RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Nitro Rush Won't Move
Old 11-22-2008 | 03:14 PM
amf66's Avatar
Default Nitro Rush Won't Move
I have a Nitro Rush that, ever since I went off a jump and landed on the throttle, won't move. The engine will start fine but it just won't move and it makes a grinding sound when I rev it up and it won't move. The spur gear isn't stripped and it moves freely. Could this be a tranny or diff problem? I hope not, since the tranny is a pain to take out! [8D]
Old 11-22-2008 | 08:46 PM
Montana Mike's Avatar
Default RE: Nitro Rush Won't Move
WOW !!!!!! Nice to finally chat to someone with a Rush. Very rare find. Is the flywheel spinning?
Old 11-22-2008 | 08:48 PM
amf66's Avatar
Yes, the flywheel spins, the clutch bell spins, the break and the spur gear spin.
Old 11-22-2008 | 08:49 PM
Are the dogbones in the carriers?
Old 11-22-2008 | 08:55 PM
amf66's Avatar
Yes
Old 11-22-2008 | 08:56 PM
Tranny and differential are the same thing in this rig. That would be my guess. And yes it is a bit of a pain to remove it.
Old 11-22-2008 | 09:02 PM
Sorry I should rephrase that. The transmiion would be my guess. If the clutch bell, spur gear, and brake pad are spining and the dog bones are in the carriers, then my guess is it is something in the trasmission. And yes it is a pain to remove. You basically have to disassemble the whole rear end to remove the tranmission.
Old 11-22-2008 | 09:28 PM
amf66's Avatar
ORIGINAL: Montana Mike
Yeah, I've been there. I had a runaway about a year ago straight into a curb and the chassis was bent. I had to order a new one and basically take the whole thing apart and put it back together!
Old 11-22-2008 | 09:32 PM
where do you get your parts for it at?
Old 11-22-2008 | 09:46 PM
amf66's Avatar
Anywhere I can find them. I mainly use Hobbys Etc Ohio and Tower Hobbies. RC Planet has parts too.
Old 11-22-2008 | 09:53 PM
I haven't drove a Rush yet. I am in the procees of building two of them. One is mainly going to be stock and the other one will not be. Neither one is ready to run yet though. Hopefully by spring I will have them finished. Then me and my son can go rip it up somewhere. Hobby Etc Ohio is getting out of HPI parts, just a heads up.
Old 11-22-2008 | 09:54 PM
amf66's Avatar
Why aren't they ready to run?
Old 11-22-2008 | 09:57 PM
Neede a motor for my sons and electronics and bodies for both of them.
Old 11-22-2008 | 10:02 PM
amf66's Avatar
I have the HPI T3.0 in mine and it runs great and has good run times. I would recomend that or an SH .18. They are great engines and easy to tune. Heres the link for the SH .18: [link]http://server.sohouniverse.net/~himotora/shopping/pgm-more_information.php?id=597&=SID[/link]. What price range are you in for the radio?
Old 11-22-2008 | 10:11 PM
NOt sure about the price range yet. Suggestions?
Old 11-22-2008 | 10:17 PM
amf66's Avatar
Well it's kind of hard to suggest a radio with out a price range. What do you want? 2.4? AM? FM?
Old 11-22-2008 | 10:23 PM
Cheap and simple, my son is 7. As far as for mine, I think a friend has one that he is going to give me a good price on, not to sure what it is though. If he says it is good , then it must be type of deal. Looking for as small of an engine as possibly. Dont want to much power in my sons hands yet.
Old 11-22-2008 | 10:57 PM
Probably just a 2 channel am radio
Old 11-23-2008 | 12:56 PM
SO is your tranny fried?
Old 11-23-2008 | 01:22 PM
46u's Avatar
46u
If you need diff gears get the MT2 gears as they are much better then the Rush gears. On the Rush it is very important to set the slipper clutch properly or you will mess up diff gears and the main gear in the transmission. I have a Rush but have not run it in years. Just have TOO many toys. [X(]
Parts are only going to get harder to fine for the Rush as it has been discontinued for a while now.[]
Old 11-23-2008 | 01:26 PM
DO you have an MT2?
Old 11-23-2008 | 01:42 PM
46u's Avatar
46u
No I have a MT 1 3/4 and use the gears out of it in my Rush which is the same diff gears as the MT2. The Rush gears are pot metal and the MT gears are MUCH more durable. But you still need to have the slipper set properly!!!!
OK for those that have never heard of a MT 1 3/4 I will enplane. My MT 1 3/4 started life as a MT1. I have up graded it to a MT2 SS other then the chassis, upper deck and the radio box. I even put the 100cc fuel tank in it that HPI said will not fit a MT1 but it will with some minor modification. I have MANY RC vehicles. I sold some so I only have around 25 not counting my few air and water RC vehicles.
Old 11-23-2008 | 09:48 PM
amf66's Avatar
Montana Mike, a good idea for your son would be to get a good .18 engine (SH .18 or T3.0) and also get an FM radio with servo end point adjustments such as this one: [link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHBB5**&P=0[/link]. Then you could adjust how fast the truck can go with the end point adjustments, and as he becomes a better driver you can let him go faster. I think that might be more practical than buying a less powerful engine in the first place.
Old 11-23-2008 | 09:55 PM
46u's Avatar
46u
SH based engines are very good engines. They are made by Golden Lion and include but not limited to SH, XTM, LRP, Sportsworks and more. If you are going to stay in the hobby consider a 2.4GHz radio as they are way better then AM or Standard FM.
Old 11-23-2008 | 09:57 PM
ThunderbirdJunkie's Avatar
I'm banking on the idler gear being stripped.
Or you could not have to work on it, and send the whole truck to ThunderbirdJunkie
