Jp 4
Old 08-26-2016, 05:10 AM
  #101
Tanker 10
Tanker 10's Avatar
Originally Posted by TheBennyB
yea, inside 10'. Theoretically you could reverse into action and never get hit from that side, then unleash a death blossom. Like you said, your rear end is IFA or I guess IRA. Guessing you'll be the first with this one at Danville Will, we can do some testing on it. Either way not a big deal.
Just a comment and a question, my TBU's will score a hit at 10 feet or closer pretty much no matter where you aim, so wouldn't the hatch blocking the apple be a mute point inside of ten feet?? Don't know, just asking.
Old 08-26-2016, 05:22 AM
  #102
TheBennyB
Exactly, so inside 10' TFA is no longer effective so he should be able to get hit in the ass. The hatch will block this and make it invulnerable up to a point. Yea it'll probably take a hit if your 1-2 feet away and off to the side a bit but not further out.
Old 08-26-2016, 05:27 AM
  #103
ausf
ausf's Avatar
Also Jeff, we first do the hit test before we ask a tanker if they can remove an obstruction. It's not just a visual observation. So if a tammy t1 comes to inspection with it's stock TC hatch and it takes hits from the obstructed side it's good to go. Never want to make a builder mess with their stuff unless necessary for fair play.
I hear ya.
It's a lose-lose situation because even if you win the battle, they'll be skepticism involved.
My T1 is retired from battle since I mounted the skeletal TC, but that hatch still has the Aber details from the original build, so it's fully functional with the retaining clip and spring assist. There's no way I'd pull it off to battle.
The landing Sherman vents were removable (as are riders) so they shouldn't be considered part of the tank design.
I look at it as the same as the tank choice. My son will always choose a 105 M4 over a JS-2 because he knows he can spin that turret so much faster than swinging that telephone pole around. If a T1 is less vulnerable from the right side, then that's how it should be battled. Although, I can't even pull off the turret turn to 45 half the time so the idea I could use the TC hatch lid like a Captain America shield is pretty funny.
Another idea on the hatch: anyway you could mount the hinge against the roof with magnets? Maybe tabs out to the side? You could pop it off for battle, back on for regular drive/display.
  #104
Tanker 10
Tanker 10's Avatar
OK, thanks Benny. I haven't tried shooting at my Jagdpanzer IV from the rear with the hatch up blocking the apple, will have to try.
Old 08-26-2016, 06:01 AM
  #105
TheBennyB
Also remember we're talking about an apple using TFA. The prism inside the apple has been rotated 45 degrees.
https://www.youtube.com/watch?v=oRxbLmF56Gs
Old 08-26-2016, 06:05 AM
  #106
Tanker 10
Tanker 10's Avatar
Thanks for the video, I've seen it in the past. I never knew before seeing that video that it was possible to do that to the apple.
Old 08-26-2016, 01:45 PM
  #107
manchu9inf
the rotation unit is installed
the main gun is assembled
The cable for the headlight in place
some pics of the hatches and periscopes
Name:	JP 4 hull interior.JPG
ID:	2178332   Click image for larger version
Name:	JP 4 main gun.JPG
ID:	2178333   Click image for larger version
Name:	JP 4 headlight cable.JPG
ID:	2178334   Click image for larger version
Name:	JP 4 hatches and periscopes (1).JPG
ID:	2178335   Click image for larger version
Name:	JP 4 hatches and periscopes (2).JPG
Old 08-26-2016, 02:29 PM
  #108
Tanker 10
Tanker 10's Avatar
Nice work, you're getting closer now, looks great.
Old 08-26-2016, 05:56 PM
  #109
manchu9inf
the electronics are mostly installed, still need to mount the Hull MG. space is a cramped, i dont like the flimsy elevation mount, the gun wobbles a lot, there isn't a spring at the rear of the recoil unit like on other tamiya tanks.
Name:	JP 4 Hull Interior Electronics (1).JPG
ID:	2178365   Click image for larger version
Name:	JP 4 Hull Interior Electronics (2).JPG
ID:	2178366   Click image for larger version
Name:	JP 4 Hull Interior Electronics (3).JPG
Old 08-26-2016, 05:59 PM
  #110
manchu9inf
here is the JPz with the gun mantlet and muzzle brake mounted. Hopefully tomorrow the speaker and gearboxes will get mounted.
