RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Official HPI MT2 Thread
Old 02-19-2006 | 12:29 AM
  #4826
Default RE: Official HPI MT2 Thread
i have a quick question about mounting my new engine. ok on my os .15 cv-x i notice that there is a nut on the crankshaft. now when i put my flywheel and clutch pads and stuff, how do i secure the clutch bell down? because i notice on my stock t-15 there is a screw that screws into the shaft with a washer in front of it that holds the clutch bell in place. is this nut on the os crankshaft the same thing? hope i said this right, let me know if it's confusing, i'll try to explain better.
Old 02-19-2006 | 01:50 AM
  #4827
Actually there is a full size Savage. Check out the video here : http://www.hpi-europe.com/show_video...=en&videoID=65
ORIGINAL: CS MT2
ORIGINAL: friday13
ORIGINAL: CS MT2
They are both 1/10, but it depends on what they scale it from. For example, a 1/10 vw beetle is going to be much smaller than a 1/10 4 door 4wd truck.
Are you going by diecast models? Not the same for these RC trucks. There is no full scale SAVAGE or REVO that exists.
Where do you get the idea that I am going by diecast models? Wanna bet there's no full scale savage or revo? Far as I know, there isn't a full size revo, instead a t-maxx and a savage. Although they came after the rc versions, they do exist none the less.
Old 02-19-2006 | 08:48 AM
  #4828
Ight guys i have just had a whole new like carb block put on my mt2. and it starts perfect 1st time. but when rev it goes tiny bit and spits quite bit of fuel but u can full throttle it and goes dead slow. only tried this 2wice or it would damage engine. so is it just a case of puttin it on a block and tuning the low speed needle to get it moving quicker then move onto the high speed needle??? by the way using a t-15 engine.
Old 02-19-2006 | 08:49 AM
  #4829
mt2nitronut's Avatar
redfox if i,m not mistaken all stock parts t 15 should be transferable to the os 15 ,fly wheel etc etc.should be able to change over to os
ORIGINAL: redfox03
Old 02-19-2006 | 08:50 AM
  #4830
blowerz you start with the upper needle first,then lower,upper needle counter clockwise
open it up 1/8 turn at a time till it runs smooth if that doesnt work turn opposite way,lower needle on side of carb the bigger screw i have always left at stock setting flush with outside edge, sounds like it is set to a rich setting no worries of hurting it then ,
ORIGINAL: Blowerz
Old 02-19-2006 | 09:52 AM
  #4831
yer the lower needle is nice and flush ok thenw ill adjust the upper needle 1/8th at a time to get ti going. will do that one day during week coz bit busy at mo plus it poring down with rain. hopefully that does the trick.
Old 02-19-2006 | 09:57 AM
  #4832
like i said if it doesnt work one way try opposite thats all did,upper needle ,hope it helps and you get it up and running
might go rippin later on today temp is starting to rise -11 now
ORIGINAL: Blowerz
Old 02-19-2006 | 10:01 AM
  #4833
Ive given up with aluminium gear, just ordered heavy duty ones for the back!
Old 02-19-2006 | 10:58 AM
  #4834
umm can someone tell me how to fit a throttle return spring plz?
im pretty sure it has been asked before but i cant see it anywhere. Thanks.
Can i use the optional linkage set with the two holes to fit one side of the spring with? if that makes sense.
Old 02-19-2006 | 11:22 AM
  #4835
if it is a rotory carb the return spring will not work only on slide carbs it will ,i tried but ,what i thaught was working it really wasnt.fail safe is the better way to go
ORIGINAL: MT2Owner
Old 02-19-2006 | 03:44 PM
  #4836
MT2Owner theres instructions on how to up a throttle return spring on the associated site
http://www.teamassociated.com/racerh...ret_spr1BW.jpg
Old 02-19-2006 | 03:48 PM
  #4837
started my mt 2 for the first time today in the basement (with the windows open and hepa filter on full blast) since my clutch bell broke 2 weeks ago. i finally got hear how my new tsais badboy exhaust sounds. all i have to say, is it sounds like a beast! also put some new fuel line on and fuel filter. put on more fuel line so it doesnt stall so quickly when it's upside down. too bad i cant go outside today. way too cold, it's like 15 outside with a windchill of like -10 or something. look on my face when i first heard the pipe --------> [X(] . i called my friend who just got a traxxas nitro rustler (his first nitro rc) yesterday and told him the pipe sounds awesome.
Old 02-19-2006 | 05:05 PM
  #4838
Hey, i'm allways rolling my car! and of coarse it stalls, I never thought of getting longer tubing, thanks lol, is there a maximum length or sumthing? or could you just go wild lol? Thanks
ORIGINAL: redfox03
Old 02-19-2006 | 06:10 PM
  #4839
adz06's Avatar
i made my fuel tubing longer mines about 6 inches n runs fine
Old 02-19-2006 | 06:35 PM
  #4840
can someone tell me if you can add reverse to the mt 2
Old 02-19-2006 | 06:49 PM
  #4841
and_des's Avatar
no
Old 02-19-2006 | 09:37 PM
  #4842
i added good 6-7 inches of tubing. worked pretty good too. emptied the fuel out the tank, then started the engine to burn the rest out. took about i'd say a good minute or two for it to finally shut off. i wonder what would happen if you did go wild with it and put more than the 6-7 inches i put on there? you just gave me an idea too. but also, i got different color fuel tubing. i got neon green going to the carb and neon orange that connects the tank to the pipe. looks pretty cool, and got the red fuel filter on there.
