Reload this Page >
CARF F4U-1 Corsair build thread
Old 10-25-2015, 09:48 AM
  #3101
saramos
saramos's Avatar
Here's my latest test print. While doing the print, I found an error in the internal ribs where the ribs were not making full contact to the center hub. I've corrected the model and will have to do another print. I also improved the look of the face of the wheel with a more scale looking reinforcements around the spokes.
Scott
Name:	Corsair Wheel cutaway.jpg
ID:	2127620   Click image for larger version
ID:	2127621   Click image for larger version
Old 11-22-2015, 09:02 AM
  #3102
ram3500-RCU
My Feedback: (221)
ram3500-RCU's Avatar
When installing the hinges on the cowl flaps I use a 1/32 shim to flush out the hinge point with the cowl plate.
ID:	2131808   Click image for larger version
Old 11-22-2015, 09:06 AM
  #3103
ram3500-RCU
My Feedback: (221)
Pitot tubes. The root is glued in and the tube unscrews for easy transport and storage.
ID:	2131811   Click image for larger version
ID:	2131812   Click image for larger version
Old 11-23-2015, 05:06 AM
  #3104
IFLYBVM2
My Feedback: (360)
Is the pitot one of the items you sell as an accessory ?
Old 11-23-2015, 11:08 AM
  #3105
ram3500-RCU
My Feedback: (221)
Not at this time. Brian makes these by hand without the benefit of a machine shop. Takes too long to be able to charge for just these. We make them for our own builds though.
Old 11-23-2015, 03:25 PM
  #3106
DrScoles
My Feedback: (18)
DrScoles's Avatar
Good to see you back at it Gary! My corsair is in storage…. A bunch of jets got in the way. Plan on bringing it back out soon.
Old 11-23-2015, 04:39 PM
  #3107
ram3500-RCU
My Feedback: (221)
Thanks Doc. Been a tough stretch for us and I still have a few things to do on the house including moving my shop but I am able to get back to work on these things anyway. Feels good to be making progress again. I have some very patient modelers I'm working with and it is much appreciated.
Old 11-23-2015, 08:42 PM
  #3108
ram3500-RCU
My Feedback: (221)
One of the things that needed fixed on this build was the elevators. The previous builder had cut the CF rod connecting them (in order to use two servos) and glued the sections onto the elevators, locking the pivot rods in and making it impossible to remove the elevators for painting. He also did a poor job of installing the bearings. This is completely unnecessary. One strong servo has proven to be sufficient. I also like the way the bearings work when the rod goes straight through. The elevator hinge points were also not installed straight so that the gap was drastically different from one side to the other.
This was all fixed, starting with new elevators. These fit perfectly to the original stabs due to the excellent manufacturing process of CARF. The holes in the left stab hinge roots were adjusted in the process. New bearings, new rod, new tiller, and new elevators, shown here before I installed the tiller.
The last picture is of the structure that the locking screw for the elevator goes in. This is an older kit that is still wood. The new kits have CF reinforcement in this area, as does the new elevators this ship is now fitted with.
ID:	2132172   Click image for larger version
ID:	2132173   Click image for larger version
ID:	2132174   Click image for larger version
Old 11-23-2015, 08:55 PM
  #3109
JSZ
My Feedback: (73)
JSZ's Avatar
Nice work! Hope all is well at home. Package is on its way
Old 11-23-2015, 11:56 PM
  #3110
ram3500-RCU
My Feedback: (221)
Thanks John. Things are getting back to normal. Mom is adjusting well so far. She seems to be comfortable and content for now. No problems so far. What an ordeal though.
This plane was in bad shape. It was originally the kit version. The name Comp ARF is deceiving. Sure, it is a composite aircraft, but the kit form requires great precision in assembly/building. The tail components, tail gear, main gear, doors, wing folding system, and outer panels all needed fixed to some degree. We were provided with a new hardware package, new elevators, and a new cowl. With these parts, and all our mods, In spite of her beginning, she will be an awesome ship. The owner wants to do 'Marines Dream', a good looking ship.
Old 11-24-2015, 09:37 AM
  #3111
Zorba1
Hi Gary, I'm about to start my built of the Corsair and I was wondering where can I get the actuators (air pistons) for the main gear and tail gear doors. They don't come with the kit.
Also I like to know why you covered the surface with aluminum foil then paint it instead of just paint the composite, any reason for that?
Did you had to sand the surface smooth before applying the foil? then do the rivets all over again?
BILL
Old 11-25-2015, 03:02 AM
  #3112
ram3500-RCU
My Feedback: (221)
BILL
Hello Bill. I'll check with my brother on the size and travel of the cylinders. He does that work for us.
Old 11-25-2015, 03:35 AM
  #3113
ram3500-RCU
My Feedback: (221)
On the reason for the aluminum, we use it where we intend to do paint chipping and weathering for an authentic exposed aluminum look. Leading edges, hatches, top front of the wing root where Corsairs are prone to loose paint, around the cowl bowl, cowl flaps, etc. The surface is sanded and prepped as you would for paint prior to applying the aluminum. Then the aluminum is wet sanded with 400 prior to paint to dull it down and remove the inevitable orange peel appearance from the adhesive.
