Electrified Partner
#126
My Feedback: (7)
AL
Hi Tony,
Thanks for the update on the electric Partner. I looked on the Hacker website and could not find the new 90 amp controller. What is the part number they sent you? Am I correct in saying if you run the 22x12 prop you will pull 65 amps and still be safe using the master 77 3p opto controller with no overheating problems. Have you now gone back to just running the 22x12 prop? Will running the 24x12 prop with the C50 14XL motor be ok as long as you are using the new 90 amp controller? With the new 10s3p pack, are they two TP5700-5S3P packs and are you using two chargers when recharging them between flights? Thank you for your time in answering my questions as I am trying to gather info on what is currently working for electric pattern.
Scott
Scott
#127
My Feedback: (92)
Not sure on the # for the 90 amp controller. I believe it is the 90 acro or something like that. A call to Hacker would straighten that out.
I believe if I had never put the 24-12 on the model I would have had no problems with the 77 controller. But the new 90 is a much better controller with some nice features, so I would recommend it.
Even with the new 90 amp controller I would not recommend using the 24-12. It is too easy to get the motor too hot and demagnetize it. That is where all my problems as noted started. So I'm stayong with the 22-12. Frankly, the performance is excellent with that prop.
The packs are exactly as you stated, and I am using two Orbit chargers.
Hope this helps!
Hope this helps!
#130
Tony (or JAS),
Please comment on the consistency of the throttle response for your set-up (viz. discharge curve) throughout a flight. I have been doing some experiments with an electrified H9 Funtana (Hacker C50-10L, TP 7600 5s4p ~9C batteries, etc.) as a preliminary step toward deciding on a e-powered pattern model. I find a noticeable change in throttle response with this set-up over the course of an ~8 minute flight (comparable P-05 fly time with glow, anyway) that I would find undesirable in a pattern set-up. There is enough power throughout the flight, but you need more throttle stick to get the same vertical performance after ~20% of the capacity has been utilized. After that point the response is consistent over a larger range of the remaining capacity.
Regards,
Andre'
Regards,
Andre'
#131
My Feedback: (92)
Hi Guys,
Andre',
I truly have not found what you are describing. Not with my Partner or with my Funtana S40. I am using the new 10s3p 5700's in the Partner now, and they work the same as my older packs. In fact, I find the power to increase as the packs get warmer during the flight. I try to warm the packs up prior to a flight by leaving them on the dash of my van in the sun. If the packs are cold at the start of a flight the power will be a little down until they warm up.
One of the things that has amazed me about the electric power is how consistent it is during a flight.
byoung466,
I did have a cell go bad on a pack last weekend. It was one of the new 10c packs from TP. They told me to keep the loads and charge rates low for the first few cycles to break-in the packs, and I thought I was doing that, but the demagged motor condition I described earlier was really loading the packs too high. I have sent the pack into TP for repair.
Cell life is still yet to be really determined. I have maybe 60-70 cycles on a single pack, far less then what they should do. So it will be a while before I know if they will do the expected 400-600 cycles.
Niall,
Sorry, I have not measured the incidences. I initially put them on the marks that are on the fuse. But I have adjusted them some during trim flights. So I really don't know the exact measurements.
Hope this helps!
Andre',
byoung466,
Niall,
Hope this helps!
#132
Tony,
What kind of spinner and adapter are you using?
It seems that the adapter shaft comes with the Hacker motor is a bit short for using Tru-Turn double jam prop nuts.
Thanks in advance.
LoTOM
Thanks in advance.
LoTOM
#133
My Feedback: (92)
LoTom,
I don't know if your's is different then mine, but I'm using a Tru-Turn spinner and adapter nut. The shaft is plenty long, in fact, it is almost too long.
Hacker did change the prop adapter with the "C" gearbox. Maybe that is the difference?
#134
Tony, did you ever consider gearing down the motor (not sure if this can be done with the Hacker) and using the bigger prop again? That way you would get back to where the system is not overloaded... while keeping the benefits of the bigger prop.
David
David
#135
I had a flame out this past weekend at the Temple contest. My Eclipse will need some fuse repairs to the pipe floor and the landing gear blocks. I've reviewed Tony's pictures for the motor installation. It looks like I can convert to a Hacker C5014XL electric drive with minimal modifications. I can easily modify the landing gear block to lower it for a 22" prop. I have few questions.
1) what is your typical right and down thrust angles when using the APC 22" E props?
2) what is the best type of connecter to use for the batteries and speed controller?
3) what is the delivery times for the motor, speed controller and batteries?
I would like to convert the plane in time for the Nats.
Thanks - Steve
Thanks - Steve
#136
My Feedback: (92)
Hi Steve,
Here are some answers. Hope this helps!
1. I would start with whatever the original thrustlines were. I built my Partner to the nose ring and have had to make no changes.
2. Deans Ultra Connector. I solder the motor directly to the speed controller and then have connectors between the ESC and batteries.
3. The motors and controllers can be very spotty. I have had a C50 14XL Acro and the 90 amp controller on order for over a month. Thunderpower batteries have been pretty good. I've never waited over two weeks for them. They are in the middle of some changes so availability may be a little slow.
I have 170 flights on the partner now and I still love it. Haven't worn out a servo pot yet!
#139
Tony,
Looks like I am taking the electric plunge. I am converting a glow engine Eclipse 2M pattern plane to an electric with a Hacker C50 14XL motor and will be using two (in series) Thunderpower 5s3P 5700 LiPo batteries. What is the best field charger to use? Also I plan to power the charger with a 120v to 12v power supply. I would like to charge both packs at the same time. What is the best power supply for charging two batteries. This will help me get more practice flights in a flying session.