ORIGINAL: cjl91000
ORIGINAL: redfox03
Old 02-19-2006 | 10:32 PM
  #4843
ORIGINAL: CS MT2
ORIGINAL: friday13
ORIGINAL: CS MT2
WHOA there! Don't get all wilded up. I already know about those monster trucks you posted. "Find me a REVO monster truck!" And then prove to me that the RC REVO is a 1/10th scale as Traxxas claims. Well?..... Not possible is it!?
Calm down.
Old 02-19-2006 | 10:43 PM
  #4844
ORIGINAL: CS MT2
ORIGINAL: friday13
ORIGINAL: bradley_wrench
its the same with the tmaxx. it is considered a 1/10 scale but its nearly the same size as a savage. I think the reason they scale it 1/10 is because of the size of the stock engine. the revo and tmaxx both come with a .15 which i think may class it lower, im not for sure though. I could be wrong but thats just my opinion
CORRECT!
Traxxas and everyone else rate the scale of their vehicles based on the potential stock space for the engine.
Unless you can show some sort of info for this, then I don't see how you can be so sure. Because of that, I say INCORRECT! I tried to give the simplest example possible to explain difference in size of scaled vehicles, but I guess some people have to read too much into it instead of reading it for what it is to get the explanation. Since that wasn't easy enough to understand, I will go further into explanation and example. If what you say about the potential space for an engine is true, then that makes the mt2 a 1/8 scale. I say this because I have a 1/8 engine, savage's s-25, in my mt2. If you look at a scale example, the mt2 matches very closely to a single cab ford ranger with the short bed. Here come the specs, and what is in parenthesis is a simple 1/10 conversion of what it would be in full size. MT2: Length 17.4" (174" ) Ranger: Length 189". MT2: Height 6.5" (65" ) Ranger: Height 66.2" MT2: Wheelbase 11.75" (117.5" ) Ranger: Wheelbase 111.5". MT2: Ground Clearance 1.5" (15" ) Ranger: 7.7" at lowest point, rear axle. The clearance is different due to the mt2 being fully independent suspension and the ranger having a solid rear axle as well as the mt2 having a higher clearance, in scale, for performance benefits. This will also influence this last spec which is width, since the suspension arms are made alot longer to compensate for performance, so I will go by the body width, which is the width of the chassis and all the components that fit on it. MT2: Width 6.4" (64" ) Ranger: Width 69.3". Although some of these specs may seem a little far off, for instance the total length, if you really think about it, that is very close. 15" difference is nothing at all, and really not worth me mentioning, but I just thought I would just for the sake of knowing that I realise this difference and understand that it is really miniscule. After all this, I regret to say that the most likely judgement when putting a scale number to it, the end result is ultimately up to the manufacturer regardless of numbers. I think they may start off with an example full size vehicle just to get the base numbers, but then tweak them to make everything they want to fit, the way they want to fit it.
With that being said I applaud your usage of a measuring tape and a calculator. Before we go any further let me tell you that if I in any way offended you - I apologize. Unless I'm reading your posts incorrectly. I'm getting the feeling that you felt my post to be attacking.
To address this current post you posted with the dimensions... in the automotive world 15" is A LOT! That is 3 inches over a foot.
In general, "to scale" means exactly that.
A diecast or RC should be to scale to the real size of the vehicle its being referred to.
This whole REVO being a 1/10th and the SAVAGE being a 1/8th is nothing but a farce! I do not condem the REVO - I love it. Although, I feel its a cope out for Traxxas to claim the REVO to be a 1/10th scale - the truck is practically the same proximity size of a 1/8th SAVAGE 25.
Let's move on to something else.
Old 02-19-2006 | 10:46 PM
  #4845
ORIGINAL: redfox03
RIGHT ON redfox!
I'm getting the cold winter blues as well up here in Canada.
CAN'T WAIT TO RUN MY MT2 AND REVO!
Old 02-19-2006 | 10:59 PM
  #4846
So...if I add extra fuel line it will help with stalls due to roll overs? I was wondering how to fix that b/c I roll all of the time.
I'm starting to make my titanium parts tommorrw, I'm gonna do my front lower arms first and the the rear. Im also gonna see if I can make some titanium c-hubs without using a CNC machine.
Old 02-19-2006 | 11:44 PM
  #4847
i know how ya feel friday. i just couldnt wait. i also cant wait to race my friends new rustler he got. it's some decent weather coming in this week, so i might just get to run it. 36 on thursday, and that's my next off day. finally get to test it out with the new exhaust and 12t clutch bell in the open.
ORIGINAL: friday13
ORIGINAL: redfox03
RIGHT ON redfox!
Old 02-19-2006 | 11:45 PM
  #4848
yep, shouldn't stall out with the extra fuel line. it'll still be fuel in the line so it gives you time to get to it. tested it out today when i started it in the basement. ran for a about a 1 and a half or two with just the fuel that was leftover in the fuel line.
ORIGINAL: GottaMX
Old 02-20-2006 | 12:00 AM
  #4849
bradley_wrench's Avatar
the fuel tubing on mine is about 12-14 inches and it runs fine, just make sure your return line is a little longer too and you will be ok. It lets me run for about 30 seconds upside down without stalling.
Old 02-20-2006 | 12:01 AM
  #4850
Thanks Redfox/Bradley Wrench
Need some creative help here. Now that I have started to make my custom titanium parts I need a project name, I'm going to engrave whatever name i choose onto a front tubular bumper. Any name suggestions?
for consideration my goals for my MT2 are: custom made titanium parts that I will make at work, big block, i going to set my new chassis plate up to accept the savage 3 speed with reverse, rc innovations supercharger, and more. Thanks for any suggestions.
