RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Official HPI MT2 Thread
Old 05-09-2007 | 04:39 AM
  #14626
kakavia's Avatar
Default RE: Official HPI MT2 Thread
If I use a 25% fuel in my t-15 engine, will I destroy it?
Now I am using 16% (for only 1 lit).
I have also found a 15% very cheap. Should I go for it?
What percentage do you suggest for my t-15?
Old 05-09-2007 | 09:37 AM
  #14627
46u's Avatar
46u
With the T 15 I recommend 20% nitro fuel with no more then 12% oil content. I would not go over 20% nitro. Unless you race I do not recommend over 20% nitro as it does not make that big of a difference for bashing. Sorry to say the T-15 is not the best engine but have fun with it and save up for a different one like the OS CV-R or RX!
Sorry guys I cannot take credit for the above post on shock springs, as it is a cut and past job. Easier to cut and past then type it all out. But either way very good reading.
Old 05-09-2007 | 11:17 AM
  #14628
murawskiallen's Avatar
yes it was very good reading, what site did you pull it from??
ORIGINAL: 46u
Old 05-09-2007 | 03:00 PM
  #14629
46u's Avatar
46u
Very good site! I printed it and it took around 60 pages.
http://home.scarlet.be/~be067749/58/
Another good source of information on set ups is go to Xray’s web site and look at their manuals. Besides Xray having some of the best vehicles out there they all so have some of the best manuals as in them they have a lot of information about set up which most manufactures neglect.
Old 05-09-2007 | 06:19 PM
  #14630
hey guys thanks for all the feedback. judging from what 46u said i think i am going to go soft in the back and medium in the front
Old 05-09-2007 | 06:51 PM
  #14631
46u's Avatar
46u
ORIGINAL: crohbober
That will be a good place to start. Let us know how it goes and good luck. I have round 4 of the Georgia Championship Series Saturday and will not be able to go up Friday to practice or spend the night do to my youngest daughter’s graduation from college.
Old 05-09-2007 | 07:20 PM
  #14632
hey 46u congrats.. and ill be going to the hobby shop this saturday and run it the same day. ill let u guys know how it handles
Old 05-10-2007 | 03:14 AM
  #14633
Yes... I agree with you 46U.... However I've been using 25% and it works pretty well though I'm not a racer.
Old 05-10-2007 | 10:16 AM
  #14634
hey everybody well im new to this forum and i also have an hpi MT2 .18ss, but right now im having trouble trying to build the diffs and to shim them correctly, and i was wondering if anyone could help me out on giving me advice on building them, because this is the first time i tried building diferentials before.
and if anyone could let me know on a good engine to repalce the stock .18ss and a good pipe also.
Old 05-10-2007 | 11:05 AM
  #14635
lewis_lfc's Avatar
the os 18 cvrx is the engine which most people tend to go and the tsais rear exit pipe get good reviews
Old 05-10-2007 | 11:40 AM
  #14636
hey people
i haven`t posted here in a while. just reading and lurking. my mt2 ss is running great.
so great i`m thinking about getting other one and make the one i got now for street use only.
my question is. does anybody know what parts i need to make the street one a two speed.
i would really like tower hobby part numbers. i still got the 18ss engine in it and if i got the two speed
for it would i be able to use it with a diff engine?
thanks.
Old 05-10-2007 | 11:58 AM
  #14637
how much backlash should there be when the diffs. are put together and shimmed right? and how many shims should there be between the final gear and the bearing?
Old 05-10-2007 | 02:12 PM
  #14638
there should be about 1mm of play.
most people had to use 2 shims but a few used three.
Old 05-10-2007 | 09:16 PM
  #14639
46u's Avatar
46u
I shim both my ring gear and pinion gear. I shim mine where I get as much tooth engagement with out bind.
Old 05-11-2007 | 09:23 AM
  #14640
when you say you shim both the ring gear and pinion gear where exactly is that? and how many shims do you put in it to get max tooth engagement without any bind?
and 46u maybe you can help me, when i hold the diff case and the 38t gear together and spin the cup joint the other turns in the oppisite direction, but when i put the four screws in the diff assembly i dont get any diff action is it suppose to move freely when i turn the cup joint because its sort of difficult to move the cup joint and get the other to move the opposite direction. and i was wondering if you can give me a little help on this problem of mine thanks.
Old 05-11-2007 | 09:43 AM
  #14641
46u's Avatar
46u
OK you have two gears that are called final gears. You have one that you put the drive cup on for the center dog bone (drive shaft). This is the pinion gear. Then you have a gear that attaches to the diff cup is the ring gear. As far as how many shims I cannot say as different ones take different amounts of shims. I have had to use anywhere between 1 to 3 shims in each location.
When you say you put your diff together and spin the cup it is not real smooth this might be so but with out being able to check it my self cannot tell what is OK and what is too much bind. New diffs do not turn as easy or smooth as when the get a little wear (seat in) on them. But just guessing more then likely you are OK.
Old 05-11-2007 | 09:51 AM
  #14642
alright thanks that explained alot. im going to try setting those shims tonight and see how much engagement i get.
do you know any good engines and pipe i might be able to use because im thinking about replacing the stock .18ss. any info. would help.
Old 05-11-2007 | 01:08 PM
  #14643
46u's Avatar
46u
Not trying to start anything but watch out as big brother is watching. No I do not have anything for sale. I sell my stuff on ebay when I am selling. All I have is a set of alloy monster truck wheels on it under vld35.
Old 05-11-2007 | 10:03 PM
  #14644
Do they make any kind of 17mm wheel adapter so you can run buggy wheels? Its for the lightning gt10 which looks the same at the wheel.
Old 05-12-2007 | 11:17 AM
  #14645
kakavia's Avatar
I own the HPI Glow Plug Ignitor w/AC Charger and I would like to know the charging time (no manual was included).
Thanks.
Old 05-12-2007 | 04:05 PM
  #14646
definently get the os 18cv-r engine and for a pipe get either tsais rear exhaust or THSracing pipe, i run this engine with the tsais rear exhaust and it performs like a champ, i have never used the THSracing pipe but i have heard nothing but good about it even rumors that it is better than the tsais but they are both about the same price so take your pick
ORIGINAL: MT2_RACER86
Old 05-12-2007 | 06:22 PM
  #14647
ORIGINAL: kakavia
Thanks.
u should charge it for atleast 5 hrs. overnight is the best just plug it in be4 you sleep ans it will start your car all day for one day..
well im having a problem of my own. well i just got my glow plug and shock oil and started my car. it started like a champ. then it didnt start so i charger the glow plug igniter more for an hour and a half. then it stil didnt start so i put it to factory settings. it still didnt start. i looked at the glow plug ignitor and found out that the batter was loose from the shaft. so i tightned it and started the car. now it wont stay in idle i always have to start pushing the trigger lighty and when i let go of the trigger it dies.. anyone help plz
Old 05-12-2007 | 07:31 PM
  #14648
you need to slightly tighten the idler screw ( the one with the sprint on it), if you have a rotary carb then you should look into the carb inlet and tighten it until the opening is about as big as the thickness of a credit card, if you have a slide carb then the opening should be about 1mm
Old 05-12-2007 | 07:51 PM
  #14649
it doesnt have anything with the tuning??. because right after i put it to factory setting it wont idle. anyway ill try that.. how much should i tighten it 1/8??
Old 05-12-2007 | 09:28 PM
  #14650
depends on what engine you have check your manual
ORIGINAL: crohbober
