Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
 Black Magic v2 builder's thread! *Updated* >
Old 02-04-2006 | 01:46 PM
  #101
MHester's Avatar
Default RE: Black Magic v2 builder's thread! *Updated*
I already won the race [8D]
Give it time, the longest anyone has had one has been a few weeks, and it takes a little time to get going.
More content later, I'm in the stages of finishing 4 of these things. Sanding is my life right now, 16 hour days.........
-Mike
Old 02-05-2006 | 12:45 AM
  #102
handglider's Avatar
My Feedback: (23)
I guess I am second??
Old 02-05-2006 | 01:00 AM
  #103
MHester's Avatar
I think I see a problem with F2 Dean......other than that it looks sweet. F2 is upper left corner..
-Mike
Old 02-05-2006 | 01:04 AM
  #104
MHester's Avatar
Oh yeah what's that bottle down there? Heineken is the official beer of Black Magic Construction. Although tonight it's Pepe Lopez...
-Mike
Old 02-05-2006 | 01:14 AM
  #105
MHester's Avatar
Wing adjusters
I have a method of doing this that works pretty darned good.
First, if you made that template and cut those holes in the fuse sides, you're in great shape. If not, do it now.
Sand your wing tube socket flush with the fuse sides.
Put some pieces of phenolics around 2 of the adjuster pins.
Elongate the rear holes as shown.
Install the wing, and insert the adjuster pins with the phenolic in the front holes (still circular at this point). This should set the wing exactly where you want it incidence-wise.
make sure your rear adjuster pins are centered in the adjusters. Install them through the holes and tack glue them with thin CA.
I use a 90 degree head on a dremel, with a drill bit installed. Now just punch the holes where the screws go through.
Remove the area of balsa around the hole with a piece of sharpened brass tubing. This provides relief for the screw head.
Now remove the wings, install the screws and nuts with loctite.
Put the wing back on, and this time repeat the process for the front adjusters using your installed rears to hold the wing in place.
Piece of cake, done.
ID:	402159   Click image for larger version
ID:	402160   Click image for larger version
ID:	402161   Click image for larger version
ID:	402162   Click image for larger version
ID:	402163   Click image for larger version
Old 02-05-2006 | 01:23 AM
  #106
Hey I take third then
But It wont let me upload the pics for some reason
Troy
Old 02-05-2006 | 02:13 AM
  #107
handglider's Avatar
My Feedback: (23)
Hi Mike and everybody,
It's been a long day starting with building the building table. I now have the most awesome 4 x 8' MDF table supported on really nice and stright 2x4s. I was able to finish the table quickly, trim out all the fuse former templates, then trim out all the balsa and lite pky formers. Mike I see my problem, it looks like F2 is supposed to be all lite ply. It was really a fun day, got a lot done. Hope to get the fuse sides cut and a start on the sheeting....
Mike I do have a number of questions: I will try an post them to this list... instead of just calling you...
My beer choice tonight was Imperial Stout, brewed in Athens, GA. Hen - but I will pick up some Heineken on the next beer run!
THANKS Mike for the AWESOME BLACK MAGIC!!
It's 2 am and I am ready to crash, I'll type more in the morning....
later all, Dean
Old 02-05-2006 | 02:16 AM
  #108
handglider's Avatar
My Feedback: (23)
It's late, I can't spell well right now, or upload....
here are the pics I tried to post....
ID:	402190   Click image for larger version
Old 02-05-2006 | 01:39 PM
  #109
MHester's Avatar
also don't cut that middle section out, it's all one piece except for the top curved part, which overlaps.
-Mike
Old 02-05-2006 | 02:11 PM
  #110
rmh's Avatar
rmh
Sure nice to see someone doing a plane from scratch.
When I look at some of the RTF stuff going for many thou -I don't know whether to laugh or cry.
Old 02-05-2006 | 07:00 PM
  #111
handglider's Avatar
My Feedback: (23)
Hello Mike and everyone,
I had a guest in the airplane factory today, Jim Ivy came by and got me going on my wing and tail sheeting. Things are starting up here, after the superbowl I am going to get back on the fuse formers... I'll write more later after the game...
ID:	402692   Click image for larger version
Old 02-05-2006 | 09:47 PM
  #112
patternflyr's Avatar
My Feedback: (17)
Man Dean,
You are lucky you camera didn't break snapping that picture with Jim in it =) I hope to see you and your Black Magic at some contests this year. Keep us posted on your progress.
Emory.
Old 02-05-2006 | 11:37 PM
  #113
MHester's Avatar
Well Dean, you're definitely in good hands. I'd love to hear Jim's input on the parts and design. Good and bad
It won't be long and I'll have some awesome pics of the new V2s. I'm doing the paint and monokote now, and man I just thought painting one of these was work....4 is like opening the gates of sandpaper hell.
But, Ocala beckons. If I don't practice soon I'm easy pickins. oh well, I'll be last place with a kool plane. LOL
Man I need more ventillation in this shop, the fumes must be getting to me.