I also use it where screws and other fasteners will be detailed as this is very easy to do in the aluminum vs the composite surface. In the case of a ship that is going to competition including static judging, for more accurate hatch detail on the CARF Corsair, I sand off the molded details and replace them with my own out of aluminum foil. The stock CARF Corsair is not "museum" scale out of the box. Very good in general, but not for static judging in competition by skilled judges (unless of course you can find 3-views that are as bad as it is). But it can be made very competitive as has been proven.
If the model is being made to look newly manufactured or freshly restored, only the later areas will get the aluminum treatment.
On the "rivets" the Corsair had very few of them as the skin was spot welded in large part, not riveted as most other aircraft of the day. Most of the front panels around the nose were removable and thus screwed on. That is why the fastener detail on the panel lines aft of the cockpit are so subtle. Spot welds would be hard to see in our scale.
Also remember, while we are on this subject, that both horizontal stabs are identical on the full size Corsair, built in the same fixture. When installed, the inspection discs face up on the port side, and down on the starboard. One of the new elevators (on these there is a left and right) I found embossed on the inside end, what looks like an L, but this surface was actually the right one has the inspection disc inspection disc on the top inboard, faces up on the right side. Early Corsairs and FG Corsairs had a single screw in the middle of the discs, Later models had 3. Probable got mix matched in the field, I would imagine.
This stuff will drive you crazy :
Old 11-25-2015, 11:26 AM
  #3114
Zorba1
Wow Thank you Gary for the detailed info. I just took her out of the box and I'm already going crazy.
Cheers
Old 11-25-2015, 03:49 PM
  #3115
Zorba1
For the rear rails, I don't like the embossed location from CARF. I locate them higher So I can catch more of the canopy material. The taper is far less with the rear set of rails, but none the less, the full scale rides in rails that are parallel as well, so the canopy gets tighter to the fuselage as it slides forward. Here, I mount them flush with the fuselage. The flex is very slight when open.
Gary is the brass channel available or you cut the groove on a square tubing?
Old 11-25-2015, 03:59 PM
  #3116
ram3500-RCU
My Feedback: (221)
I cut the slot in sqaure tubing. I have a jig made for this. Boy do i miss Barry.
On the cylinders, we are using Robart 1 1/8" throw, 3/8 bore. Shulman had some nice ones but he isn't selling them now.
Old 11-25-2015, 04:32 PM
  #3117
Zorba1
Sorry for the one word answer. I did that from my phone and I have a hard time typing long answers from that. The hole in the center moves depending on how you glued the ply on. I use the mold seam lines to establish a cross hair on the firewall and use this as the starting point for measuring. The center of the template will be to the port side of center and slightly below the horizontal line. I can give you these dimensions if I haven't already. The reason it is not in the center is because of the thrust angle of the engine. 2.5 deg right and .05 deg of up means it must be moved off center in order for the prop to be centered in the cowl and this is important or you will have rockers poking threw.
Gary do you have the dimensions of this ply? or a template to cut from?
Old 11-25-2015, 05:30 PM
  #3118
Zorba1
An update for those of you who purchase our upgrade parts.
I am close to having our web site ready to open. In addition to being a place to go for items, manuals, and general building tips, it will also serve as an online photo album of helpful pictures to aid in the installation of all these mods. Should make the installs very easy with, in most cases, step by step pictures. this is much easier than say CDs or sending them via emails and such.
Hi Gary what is the name of your site?
Old 11-25-2015, 11:42 PM
  #3119
ram3500-RCU
My Feedback: (221)
The plywood firewall is part of the CARF kit. It consists of 3 plywood discs. One large one on the inside, another on the outside, and a smaller one in the center on the outside, sandwiching the composite.
Old 11-25-2015, 11:43 PM
  #3120
ram3500-RCU
My Feedback: (221)
No website. My email is [email protected]
Old 11-26-2015, 12:02 AM
  #3121
ram3500-RCU
My Feedback: (221)
I do have a template for the bolt locations for the Moki 250/215. These engines have very little clearance in the cowl and must be centered. The 257 7 cylinder has more clearance as it is a little smaller in diameter. I use the mold lines as a bench mark and not the plywood firewall as it may vary from plane to plane. Hope this makes sense.
Old 11-26-2015, 12:27 AM
  #3122
Zorba1
No Gary I mean the one where the cowl mounts the one with all the holes.
Bill
Old 11-26-2015, 05:43 AM
  #3123
jchorak
My Feedback: (9)
Brian from dbalsa.com whipped me up the correct armour plating and headrest for the 1D version I am doing.
Old 11-26-2015, 06:41 AM
  #3124
ram3500-RCU
My Feedback: (221)
Bill
Oh, daaaa, sorry Bill. My stainless steel cowl flap stand-offs are designed around using 3/16" ply for the rings. With thicker ply, shorter ones would have to be used. They are 18.2 MM with the 3/16 ply or .71".
ID:	2132565   Click image for larger version
ID:	2132566   Click image for larger version
ID:	2132567   Click image for larger version
  #3125
ram3500-RCU
My Feedback: (221)
Very cool. Some have commented to me about the heavy nature of the DB resin parts. IMO, it is just not an issue on this plane. The air frame itself is very light, plus, she still flies exceptionally well even at upwards of 70lbs, probably 15 lbs or so more than most will finish out with most scale detail and folding wings.
