Reload this Page >
CARF CT-114 Tutor 2.6m Build thread
Old 04-25-2014, 09:30 AM
  #876
PaulD
My Feedback: (39)
PaulD's Avatar
Stan,
if you mean this one then yes:
http://www.towerhobbies.com/products.../futm0830.html
What I like about it is the simple set up - just one gain trim pot. Mounts on its side to get the correct alignment for rudder control and orientation is dependant on the servo direction/linkage which you will have to figure out on your jet.
I can dig up pictures but will be next week as I'm travelling until Sunday.
There are others that are similar that should work fine as well, we just found this one simple and compact.
PaulD
Old 04-25-2014, 10:40 AM
  #877
tucson
Thanks PaulD,
Pictures of your trailing link install would be great.
Stan
Old 04-25-2014, 01:53 PM
  #878
sc0tt
My Feedback: (61)
sc0tt's Avatar
Are the Behotec main struts 170mm?
If yes, then they should be the same as used on the CARF Lightning.
Old 05-04-2014, 12:11 AM
  #879
flesche
flesche's Avatar
I took a cuple of pic when flying yesterday I had to mod a little bit on the 170mm trailing links
ID:	1992338   Click image for larger version
ID:	1992339   Click image for larger version
Old 05-04-2014, 04:21 AM
  #880
Gonzalo38
Gonzalo38's Avatar
The landing gear looks great. What were the mods done to it ?
Old 05-04-2014, 05:07 AM
  #881
sc0tt
My Feedback: (61)
sc0tt's Avatar
I think fleshe modified the strut doors and cover plates due to the front pivot link on the Behotec trailing legs. On my lightning I just added a small piece to cover the pivot link. The only other way is to make the strut door wider.
Name:	MLG doors closed.jpg
Old 05-04-2014, 07:24 AM
  #882
flesche
flesche's Avatar
If I remember right 170mm is a little bit to long I think we shorten it 6-8mm
Old 05-04-2014, 09:10 AM
  #883
Gonzalo38
Gonzalo38's Avatar
Thanks for the info guys.
Yesterday I was flying my Tutor and every time I fly it, it reminds me why it's one of my favourite planes.......
Both of my Comp-Arf Tutors are equipped with the iGyro from Powerbox and that's really helping protecting the landing gear in crosswind landings. Ou club can get extremely windy and a little help is always welcome.
ID:	1992470   Click image for larger version
ID:	1992471   Click image for larger version
ID:	1992472   Click image for larger version
ID:	1992473   Click image for larger version
Old 05-19-2014, 05:49 PM
  #884
tucson
I am in the process of putting a cortex gyro in my Tutor.
Trying ti figure out if the tray in the cabin is level; with the straight flying attitude of the Tutor.
Any ideas where to place the Gyro?
I guess the motor mount should be a good place to start but need to keep the gyro next to my receiver in the front cabin.
Open for ideas.
Stan
Old 05-19-2014, 11:40 PM
  #885
Tuggs
Tuggs's Avatar
Hi Stan,
My Cortex is placed below the cockpit seats - this is where my powerbox and the receiver sits as well. It doesnt really matter where you put the Gyro, just pay attention to the right orientation.
T
Old 05-20-2014, 03:56 AM
  #886
Gonzalo38
Gonzalo38's Avatar
Mounting instructions of the Cortex don't mention that the Gyro needs to be levelled during flight. The only important things are orientation and using the supplied mounting pads.
My iGyro is mounted under the seats and works perfect.
Old 05-20-2014, 06:12 AM
  #887
tucson
Originally Posted by Tuggs
Hi Stan,
T
Hi Tuggs, and Gonzalo,
I have another Cortex mounted in an Osiris with a lot of flights.
It is mounted level with the airplane also in the proper orientation.
I was under the impression that it had to be mounted level with the airplane.
The tray in the cabin in my Tutor is not near the level of the motor mounts which by the way are not level with each other.
Maybe I am wrong in thinking that the cortex has to be mounted level with the flying attitude of the airplane.
I will call Danny at Espirit who is the US distributor and post what he has to say.
