 Another Skymaster Viper >
Old 02-01-2010 | 11:54 AM
  #776
Carsten Groen's Avatar
Default RE: Another Skymaster Viper
Very nice Ron!
BUT, why the "Girlie power" engine ?
(I bet Sandor said something like that also )
Old 02-01-2010 | 12:15 PM
  #777
Hallo Carsten,
alomst looks like you know Sandor for a longer time, yes he also told the same about the turbine and he is not the only one.
On the dutch forum we also had that item and a few people told me that they are going to use a P200 in the Viper.
They wanted a turbine for real man. My Answer: I don't need a bigger turbine te be a man
I don't worry, it fly's with a P160 so i guess it will fly with the 18,3 kg thrust Merlin.
Regards Ron.
P.S. Oleo's looking almost as nice as on mine Viper.
Old 02-01-2010 | 12:30 PM
  #778
hehe
Yes, I know Sandor quite a bit, must have bought too much stuff from him
I'm sure that a P160SX is more than enough for the plane, I got the 200 only because I didn't have one already, so I simply had to try it
Oh yes, and then we can always make fun about it
Old 02-01-2010 | 12:40 PM
  #779
Carsten, what about the travel adjustments for the Viper.
I already asked Ali about the rudder and he told me the travel for the rudder is as much as it can get.
How much travel do you have on the alevator and the ailerons.
As much as they say in the manual or more?
Old 02-01-2010 | 12:54 PM
  #780
Duncan's Avatar
Ha ha Ron, I agree with you. Those that have gone for a 200 are compensating for lacking in other areas !!
I measured Ali's rudder movement during one of the team building sessions and he has 75mm each way
Cheers
Duncan
Old 02-01-2010 | 01:03 PM
  #781
ORIGINAL: Ron v U
Ron,
I went with the movements in the manual, I think that a little more aileron would not hurt, but didn't have enough time with the plane before the fu##ing snow came here [:'(]
But the settings in the manual is a very good starting point, you wont go wrong with those!
You are going to be very happy with the plane!
and Duncan, you are sooo wrong
Old 02-01-2010 | 01:12 PM
  #782
ORIGINAL: Duncan
Ha ha Ron, I agree with you. Those that have gone for a 200 are comprnsating for lacking in other areas !!
Cheers
Duncan
Thanks Duncan,
at the moment i programmed the ruddder with 65 mm each way, but i have room for more.
Regards Ron
Old 02-01-2010 | 01:17 PM
  #783
ORIGINAL: cgroen
ORIGINAL: Ron v U
Ron,
Carsten, thanks for info.
About the ailerons, i was also thinking to give a little more.
The 15mm as the say in the manual looks not enough for me.
Regards Ron
P.S. Duncan i agree with you, sorry Carsten
Old 02-01-2010 | 01:26 PM
  #784
dubd's Avatar
The VJ flies great with a P-160. The only difference I see with mine (P-200) and the ones with a P-160 is stronger verticals.
Old 02-01-2010 | 03:07 PM
  #785
Erwin DB's Avatar
Hello Gonzalo,
Just for your info...today I received a small package from SM with a new bottom fuel tank.
Fits perfect under the inlet ducs now.
To be honest, Skymastersservice is just fine !
Kind regards,
Erwin
Old 02-01-2010 | 09:41 PM
  #786
gonzalom's Avatar
Thank you Erwin for the info. I contacted them about this and they said it will take a while to get one.... so I am in the process of cutting mine.
Regards,
Gonzalo
Old 02-02-2010 | 03:58 AM
  #787
My Feedback: (10)
ORIGINAL: Duncan
Cheers
Duncan
sure bill , next time you need a son i guess you will have to contact me.
Old 02-02-2010 | 04:02 AM
  #788
ORIGINAL: digitech
Classic
Old 02-02-2010 | 04:34 AM
  #789
Duncan's Avatar
lol apparently it takes a real man to produce a girl
Old 02-02-2010 | 04:51 AM
  #790
Vinceyboy's Avatar
A definite "YES" on that one Dunc [sm=thumbs_up.gif]
Old 02-02-2010 | 05:10 AM
  #791
DENTO's Avatar
ORIGINAL: Duncan
ANY PLUMBER CAN SOLDER A SPOUT ON BUT IT TAKES A TRADSMAN TO ROLL THE EDGES LOL
Old 02-02-2010 | 05:37 AM
  #792
My Feedback: (10)
ORIGINAL: Duncan
i agree it takes one to make one
ladyboy!
Old 02-02-2010 | 06:17 AM
  #793
Duncan's Avatar
Is there something about your life, that you're not telling us Sandor? I thought you problems with sitting down at pampa where to do with something else
Old 02-02-2010 | 06:18 AM
  #794
Vinceyboy's Avatar
That could have been the strong curry he had the night before
Old 02-02-2010 | 06:34 AM
  #795
My Feedback: (10)
ORIGINAL: Duncan
My airvent is working flawlessly again thank you
i will take you lot on pampa,s somewhere just to make you shut up forever...[>:]
Old 02-02-2010 | 06:56 AM
  #796
Vinceyboy's Avatar
Matter of interest, what date is Pampa this year?
Cheers,
Vince.
Old 02-02-2010 | 08:05 AM
  #797
Duncan's Avatar
24th and 25th of July Vince, Natalie's birthday weekend again lol
Old 02-02-2010 | 08:54 AM
  #798
schroedm's Avatar
Dunc,
Does is surprise you that Nat's birthday keeps falling on the same date every year?! Weird huh?!!
Old 02-02-2010 | 09:44 AM
  #799
Vinceyboy's Avatar
ORIGINAL: Duncan
Damn, that's the Hastings show weekend, could be a few happy people at Pampa then, lol
and after Mark's comment, I know someone else whose flying is ruled by "er in doors" keeps getting these stunning models and can't get out to fly them
Old 02-02-2010 | 09:48 AM
  #800
Ali's Avatar
Ali
I got to fly two vipers this past weekend. One with P-160 and the other with P-200 power.
P-200 has the edge for sheer vertical power, but as I showed the 160 powered viper could easily go out of site vertical after a straight run ( Not sure how much more vertical than out of sight anyone could want )
The rest of the flight envelope the P-160 buried the P-200.
Lighter
Easier to manage the speed
Much improved slow speed handling. I could really feel the extra weight of the 200 version wanting to bite me in the same low and slow pattern that the 160 version had no trouble with.
More floaty touchdown
Much softer and less aggressive stall. Both version dropped a wing but with the 160 version I could fly out of it ( Catch the wing drop ) 200 version actually went into 1/2 a rotational spin.
Oh and of course the flight times were longer on the 160 version.
The P200 Viper was still a great plane to fly ( So dont get too despondent all you guys that have gone down that route) Its just the lighter version is that much greater.
Ask me if I would ever have a P200 in one of my vipers......... Nope!
Regards Al
P.S I forgot to mention... We were flying at an elevated field in 30 deg temps with high humidity and the Jet Cat 160 Sx didnt struggle to fly the Viper in anyway!
