Reload this Page >
Albatros DVa
Albatros DVa
Old 12-28-2008, 09:52 PM
  #226
cocobear
Default RE: Albatros DVa
Hi, I use Dubro turnbuckles on my planes. A little gun blue and they look just right! For flying wires, By a spool of 150-200 lb Dow Rigger line. Inexpensive 5 strand braid and a spool will do a bunch of 1/3rd scales.
DJ
Wilson, PM me with your Email as I have more info for you
Old 01-04-2009, 11:08 PM
  #227
wilson4491
cocobear I did pm you with my e-mail ( I think I did but it does not show up in my sent folder ) I thought I would post a couple of pictures of my build so far.
ID:	1103772   Click image for larger version
Old 01-05-2009, 10:33 AM
  #228
mcjustis
DJ,
I have my fuse all ready for the sheeting and was wondering what thickness of sheet you used. The plans I have call for 5/32" thick, which I think is way too thick. Not to mention too much work. I was thinking about 3/32. 1/16 would be even easier, but I would be worried about an errant thunb poking through it. What is your recommendation?
Martin
Old 01-05-2009, 01:15 PM
  #229
cocobear
Hi Martin, I used 3/32" on the 1/4's and 1/8th on the 1/3rds
Old 01-05-2009, 06:38 PM
  #230
Mode One
cocobear, Sorry to cut in here with an unrelated subject. At theaerodrome.com, I talked to you about 1/4th scale plans for your Albatross DIII. I have left a PM there about this. Thank you! (Now, back to your regularly scheduled programing)!
Old 01-05-2009, 11:38 PM
  #231
mcjustis
DJ,
I have another question for you. I am wondering what kind of servos you're using in the top wing. I have two HS-5125's sitting here. THey say (I think) 49oz @ 6volts. Is that enough. It seems a little weak to me. Just curious what you guys are using.
Thanks again,
Martin
Old 01-06-2009, 10:48 PM
  #232
semeraro
Did some work on the cowl tonight. Added the metal strip edging and slathered some bondo on top. Now on to sand fill sand fill prime sand.... It is getting there.
Dave S
ID:	1105294   Click image for larger version
ID:	1105295   Click image for larger version
ID:	1105296   Click image for larger version
Old 01-16-2009, 08:39 AM
  #233
semeraro
I covered the stab with koverall and primed some of the gun bits. The stab is just slid into place to make sure there were no gaps. I will give it some dope, stitching and tapes before I install it permanently. The scheme I want to use has the tail in black and white stripes.
Dave
ID:	1111962   Click image for larger version
ID:	1111963   Click image for larger version
ID:	1111964   Click image for larger version
Old 01-26-2009, 11:49 PM
  #234
kahloq
kahloq's Avatar
Ive been interested in building an Albatros for some. This is a very interesting thread.
Old 01-30-2009, 06:06 PM
  #235
clearblue
clearblue's Avatar
Dave and Dave, I have started the Spad! I've posted a build thread here in RC scale. Jim
Old 02-05-2009, 01:19 AM
  #236
rcar4
rcar4's Avatar
Any progress?
Old 02-05-2009, 07:18 AM
  #237
Mode One
Dave (Cocobear), Sorry to cut in here, again. The plans for the Albatros DIII that you said were placed in the mail on January 16th, have not arrived. I would think you will want to investigate this. Again, If they do show up, I will mail a payment for them when you either PM your mail address to me or will use your return address to send it off.
Thanks!
Old 02-07-2009, 12:01 PM
  #238
semeraro
hi rcar4,
I have been working on little detail stuff that is, in my opinion, not very interesting to look at so I didnt post it. I have been working on getting the cabane struts finished and ready for primer. I put some more bondo on and did some shaping of the fairings and the metal brackets that model the strut attach fittings. I had to bend them a bit to make them fit the fuselage side. Then I slopped some resin on the struts and other places on the airplane to seal the grain.
