RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Official HPI MT2 Thread
Old 10-22-2006 | 10:12 AM
  #8176
Default RE: Official HPI MT2 Thread
I use the RD Racing Starter box to start my 1/8th, 1/10th losi, Truggy, and of Course Revo.
If your having problem with starter being stiff try pre-warming the motor to get it started for the first time until its good and broken in. This will make your life waaaaaaayyyyy easier when it comes to fresh motors and Pull starts.
IMO
46u I added a bunch of shots to my gallery too
Old 10-22-2006 | 11:08 AM
  #8177
46u's Avatar
46u
But changing all the pegs and motor around is a pain particularly if you run more then one class on the same day. I think I will just get one for each vehicle or at least have 2. Will check out your gallery, I just wish they let us post more the 10 pictures in it.
Old 10-22-2006 | 11:12 AM
  #8178
46u's Avatar
46u
You got any close up pictures of your trucks?
Old 10-22-2006 | 06:17 PM
  #8179
murawskiallen's Avatar
right before my truck runs out of fuel and dies the engine revs way up..i was wondering if this was normal or if i should do something about it, i think its because right befor it runs out of fuel alot of air mixes with the fuel in the fuel lines, but i could be wrong...any suggestions???
Old 10-22-2006 | 06:23 PM
  #8180
46u's Avatar
46u
Yes this is normal as it leans out when running out of fuel.
Old 10-22-2006 | 06:26 PM
  #8181
ok thanx that makes me feel better
Old 10-22-2006 | 06:29 PM
  #8182
i have a mt 2 rtr...i have had it for about 5 months and i have a os 18 tz motor in it....it is wicked fast but my rear diff keeps stripping....i have the hardened one and i put a new one in today and it stripped in 3 tanks its kinda angering. would aluminum diff cases prevent this because i think the torque fromt he motor pushe the case apart a little giving it a bad gear mesh?
Old 10-22-2006 | 06:38 PM
  #8183
46u since you have a savage also i hope you can help me, ive stripped out two stock 52 spur gears...is there somthing i can do as a good fix to this problem?
thanks for your help
Old 10-22-2006 | 06:58 PM
  #8184
46u's Avatar
46u
ORIGINAL: mxdragon
I have the 18 TZ in mine and do not have a problem. Are you shimming them when you put them together?
Old 10-22-2006 | 07:01 PM
  #8185
46u's Avatar
46u
ORIGINAL: tattguy12
Are they striping or melting? The reason I ask is the only spur I had a problem with in over 6 gallons of fuel was when I was breaking it in and it melted do to the sorry stock composite clutch shoes slipping so bad it got the CB so hot it melted spur. I have at least 6 gallons on the spur I am running now. Setting mesh is critical as well.
Old 10-22-2006 | 07:02 PM
  #8186
uhh...well they came with shims three of them and i put them in between the bearing and the final gear....is there anywhere else i need to shim them? my from diff hasnt stripped once either its kinda strange.
Old 10-22-2006 | 07:09 PM
  #8187
46u's Avatar
46u
You can all so shim the pinion gear. You want as much tooth engagement as possible with out bind. I have only had my TZ in for a couple of months but have been running my MT for 4 years with MANY gallons throw it I only striped my spider gears once and to date never striped my ring and pinion gears.
Old 10-22-2006 | 07:11 PM
  #8188
i'll try putting a shim in the pinion gear and hopefully that will fix it. thanks for the help.
Old 10-22-2006 | 07:15 PM
  #8189
how can I tell if the gears are binding too much?
Old 10-22-2006 | 07:16 PM
  #8190
there melting.
Old 10-22-2006 | 07:30 PM
  #8191
46u's Avatar
46u
ORIGINAL: mxdragon
When you get done putting the Diff together they should turn free and have a very small amount of gear lash.
Old 10-22-2006 | 07:32 PM
  #8192
46u's Avatar
46u
ORIGINAL: tattguy12
there melting.
Is the truck new and have the stock composite clutch shoes?
Old 10-22-2006 | 07:34 PM
  #8193
its an older 21 but the shoes are still stock,o.k everything on the truck is stock..lol
Old 10-22-2006 | 07:36 PM
  #8194
could the slipper clutch being to tight cause them to strip this quickly as well?
Old 10-22-2006 | 07:47 PM
  #8195
46u's Avatar
46u
I have run mine with the slipper tighten all the way up for over 6 gallons and most with the Savage run it that way. If it is not new I am guessing it has run with out problems with the stock shoes. So I am guessing you are not getting the mesh and aliment correct. Sorry to say some have problems with this. How long have you had the truck? Did you buy it used? Do you loctite the motor moung screws?
Old 10-22-2006 | 10:43 PM
  #8196
ELITE913's Avatar
i dond need a list of parts, but roughly how much would it cost to convert an rs4 3 evo to an mt2 rtr?
Old 10-23-2006 | 12:28 PM
  #8197
if i had to guess i think it would probably be around $50 if you want to get all plastic parts...for all alloy parts now thats a diifferent story
Old 10-23-2006 | 12:31 PM
  #8198
but im not completely sure as to what all the parts needed are
Old 10-23-2006 | 01:08 PM
  #8199
46u's Avatar
46u
Will cost a good bit more then $50 I would guess around $100 to $150. Shocks alone would be around $35.00. Then wheels tires A arms, shock tower, drives where the wheels go on. knuckles, drive shafts so it very well could even be more. I think you would be much better off buying the SS kit unless you can pick the parts up REAL cheap.
Old 10-23-2006 | 01:12 PM
  #8200
well ill give u a list of what i think u will mainly need.
front susspention arms
rear susspention arms
front and rear dog bones
front and rear drive axles (not sure if the rs4 ones have the right inside diamiter )
2.2" truck wheels and tires
front bumper
heavy duty front and rear diffs ( u will need them at some point anyway )
front and rear diff axles (not sure if the rs4 ones have the right inside diamiter )
and i think thats all