Name:	JP 4 with gun mounted (1).JPG
ID:	2178371   Click image for larger version
Name:	JP 4 with gun mounted (2).JPG
ID:	2178372   Click image for larger version
Name:	JP 4 with gun mounted (4).JPG
ID:	2178373   Click image for larger version
Name:	JP 4 with gun mounted (6).JPG
Old 08-26-2016, 06:23 PM
  #111
kinzavrop
That is one "bad ass" looking tank hunter. I can't imagine having the L70 gun. It would be too long for this size tank.
Old 08-27-2016, 04:28 AM
  #112
TheBennyB
Sounds like a another part for Daryl to improve on. If you make the trunion/traverse bracket out of aluminum should reduce some deflection. This was the same problem with the JP.
Old 08-27-2016, 06:07 AM
  #113
Panther F
Panther F's Avatar
Thumbs up
Very neat and tidy work.
Jeff
Old 08-27-2016, 07:26 AM
  #114
manchu9inf
I haven't built the JP, but i think the problem is at least twofold: one, is how they have the elevation arm with that flimsy bent piece of metal that hooks into the recoil mount and second, the whole system isn't balanced well, i cant imagine how it would flop around with even the longer barrel.
Old 08-27-2016, 12:59 PM
  #115
manchu9inf
i have made a more solid elevation arm with some extra parts, it helps but doesn't completely fix the problem.
Name:	JP 4 new elevation arm (2).JPG
ID:	2178469   Click image for larger version
Name:	JP 4 new elevation arm (3).JPG
ID:	2178470   Click image for larger version
Name:	JP 4 new elevation arm (4).JPG
ID:	2178471   Click image for larger version
Name:	JP 4 new elevation arm (1).JPG
Old 08-27-2016, 01:03 PM
  #116
manchu9inf
The gearboxes, MF, DMD, and speaker installed. I like to use the foam around the outshafts to help prevent dust and debris from getting inside the tank.
Name:	JP 4 motors and MF installed (1).JPG
ID:	2178478   Click image for larger version
Name:	JP 4 motors and MF installed (2).JPG
ID:	2178479   Click image for larger version
Name:	JP 4 motors and MF installed (3).JPG
ID:	2178480   Click image for larger version
Name:	JP 4 motors and MF installed (4).JPG
Old 08-27-2016, 01:06 PM
  #117
manchu9inf
The tank hunter with tracks.
Name:	JP 4 with tracks installed  (2).JPG
ID:	2178485   Click image for larger version
Name:	JP 4 with tracks installed  (1).JPG
Old 08-27-2016, 01:43 PM
  #118
MAUS45
MAUS45's Avatar
Looks nice!!!
Old 08-27-2016, 01:50 PM
  #119
kinzavrop
Bad to the bone!
Old 08-27-2016, 07:20 PM
  #120
manchu9inf
The hull schruzen brackets i added 1mm brass bolts to replace the molded on bolts heads as well as to add a little more bracing, hopefully they will stay on better.
Name:	JP 4 skirt brackets (2).JPG
ID:	2178544   Click image for larger version
Name:	JP 4 skirt brackets (1).JPG
ID:	2178545   Click image for larger version
Name:	JP 4 skirt brackets (3).JPG
Old 08-27-2016, 07:24 PM
  #121
manchu9inf
dreaded pin holes, the side skirts are easy enough to fix, the brackets, not so much. Hopefully they wont be noticed with the schruzen on.
Name:	JP 4 pin holes (1).JPG
ID:	2178548   Click image for larger version
Name:	JP 4 pin holes (2).JPG
Old 08-28-2016, 05:43 AM
  #122
Rad_Schuhart
Hi, I just saw the wires for the headligt. Is it a working light? If so, where can I buy a wire like that? I would like to install something similar in my tanks.
Old 08-28-2016, 01:49 PM
  #123
manchu9inf
its not a working headlight and the cable is a wire Christmas tree ornament hanger.
Old 08-29-2016, 03:29 PM
  #124
kinzavrop
Will, did you zim the "sissy skirts"?
Old 08-29-2016, 05:33 PM
  #125
manchu9inf
i did not zimm, i haven't found any pics with them zimmed.
