Vortex F3A build thread
#176
It's true, i find it difficult to capture the looks of the plane with photos, there is too much distortion cased by the camera lens. Sure, you can post the 3D PDF if you want
#177
3D PDF of the Vortex . The 3D feature works in adobe acrobat reader DC . You have to confy in the data and click the blank image to activate the feature .Left button presed to roll and tumble ,scroll to make even bigger.
flyintexan (05-15-2020)
#178
Hello everyone,especially Alex!
Given, that Alex generously shared his files for cutting Vortex,
l also decided to make it myselfe. The cut is in the works and l look
forward to it in a few days...
Br Robi
Br Robi
#183
Again, beautiful work Alex. I myself found that in designs such as this (I collaborated with AC Glenn on the "Ariel") the fuselage starts to become a flying balsawood forest. The surface area of such fuselages becomes an immense number. My latest fuse design project is showing a surface area of 1.471 sq meters (with canopy but no rudder). Creating the sub structure with enough minimal integrity for building and a skin that will carry most of the flight loads is a daunting task in designs like these.
-Mark
-Mark
#184
Please keep us updated with your progress and post some images when you can.
My Vortex is almost 2000 km away and it will be a while before i can work on it again, so the next best thing is seeing others building one.
#185
-Mark
-Mark
It's true, the structure gets very complex for a plane of this size, only designing it took me around 5 months in total. But it's something very satisfying to see the puzzle of small parts come together just like i imagined and developing from thin fragile balsa sheets into a massive powerful plane.
I like composite construction too, but it's not something i can do by myself at home, you need a fully equipped workshop for that. I saw your new Revo project has a composite fuselage and i'm looking forward to seeing more images of its progress.
The following 3 users liked this post by Alex Voicu:
#186
robin24 (05-15-2020)
#189
Hello!
So l am about as far away as your plane...
After consulting with my friend Marko, who has vast experience with the F3A, we decidet to build the aircraft with fixed wings,
( taking into account the angles planned ) and with the classic back engine mount. According to Krille s experience, however, the current firewall would be left at 0 degrees.
The cut is made of light balsa...
Br Robi
Br Robi
#190
The 3D PDF format doesn't support textures, but i found a way to export the model in 2 different paintschemes for your viewing pleasure
The files are too large to attach here, so i uploaded them on Google Drive.
When opening the 3D PDFs, an Options button will show up in the top bar, just click it and choose to trust the document (any of the 2 options there). You may need to click on the screen one more time for the model to show up.
For best results, do the following:
- Right click on the screen, go to Viewing Options > Use Perspective Projection
- Right click on the screen, go to Viewing Options > Lighting Schemes > CAD Optimized Lights
- Right click on the screen > Full Screen Multimedia
You can use Left mouse button to rotate the camera, Ctrl + L Mouse to pan, and Shift + L Mouse to zoom.
If the model is not displayed correctly, right click on the screen, go to 3D Preferences, check box labeled "Enable double-sided rendering".
https://drive.google.com/open?id=1jz...t29n40I15RKgHa
https://drive.google.com/open?id=1YQ...irkSXX_1iMJXYK
#191
Hello!
The Wortex is cut out. Now l am wondering if anyone has a bill of materials made?
How many pieces of balsa 2mm, 4mm, 6mm ,8mm, 10mm do l need? Maybe Alex?
Br Robi
Br Robi
#192
Obviously for a 500x200mm balsa sheet you need to cut a 1m sheet in half and join the 2 pieces together with CA before laser cutting.
All you need to do is to explore each material folder and figure out the number of 1m long sheets needed.
The flat areas of the fuselage (vertical side walls) are made of 3mm balsa, and these are included in the laser cutting drawings.
The curved areas of the fuselage (turtle deck, belly pan, fin, etc.) are covered with 2mm balsa and these are not included in the laser cutting drawings since you need to manually cut and adjust them for a perfect fit. You need around 17 sheets of 2mm balsa (1m long) to cover the whole fuselage. Another 16 sheets of 2mm balsa are needed for the wings and 6 for the stabs, so in total 39 sheets.
robin24 (05-17-2020)
#193
#195
Alex Voicu
Thankyou very much for shared this plant i love this plane for long time i searching he for make i'm very happy for this
i have one question on folder laser cutting have much files what which necessarily i need use 3mm 10mm 1.5mm
i want make using 3mm but i need cutting all files on folder? i not understand well what i need use can u help me? for me use 3mm i need cutting only all folder 3mm? and have two folder BF and SF i will need cutting all folder on laser 1mm 1.5mm 2mm 3mm 10mm?
#198
The purpose of these tabs is to keep the parts attached to the balsa sheet, otherwise it is easy to loose some parts. You can easily cut these tabs with a cutter and detach the parts from the sheet when you need them.
#199
Alex Voicu
The laser cutting files are grouped in folders depending on the materials used, you just need to go into each folder and count the number of balsa sheets needed. Some sheets are 500x200mm, which means you need to cut a 1m long balsa sheet in half and join the 2 pieces together with CA adhesive before laser cutting.
The 3mm balsa sheets are mainly used for the fuselage, and the 2.5mm balsa is for the wings and stabs, but you need to cut all the sheets for a complete model. Maybe you can cut the 6mm and 10mm balsa parts by hand, since there are only simple rectangular shapes with a centerline (used for wings, stabs and rudder hinge lines).
AndersonR (05-25-2020)