I also did an experiment on one of the shell chutes. Three of the four were balsa covered with paper. On the fourth I carved it from balsa but used resin instead of paper. I tried to mold in panel lines and the other detail. It did not work out well and so I covered that with paper also and detailed it. I didnt take any pictures of any of this stuff.
It finally warmed up today so I got into the garage and got another coat of dope on the ailerons. The wings are ready for markings. The ailerons need one more coat of dope or so. They should be done by the end of the weekend. I am working efest tomorrow so I may not get much done.
By the way, I see you are from Champaign. Are you in the local rc club? If you are going to efest on sunday stop by the frequency board. That is where I am working and I am pretty sure I will have lots of spare time to chat.
Dave S.
Old 02-09-2009, 10:17 AM
  #239
cocobear
Resolved
Old 02-09-2009, 12:42 PM
  #240
Mode One
Old 02-09-2009, 12:56 PM
  #241
cocobear
I never asked for payment. i was planning to replace them at my expense prior to your attack.
Old 02-09-2009, 09:04 PM
  #242
Mode One
Old 02-10-2009, 01:20 AM
  #243
rcar4
rcar4's Avatar
semeraro,
Thanks for the update, Hope to see you maiden her at the club, you are going to fly her at the club? I did go to efest, but had not checked the thread before I went. I was a little surprised to see a frequency board, And my have seen you and not known it. You guys are doing a great job on your builds!
Cocobear sorry to hear about your job, it is their loss. You are very talented, maybe you should be your own boss.
Take care and hope to see you at the club!
Ron
Rcar4
CCRCC
Edit
Mode one
Thanks for the correction, when I saw the age of 58 it should have given me a clue. Good luck.
Old 02-10-2009, 10:22 AM
  #244
cocobear
Back on topic!!!! I had not touched this for quite some time due to illness, crazy work schedule and the fact that I found a big fat problem with the markings!! After studying the pictures extensivly I noticed something which looked slightly odd. I confirmed the issue and became depressed and needed to walk away from it for a while. Yesterday I began tackling the problem. man do I hate reworking something I thought was done. I shall know tomorrow if my efforts were succesful. If so, plane should be finished in a couple of weeks!!
DJ
Old 02-10-2009, 10:26 AM
  #245
BobH
This seems to be a private matter between you and cocobear so why bring it to a forum? Have you been cheated, ripped off etc? Maybe its a matter of the plans carrier and not the sender. I bought something from a guy on Tx and even though I live in Va the item was SENT TO GEORGIA??? why? ask the post office!! and I never received it and was out my $50 too.
Public whining seems to be the order of the day. Sorry about your job loss. I think unless you have a real issue that cannot be resolved in private you should keep it private. My 02 cents.
Old 02-10-2009, 10:48 AM
  #246
JohnF
Well said Bob, I completely concur. If I started whining about the money I lost a few years ago waiting for a engine to be built by a well known guy in Canada and the out come you would all pass out! [sm=47_47.gif]
Old 02-10-2009, 11:09 AM
  #247
cocobear
Enough! Let's talk building!!!
Old 02-10-2009, 11:46 AM
  #248
BobH
I may have misspoken before. I apologize to all the parties concerned. I'm sure they can resolve the issue in private. DJ yes, lets get back to building.
Old 02-10-2009, 02:24 PM
  #249
mcjustis
Dave,
I am almost finished with the top wing on my DV and am wondering if the servos I plan on using are enough. They are theHitec 5125 thin wing servos. About 50 oz.in torque on 6v. Will this be enough. If not what are you guys using?
Martin
Old 02-10-2009, 03:49 PM
  #250
cocobear
That should be OK. Bottom limit however. Standard sizes will fit with ease. I highly recomend looking at the Futaba S3305s as they are only $35 and 105 oz.in and metal gears. If the Hitec thin wings don't have metal gears, don't use them, at least in my opinion.
