RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Official HPI MT2 Thread
Old 12-06-2006 | 03:10 PM
  #9751
djheptic's Avatar
Default RE: Official HPI MT2 Thread
no exhaust yet. dirt bonez tyres should be here friday. a quick question on glueing. how do i stop them from going lumpy around the edges and get a nice smooth edge with no lumps around the tyre
Old 12-06-2006 | 03:20 PM
  #9752
46u's Avatar
46u
Should have gotten the Pro Line Bow Ties as they last MUCH longer then the HPI Dirt Bonz! Make sure you stay off the pavement.
Old 12-06-2006 | 03:21 PM
  #9753
nickrummy's Avatar
Are the dirt bonez the tires that come on the 18ss? If so, you better never run those things on pavement. They will get chewed up REAL fast.
as for glueing. I rough up the bead of the tire with a dremel. I just put the tire on the rim and push the lip of the tire to the inner most part of the rim. That way you can put a bead of glue all the way around the rim. then just pull the tire bead back onto the rim lip that has glue and make sure it seats in nicely. This usually gives you enough time to get the tire situated before the glue dried.
ORIGINAL: djheptic
Old 12-06-2006 | 03:26 PM
  #9754
djheptic's Avatar
ok thanks guys, and im not botherd about the tires wearing down, i got them in a sale from jespares 10% off all tires untill friday ill keep off the pavement wink wink lol
Old 12-06-2006 | 03:28 PM
  #9755
46u's Avatar
46u
Yes they are the ones that come with the 18ss.
Old 12-06-2006 | 03:35 PM
  #9756
A distant friend of mine doesn't have an rcu account but was wondering if there are any off road tracks around New York City
Old 12-06-2006 | 03:45 PM
  #9757
46u's Avatar
46u
Did you check in the RC Regional Racer and Basher thread? All so check here.
http://rcvehicles.about.com/gi/dynam...track_srch.asp
Old 12-06-2006 | 03:49 PM
  #9758
46u's Avatar
46u
Here are the tires I run and last much longer then the HPI Dirt Bonz.
http://www2.towerhobbies.com/cgi-bin...?&I=LXDX79&P=0
Old 12-06-2006 | 04:31 PM
  #9759
ORIGINAL: 46u
I was born in Pittsburgh PA one 1214 Macon, Ave and in 1968 moved to Macon, Georgia.
i was born in ambler pa
  #9760
is it comin for the clutch bell to brake in two well it happend to me
Old 12-06-2006 | 04:37 PM
  #9761
46u's Avatar
46u
Do you have the RTR with the stock CB? If so yes I have heard of this happening many times and I recommend to up grade to the race CB with the much better bearing set up.
Old 12-06-2006 | 05:07 PM
  #9762
djheptic's Avatar
I'm not to keen on my break. Can you get alu disk break?. I Think its my pads that need tightening
Old 12-06-2006 | 05:12 PM
  #9763
hey im thinking of painting my own body.... any suggestions for colors that gowell with red??
Old 12-06-2006 | 05:34 PM
  #9764
djheptic's Avatar
red and.....ORANGE lol! personaly i think red and lime green would look cool. Talking of painting my shell is coming tommorow hopefully. when its done i shall post some pictures
Old 12-06-2006 | 05:46 PM
  #9765
yea might be interesting... im gonna do like stripes straigh down the middle like dodge vipers
Old 12-06-2006 | 05:55 PM
  #9766
djheptic's Avatar
oh cool, copy 46u hehe
Old 12-06-2006 | 06:36 PM
  #9767
46u's Avatar
46u
ORIGINAL: djheptic
If you are running the stock RTR you need to change to one of these. I have the first one and it works great but just ordered the seconded one to see how it does. Mine is not ware out but where it goes on the cup is getting quite waddled out. You can all so get a higher torque servo.
This is the one that came with mine works great
http://www2.towerhobbies.com/cgi-bin...7&I=LXM738&P=K
I am going to try this one as it is so much cheaper.
http://www2.towerhobbies.com/cgi-bin...&I=LXFYP8&P=ML
Old 12-06-2006 | 06:45 PM
  #9768
Well I've just finished taking the roto-start off my MT2 and replacing it with a pull-starter. A bit more work than I expected as I had to remove the rear diff and wheels to get access to unscrew the roto-start, but I suppose it's a good thing as I familiarise myself with the car.
Hopefully having a pull-start will mean less hassle in future, as carrying that heavy roto-starter around was a real pain.
Old 12-06-2006 | 06:50 PM
  #9769
46u's Avatar
46u
Why didn’t you just take the 4 screws out holding the engine and pull the whole engine off?
Old 12-06-2006 | 07:00 PM
  #9770
nickrummy's Avatar
I'm running the second disc you have posted. Works great for me! I have never used the first one. I got my truck used and the disc was shot so I bought the one you linked. Took a little while to wear in but it is great now.
ORIGINAL: 46u
ORIGINAL: djheptic
Old 12-06-2006 | 07:02 PM
  #9771
Because I'm a bit afraid to mess about with the engine. Maybe because I'm a newbie to all this I'm being a bit too careful, but at least I've familiarised myself with the back end of the car now, which will be handy if I need replacements or if I crash the car in the future.
Old 12-06-2006 | 07:11 PM
  #9772
nickrummy's Avatar
woulda been WAY easier that way.
ORIGINAL: 46u
Old 12-06-2006 | 07:12 PM
  #9773
nickrummy's Avatar
you're gonna have to do it some time
Just take not as to how it came apart, remember to use loctite on any screw that goes into metal and read up on adjusting gear mesh. It is a little over whelming at a first glance but it is knowledge that needs to be known when owning a nitro vehicle.
ORIGINAL: arapoda
Old 12-06-2006 | 07:38 PM
  #9774
46u's Avatar
46u
On the RTR there is not a whole lot of gear mesh you have to worry about as the engine has the mounts make on it and there is very little if any adjustment. The only engine I ever had set up that way was on my Rush and it was so many years ago I forget if there is even any adjustment to the mesh.
Old 12-06-2006 | 07:53 PM
  #9775
nickrummy's Avatar
oh does the RTR just use the 4 fixed motor mount locations? The motor mounts that are builing to the motor's case? I was thinking it used the cheap aluminum motor mounts that use the slot in the chassis.