All work and no play makes Mike a dull boy. All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.All work and no play makes Mike a dull boy.
All work and no......holy crap I've been trapped in this shop too long. WHERE'S MY AXE?!?!?!?!!
J/K
-Mike
Old 02-06-2006 | 12:09 AM
  #114
MHester's Avatar
Oh, and your shop floor is too clean for proper building proceedures. Throw a bunch of stuff on the floor, you're making me look bad
-M
Old 02-06-2006 | 12:12 AM
  #115
MHester's Avatar
ORIGINAL: dick Hanson
Thanks Dick.
And I agree, wholeheartedly.
But from what I've seen, there's hope. Stay tuned.....
-Mike
Old 02-06-2006 | 03:14 AM
  #116
handglider's Avatar
My Feedback: (23)
Photo's from todays work.
ID:	402907   Click image for larger version
ID:	402908   Click image for larger version
ID:	402909   Click image for larger version
ID:	402910   Click image for larger version
ID:	402911   Click image for larger version
ID:	402912   Click image for larger version
ID:	402913   Click image for larger version
ID:	402915   Click image for larger version
ID:	402916   Click image for larger version
ID:	402917   Click image for larger version
Old 02-06-2006 | 04:18 AM
  #117
handglider's Avatar
My Feedback: (23)
a few more of the "other" project...
ID:	402921   Click image for larger version
ID:	402922   Click image for larger version
Old 02-07-2006 | 12:21 PM
  #118
handglider's Avatar
My Feedback: (23)
Well another night, the final set of former templates and a new set of formers. And a little trash in the shop....
Hope to cut another set of formers tonight and 2 sets of fuse sides tonight.
ID:	403722   Click image for larger version
ID:	403723   Click image for larger version
ID:	403724   Click image for larger version
ID:	403725   Click image for larger version
ID:	403726   Click image for larger version
Old 02-07-2006 | 12:47 PM
  #119
Handgliders workshop... what sort of place is that?
It looks bigger than my house!
Old 02-07-2006 | 01:52 PM
  #120
Hi Handglider
DId you redraw all your formers and modify them on computer a litte then cut them out ??? If so can I ask for a copy to compare mine
thanks
Troy
Old 02-07-2006 | 02:33 PM
  #121
handglider's Avatar
My Feedback: (23)
HI Troy,
Yes, I've got about two days worth of work into tweaking these formers. I drew the outlines in Adobe Illustrator, with center lines etc. This all will work well in the fuse jig that I have planned for later this week. These formers are AWESOME, I had fun with the inside lightning holes and shapes. I am going to rip out another set tonight with a few more additional tweaks, I am planning on building two airframes initially.
I am going to be running a YS 140 DZ - so I am using 3/16 ply 3/16 balsa firewall otherwise the rest of the material is per the plans. I have actually made 3 sets of formers so far. Each set is usuable but not as acurate as this last set.
Sorry but I won't be sharing my drawings at this time, hope you understand... but I'll take pictures of everything to show you how and what I am doing....
Let's see what your doing Troy?
You can recreate what I have done, I didn't do anything special here, and it only took me two days.... ; ) The interesting thing I discovered is that it was easier working in metric. I am building the fuse gig in millimeters.
I will be plotting fuse side templates and will print them out on roll paper just like I have done the former templates. the paper templates will have former stations printed in postition, this should make setting up the jig pretty freaking perfect. I will be using laser levels instead of the "String" method that Mike suggests - more on this later....., I'll be able to align the wing and stab tubes in the gig - this is going to FREAKING ROCK!!!!
I've got my digital scales coming in a few days, I will be getting my weight sheets going soon. Sorry that I have been only posting pictures with little text, I've been working like 20 hour days on this since saturday, been too busy drawing, cutting, drawing, cutting....
stay tuned - this Black Magic will be one BAD BAD BOY!!!
Dean
Old 02-07-2006 | 02:38 PM
  #122
handglider's Avatar
My Feedback: (23)
another detail picture of my formers
Old 02-07-2006 | 07:08 PM
  #123
handglider's Avatar
My Feedback: (23)
Sushi, lasers and fuse templates.
just got home from work,
ready to enjoy a little fresh sushi....
and knock out some fuse sides.....
Old 02-07-2006 | 08:21 PM
  #124
handglider's Avatar
My Feedback: (23)
Laser level tabletop mockup. This is the CHEAP $15.00 radio shack.
The pictures tell the story..... this is going to ROCK!!!
ID:	403970   Click image for larger version
ID:	403971   Click image for larger version
ID:	403972   Click image for larger version
ID:	403973   Click image for larger version
ID:	403974   Click image for larger version
ID:	403975   Click image for larger version
ID:	403976   Click image for larger version
Old 02-07-2006 | 08:50 PM
  #125
RC_Pattern_Flyer's Avatar
OK.. ..... NOW THAT IS COOL! i am so behind the times... i use the ole six pack and close one eye, if it isnt straight.. try the other eye or add another 6 pack.. hahaha.. looks great guys!
Chuck
