 XPS 2.4 Module ?? >
XPS 2.4 Module ??
XPS 2.4 Module ??
Old 10-18-2009 | 11:05 PM
Default RE: XPS 2.4 Module ??
ORIGINAL: PaulD
Kirk,
The 12Fg and 6014 receivers is exactly what I am running. Not a single issue so far.
I just ordered one of these from SinCityJets:
http://s42221013.einsundeinsshop.de/...%3D282214%3D29
Looks like a nice simple power solution for the 6014 receiver.
PaulD
How much in $$$?
Thanks.
Old 10-18-2009 | 11:45 PM
The PowerJack 6014 unit is $100 delivered to your door. Eur to USD is killing me right now.
Chad
Old 10-19-2009 | 09:26 AM
My Feedback: (10)
ORIGINAL: k_sonn
Hey Paul,
Yes, I dd find out what caused the loss of the Starfire. It seems using a LiPo battery in the 10X transmitter causes a diode or a board or something like that to burn out, in turn causing intermitten signal loss. There is supposed to be a bulletin on the Horizon site about this but to this day I have not been able to find it. After doing a lot of research and talking to several guys, I recently purchased a Futaba 12FG FASST system to replace the 10X.
If I recall this wasn't a JR issue but a Spektrum module issue. I believe I saw the document that said not to run over 11v to the Spektrum module.
Old 10-22-2009 | 10:16 AM
My Feedback: (16)
We atteneded the Sun Valley Jet event over the weekend, and there were several people (including Woody) flying XPS 2.4GHz systems in their jets. As usual, no problems when people power their setups correctly.
Old 10-22-2009 | 10:20 AM
Who were the several people? (besides Woody and you)
Old 10-22-2009 | 10:30 AM
  #31
Jim
Is there an upgrade available for the older units?
Old 10-22-2009 | 12:25 PM
  #32
Jim Cattanach's Avatar
I used the Extreme power systems 2.4 as it was the first to offer modules & Rx's. I had lost a couple of jets on 35Mhz. I fitted it to my Avonds F15. For many flights there were no issues. As more people started to switch over to 2.4, I started to get the odd lock out lasting a split second. The lockouts became more frequent, so I ditched the system & bought a Spectrum module & Rx's. I have had no problems since.
Old 11-02-2009 | 01:03 PM
  #33
tassos p's Avatar
XPS are now focusing on EDF motors....
Apparently this FEJ electric powered F-14 is powered by their product .....
http://www.youtube.com/user/aeroRCmo.../2/hikby3dLqbg
http://www.youtube.com/user/aeroRCmo.../1/reyZrUjZxfo
http://www.youtube.com/user/aeroRCmo.../0/m63jUq0I2UE
Tassos
Old 11-02-2009 | 05:25 PM
  #34
ORIGINAL: SinCityJets
Jim, you must have forgotten to answer this question?!!!? Who were the several people? (besides Woody and you)????
Old 11-02-2009 | 06:40 PM
  #35
hcuellart's Avatar
My Feedback: (41)
I've been using XPS since they came out and never have had a problem. I do use direct lipo as power source and now with the updated version I believe now we have proven frequency hopping capability. Just as XPS has lost planes I have seen the first Futabas heat up and planes lost. I believe no single manufacturer is perfect but now most of them if not all have resolved their gripes...
I am an XPS believer, I have it on a 100cc Composite Edge converted to electric with a Hacker A150-8 on 14S pulling close to 200A, I cannot think of a system more unfriendly to receivers...
Just my 2 cents
Homero
Old 11-02-2009 | 07:12 PM
  #36
I used XPS V3 for 5 days before moving to Weatronic.
The first 4 days were fine, no trouble, the 5th day I had a lock out after take off and resulting total loss.
This occured also 1 time in the workshop, and power cycling was the only way to reset it. Not easy while in flight !
My 1 cent !
Old 11-02-2009 | 10:28 PM
  #37
My Feedback: (57)
ORIGINAL: hcuellart
Just my 2 cents
Homero
Homero,
Do you only fly at your local field or do you fly at meets or events outside your local area and state? I'd like to invite you to my field and see how you make out.
R/
George
Old 11-02-2009 | 10:58 PM
  #38
bruff's Avatar
My Feedback: (18)
I was there flying my Formost 150 EDf on XPS. Been using it for two years with out a hitch.
Bob
Old 11-03-2009 | 05:06 AM
  #39
BaldEagel's Avatar
There is no doubt that the XPS system when it first came out had serious problems, some people got the system to work, but they are in the minority, hence Graupner recalling the IFS system and refunding monies, companies like Grupner do not do this usually they issue a credit note or upgrade the system the unusual step of refunding indicates their belife that the system was not viable and contraveaned the strict "Customer use Regulations" in Germany.
The new system that does have the capability of hopping between channels I am sure is a much better system, would I buy it, NO, I do not like being used as a Development Engineer with a system that could have cost me an airframe, once bitten twice shy, in fact I now will not buy anything Graupner as they argued the case with me until others sent theirs back, I think it was the various threads and Forums that I sent links to them for that finally convinced them.
Mike
Old 11-03-2009 | 06:38 PM
  #40
True, the initial dishonesty that XPS displayed turned off many a potential customer. No matter what some of the XPS supporters say about the original system, those who have followed this closely know there were BIG issues.
