OFFICIAL HPI RUSH / EVO THREAD
#2252
TX
yeah probably, check the slipper and see if its loose
ORIGINAL: subsy
mine revs too much and doesnt go anywhere, is this the slipper needs tightening?
#2253
well today i went to start it, started, few seconds and it stopped same again for the next few goes and then it wouldnt start, any ideas?
#2254
TX
sounds like your engine needs to be retuned
ORIGINAL: rushevoross
#2255
ORIGINAL: subsy
#2256
TX
yeah iv herd that gluing the hexes works really well if thats whats wrong
ORIGINAL: dmr bikes 4 eva
ive had this problem its your wheel hexes youll probally need a new set of wheels and hexes just checke everything else before going and buying some new wheels if it is your hexes then when you get a new set of wheels glue your new hexes into the wheels to prevent it happing again or you could buy the proline dish wheels with just a pin slot in the back plese check everything first though
ORIGINAL: subsy
#2261
yup that can be a problem loads of guys jus slam a more touque high horspower engine in there trucks and dont get that the stock truck is designed aroun the stock engine then they are in the hobby shop once a month buying the same parts rather than spend the money in the first place and upgrade the gearbox etcoh and yeah the mt2 hexes have worked well for me and there worth it.
#2262
Hi, i have a rush evo. that i blew the engine in . engine was on last leg when i got it. i was wanting to get a .18 engine for it.any suggestions on what one and what parts are needed to do this. i herd the os. .18 cv-rx with 11 j carb is good . anybody know if the stock header and pipe off the t-15 will fit on this?
#2263
did u mean this [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGGP8&P=]tower hobbies[/link] if so i have never seen one but yes i think so however i think it was some time ago someone said thed had problems actually fitting it in the car i had to cut a bit out of my chassis brace to fit my nosram and ive heard trannys can go with the 18 o.s's i would sugget a smaller os even the 12 can strip spur id see what some of the other americans think is good as i can only advise on what we can get in england
#2269
high end .18s are too much for the rush, let alone big blocks.
Spent about an hour fixing my rush on the weekend, got it all working but in my excitement forgot to put the securing pins on the battery compartment (school boy error). Needless to say they fell out at full throttle and my rush drove square on into a wall at 40MPH+. Bent the chassis, snapped a hinge pin, snapped a shock shaft, tore the servo saver to bits and I think my £30 hitec server is dead too..
won't be doing that again..
![Frown](https://www.rcuniverse.com/forum/images/smilies/frown.gif)
#2270
unlucky beleve me its not a new one i did it with my sst about 2 years ago and needless to say carbon fibre chassis and topdeck and suspension tower +curb=1 month without car
#2271
it's the second big one I've had, both for just being really careless and stupid... Luckily the rush does take a lot of abuse, if the servo is ok it's a £10.00 fix which isn't too bad.. £10 and a hammer on the chassis..
