody tell me if there is a good alternative to the sport landing gear from C-ARF. I want to do a T-45-like version of the Hawk with twin nose wheels.
Old 01-07-2013, 11:35 AM
  #994
fireblade5437
TUCSON (Stan)
Your pitot probe for your CARF Hawk is finished, will pack into a carbon tube for protection then it will be on it's way over the pond!
Alan
ID:	1837828   Click image for larger version
Old 01-07-2013, 12:52 PM
  #995
Dave Wilshere
ORIGINAL: Stig Andersen
Not really, though Jet 1A in Austria did some sets for the Hawk, Peter might be able to build you a nose unit with a twin wheel nose leg..
Dave W
Old 01-07-2013, 01:32 PM
  #996
tucson
Alan,
The probe looks great.
You are quite the craftsman.
Looking forward (No pun intended) to putting it on my Hawk.
Thank you,
Stan
Old 01-08-2013, 02:56 AM
  #997
Stig Andersen
ORIGINAL: Dave Wilshere
Dave W
Thanks, Dave. I ordered the sport landing gear from CARF. Maybe I can do something with the nose leg myself. [8D]
Old 01-09-2013, 08:08 AM
  #998
Kenrico
Kenrico's Avatar
Finally got the hawk out of the box today.
will get some pics later
Old 01-12-2013, 03:06 PM
  #999
Kenrico
Kenrico's Avatar
Started the build last night
ID:	1839625   Click image for larger version
ID:	1839626   Click image for larger version
ID:	1839627   Click image for larger version
ID:	1839628   Click image for larger version
Old 01-12-2013, 03:20 PM
  #1000
Kenrico
Kenrico's Avatar
for those who have built the Hawk, where did you route the Aileron Servo extensions? I know Dave said in front on the Spar but does that mean they would exit between the gear and spar like where we would also route the airline?
I was thinking on bringing them behind the spar (between spar and trailing edge) and then enter the center some where by the flap servo. there is also a slot there that looks like it was intended for that but not sure.
any help greatly appreciated !
Thanks!