It may now be a viable system, but JD urinated up-stream far too much to be trusted now. If you have any sense, avoid XPS like the plague. Especially with the solid performance of JR/Futaba/Weatronics/Jeti 2.4 systems, why in the world would anyone with a valuable model even consider taking a chance??? Sure, some will say "I know this guy that had a JR go in and this guy that had a Futaba go in". Of course, feces happens. But that in no way implies you should trust XPS!
Old 11-03-2009 | 06:49 PM
  #41
ravill's Avatar
Just don't do it.
Raf
Old 11-04-2009 | 08:13 PM
  #42
Gordito Volador's Avatar
ORIGINAL: Woketman
Ditto that Wocketman!
Old 11-05-2009 | 02:11 AM
  #43
hcuellart's Avatar
My Feedback: (41)
Hi George, I mostly fly local and do fly a lot in Mexico as I live most of the time over here. It would be quite difficult to transport my large electric over to Afghanistan, but with my current system I do feel comfortable. I am not supporting in any way the way it came out in the beginning, fortunately for me, in the fields I flew they took too much time to do the change so 2.4 wasn't flooded at all, I don't know if this contributed to my success... I do not know Jim Drew and his obscure past or doings, but service from him/them has been just as any other company would be.
Truth be told, I do like to experiment on new things so I jumped right in a couple of years ago, recently, I have been tempted by all these negative comments on the forums to change, but the fact is that I have not lost a single plane and I don't think I will loose one with the new version and running direct lipos on my planes (voltage seems to be important to the XPS system).
ORIGINAL: George
ORIGINAL: hcuellart
Just my 2 cents
Homero
Homero,
R/
George
Old 11-05-2009 | 04:11 AM
  #44
BaldEagel's Avatar
The environment I fly in is criss crossed with high power transmision and power lines, the UK has very crowded airwaves and therefore is a faily harsh environment for any system in a built up area, we fly on an estuary that has communication masts on either side of it, IFS /XPS just would not work on my site, the lock out where consistant and total, ordianary PPM has glitches, PCM seems to be reliable, but all 2.4Ghz except IFS seems to work OK, I have not tried the new system from Graupner nor intend too, as I have said before once bitten twice shy.
Mike
Old 11-05-2009 | 11:08 AM
  #45
My Feedback: (57)
ORIGINAL: hcuellart
ORIGINAL: George
ORIGINAL: hcuellart
Just my 2 cents
Homero
Homero,
R/
George
Homero,
Thanks for your honest reply. I only work in Afghanistan, I was talking about flying in Va. Beach. [8D]
It just seems the system works good in only a few places and if you happen to be in one of those places; all is well. My problem is that I travel and fly at many different places and can't trust the system to work at all of them without thoroughly testing at each location. It didn't work at my home field (NALF Fentress), so I lost complete confidence in it. It be interesting to see how the new systems acts, but I won't be trying this time.
Sounds like it is working well for you and hopefully continue to do so. Good luck and thanks again.
George
Old 11-05-2009 | 03:27 PM
  #46
hcuellart's Avatar
My Feedback: (41)
Thanks George!! I wish you happy flights too!!
Old 11-05-2009 | 03:39 PM
  #47
hcuellart's Avatar
My Feedback: (41)
ORIGINAL: BaldEagel
Mike
Mike totally true, unfortunately for JD and XPS, once bitten twice shy!! I have read many many posts like yours and it seems when it first came out it wasn't tested as it should have... Now XPS has to pay the price and will have to clean up their act or it may be their demise.
Presently XPS has the idea of getting a new system which will transmit in the actual 2.4Ghz but will have a secondary or dual system on the 900 Mhz bandwidth lets see how that goes and when it goes... People, including myself, have been asking about their 12ch receivers with no luck on release dates, he says he will release them jointly with their 16ch ones .
But well, he is trying to keep up and that by itself is outstanding given all the problems he had to face at the beginning.
Old 11-05-2009 | 04:03 PM
  #48
jonkoppisch's Avatar
My Feedback: (162)
Maidened another new jet on 2.4. Perfect flight. I have several flights on it now in the last couple of weeks....
On FASST!!!
Old 11-05-2009 | 07:00 PM
  #49
BaldEagel's Avatar
ORIGINAL: hcuellart
ORIGINAL: BaldEagel
Mike
The problems that he faced he made for himself, he brought an item to the market that clearly did not do what it said in the advertising blurb, it was supposed to hop to a different frequency withing the 2.4Ghz band if it detected interference, it was proved it did not work, hop or reject interference, IMO he does not deserve to have my buisness or anyone elses for that matter, I do not like being lied to in any type of advertisment especially in a circustance that could cost me many thousands of my hard earned cash, my advise to all is not to trust XPS or the Graupner IFS system it does not deserve to be on the market, there are others out there that did not lie on the performance of their systems and have addressed any problems found after bringing them out, they have been up front with the problems encountered and addressed them XPS have not even admitted that a problem existed, that in itself is enough to convince me they cannot be trusted.
Mike
EDIT: The Futaba 12FG is 12 proportional channels and two switched or if you fit the MPX-1 system to channels 11 & 12 you can get an extra 16 channels yes thats right a total of 26 proportional channels and two switched.
Old 11-05-2009 | 07:20 PM
  #50
I feel much the same as BaldEagel about XPS: we were all definitely lied to. Avoid XPS.
But in fairness, Futaba had the heat problem and has not admiited squat about it. But they did not lie and deny it either. And yes, I am flying FASST! It works VERY well.