Steve
Steve
#140
SK, CANADA
Steve, without actually using any of them or having any first hand knowledge, in my research I found that a pair of Astroflight 109s was the cheapest way to go. You can go with the more expensive chargers like the Orbit and Schulze, but you only gain easier firmware updating, more volts and/or amps that you won't need with those batteries, and computer interfacing. I'm also fairly certain Tony has already discussed his choices in chargers somewhere on RCu.
#141
The astroflights are prob the hottest charger, if you can find them in stock. 8 amps and up to 9 cells, charges lithiums only. Schulze's most economical charger is only 5 amps but will charge several differnent types of batteries, but is also harder to use, where the astro is more plug and play. Plus the astro's a lot less cost. You'll need 2 chargers, chargeing the packs seperately as 5 cell at 5.7amps. Cosel power supplies work well. You can only find them on ebay now for $24, 13 amp. Light Flight RC sells something similar for a couple dollars less. You have to add your own power cord, but for the money they're a good deal. Orbit, I don't know much about them.
Re read Tony's post #125. Of all the tips he's given us all, this is the best post he's made for someone new getting into electrics.
#142
Tony,
I have mounted the Hacker C50 14XL engine in my Eclipse. I have two cheek cowl air entry openings in line with the motor. I seem to remember you had overheated one of your engines. Would you recommend I install air deflector baffles to direct the air across the engine? By the way, I did block off the chin cowl air entry in an attempt to insure incomming air was inline with the motor from the cheek cowl openings. I have also ordered a temperature gun. What is the maximum temperature of the motor you would feel is appropiate? It is in the 90's here in Houston.
I have attached a picture of the plane before the chin cowl modifications.
This thread has helped me a lot. I hope to start another thread on my Eclipse electric conversion project. I am just waiting to get everything finished and get in a test flight.
Steve
Steve
#143
swk551, that eclipse loks very similar to my smaragd, what weight did your's come out at, I'm hoping mine will be under 10lbs, but definately under 11lbs. I'm using a 10s2p pack, so I'm hoping that will produce a light plane.
tonyf
I've mount the motor to the nose ring of my plane, hope it's strong enough, however have you put any form of soft between the motor and fuse. I've been thinking of putting some innertube im between just to dampen the noise from the gearbox.
tonyf
#144
Sorry I have not received my TP6000 10s3p batteries yet. But if thier estimated weight is right, I hope to come in at 10#-14oz. I did mount my motor to a nose ring in the plane very similar to TonyF's arrangement. I use a rear motor support almost identical to TonyF's.
#145
ORIGINAL: TonyF
David
#147
My Feedback: (92)
Hi,
I'll try to answer all the questions.
Steve,
I overheated a motor running a 24-12 prop, which is too much load on the motor. However, I would be concerned about trying to cool the motor with just the cheek cowl inlets. I am now using a 3" spinner on the Partner which opens up a gap between the fuse and the spinner, letting air in around the spinner. I also use the chin cowl inlet with a baffle to direct the air up to the motor. I have had no motor temp problems with this arrangement even on 95 -100 degree days. Too much cooling is always better then too little. I would try to run the motor no more then 150-160 degrees.
foofydoo,
I think you might have real longevity problems with the batteries running a 2P pack. What is the total capacity of that pack? If it's 4000 mah you'll be depleting it to it's max nearly every flight, not good for the packs. Also, current draw may be too high. Just seems a little too much on the edge. Also, I looked at the pics of your motor installation. Using a firewall and a solid front nose ring will greatly reduce the cooling to the motor. You may have overtemp problems. Keep a close eye on that. You can look at the beginning of this thred and see my mounting arrangement. It is shock mounted.
David,
I think you should clean and regrease the gearbox after 50-75 flights. I had an idler gear bearing go bad in the original gearbox after about 150 flights without cleaning, so I think 50-75 would be a better number. Other then that, the gearbox has been great. It really is a very well built unit. Just keep track of the orientation of the idler gears and the little washers when you disassemble the box. It needs to go back together correctly.
Hope this helps!
Steve,
foofydoo,
David,
Hope this helps!
#148
hi tonyf
haven't cut out any holes for the motor yet, will be the standard holes in the nose, and then the fire wall will have big hole so I can remove the motor, might even put a scopp on top above the motor.
the packs are 5000mah flightpoweer packs, they are 14c and peak at 20c, so they should be ok. they use them in the 3d helicopters, the big current eaters and they're fine in them.
how have you shock mounted it.
#149
Hello.
Do you recommend/need to cool down the batteries after flights, before they are put on the charger?
I have two large lipo packs, 10s2p Irate (4400 mAh total) and 10s3p TP (6000 mAh). After a flight, it takes at least 15 minutes for these packs to cool down to near ambient temperature. I have a cooling tube with a 12V fan that I used to use for charging NiCd batteries, should I start using this before charging?
(The batteries do not heat up at all during charging, so it would just be to get the temperature down as quickly as possible after flights, before charging.)
Magne
Magne
#150
CA
Magne
since Lipos fly best when they are 120 degrees, I don't see why you need to have to cool them to ambient. I don't. I use 10s4p and 10s3p packs. Because they are the new ThunderPower 10c packs they go into the plane hot (sitting on the dash) but come out at around 110. I just put them right back on the charger.
-- Kyle
-- Kyle