Stan
Old 05-20-2014, 06:22 AM
  #888
Tuggs
Tuggs's Avatar
Stan
Yes
It doesnt have to be level with the straight flying level whatsoever. It only needs to show in the right direction as in the picture above. I am sure there is a maximum angle which you should not exceed, since you have to use the software if you want to mount the cortex in a different orientation. Just apply common sense when you mount it Btw, you shouldn't mount it next to the turbine. The bottom of the fuselage just below the cockpit is fine, assuming that your receiver is located there as well, I mean you're limited to the cable length anyways ,right?
cheers
T
Old 05-20-2014, 06:53 AM
  #889
tucson
Yes
cheers
T
I just got off the phone with Danny at Espirit.
He said it is not critical but it should be mounted as level as possible to the flying attitude of the airplane.
I was not going to mount it back in the engine compartment I was just using the engine mounts as a level place in the airplane to compare to the level attitude of the board in the cabin.
I guess it is not as critical as I thought it might be.
Best Regards,
Stan
Old 06-06-2014, 09:28 AM
  #890
didiwatt
My Feedback: (38)
Dave:
I am in the process of installing a JetCat 180 with smoke in my Tutor. I am a newbie with regards to smoke on a turbine. I have the spray tube from JetCat which looks exactly like the one in your install pictures in the manual. Do you have any pictures of your finished install of the spray tube. JetCat has nothing in their manual. Is it critical where the spray is directed and location of the spray outlet? I assume you bend the tube to locate the spray outlet where you want it.
Paul
Old 06-06-2014, 02:49 PM
  #891
PaulD
My Feedback: (39)
PaulD's Avatar
Paul,
Everyone has their own idea of how the smoke tube should be installed. My personal experience is with the tube bent so that the exit is 1.5 - 2" behind the nozzle and the tube exit well into the nozzle stream pointing at center. If it's too far out from center, the exhaust from the turbine tends to blow a lot of the oil away before it's burnt into smoke. You need to experiment with your own installation a bit for the best results. Also recommend the mix is set up so the smoke comes on at about 1/3 throttle minimum and increases from there.
PaulD
Old 06-09-2014, 12:39 PM
  #892
didiwatt
My Feedback: (38)
Thanks Paul:
I found a drawing in the installation instructions for the jetcat smokerpump. It pretty much shows what you said, 25 to 50cm from the end of nozzle and 5 to 10mm into the nozzle stream and spraying toward the center.
Didi
Old 06-09-2014, 01:23 PM
  #893
Dave Wilshere
It seems to work well 1 3/4 to 2" behind. Monitor the ingress of oil, the unducted install can (does) suck smoke residue into the fuselage and I found my tail area wood soaked with oil.
Dave
Old 01-03-2015, 08:50 AM
  #894
sharam
sharam's Avatar
Well, thanks to dubd my Tutor maidened this week. It looked absolutely majestic - large maneuvers, precise turns, just awesome. Powerplant is an evojet 160. Planning on installing a smoke system. CG was right on the manual setting, throws as well. Thank you Comp-arf!
Old 01-03-2015, 09:14 AM
  #895
Helijet
It truly is an amazing aircraft. It has become my goto jet. Its an adrenalin rush every time I take it out!
Cheers
Dean W.
Old 01-03-2015, 09:29 AM
  #896
sharam
sharam's Avatar
Cheers
Dean W.
Just noticed you are in Kamloops. Been there a few times on my way to Blue River for some heli-skiing! If the Tutor were not so big, I would bring her with me next time! Should be there again in March this year.
Old 01-03-2015, 09:32 AM
  #897
dubd
dubd's Avatar
Shahram, it was a pleasure to fly! Great presence in the air. Looking forward to seeing it at the field again. Congrats!
Old 01-03-2015, 11:07 AM
  #898
Helijet
Mike Wiegele Heli Skiing. Outstanding scenery!
Enjoy the trip up this way..its cheaper than it has been the last few years as well.
Dean
Old 02-10-2015, 08:00 AM
  #899
nobbybasher
I have recently purchased a tutor I have some issues with the kit but they are being resolved by my rep and CARF.
Old 02-10-2015, 08:41 AM
  #900
Gonzalo38
Gonzalo38's Avatar
What are the issues you have faced with this model ? I currently have two (2) CARF Tutors and no issues at all with both of them. Landing gear could be a little bit more robust but besides that, the airplanes are holding quite well and no major problems during assembly.
