CARF F4U-1 Corsair build thread
#952
CA
RE: CARF F4U-1 Corsair build thread
That looks great ! The linear movement of that screwdrive looks to be the a great solution for this, a nice straight push pull is whats needed for sure.
Maybe even mount your control rods solidly to the alum. cross bar in case one side gets in a bind ? just a thought. 4-40 wire rods instead of the nyrods might prevent any flexing under a load.
I tried a 4-40 nylon clevise once for a "carrier" ground down and sliced through the center to ride inside the rails.
#954
Have the wing fold peaces back after i did them away for a surface treatment.The surface is now nearly as hard as steel and after the treatment the get seald whith a teflon coating which make them sort of selflubicating.
I did this because the get scratht even by moving them inbetween aech other.Now i hope that that problem is fixt.
Grtz Bruno
Grtz Bruno
#958
Since whe paid a lot of mony for it atleast i want to give it a try,i also modified the cilinders by putting a real oil seal ring in it and a new 316 steel polisched ram.
It took some time and efort to do this but it take the weak spots out of the system so i hope it will work.
By the way,i already learnt a lot from this tread THANKS FOR THAT .
#960
My Feedback: (221)
ORIGINAL: henderyckx bruno
We are happy to share our work.
Thank you for sharing your work, and please keep us posted on your build.
#961
My Feedback: (221)
ORIGINAL: pajaro
Ram where did Brian got the covers from?
Here is a shot of the full scale.
#964
My Feedback: (158)
ORIGINAL: ram3500-RCU
Here is what I have come up with so far on the canopy drive. A couple control horns I had laying around made a tasty mount for the motor. I have found I need a carrier bearing on the back of the shaft to stabilize it.
maybe I missed it, Is that canopy drive actuator proportionally controlled or overload like the lados?,, how do you control the stop points I guess is my question
#965
My Feedback: (221)
ORIGINAL: scale only 4 me
Gary,
I will take some more pictures, but I did make some changes since the first trial. The ends were set up for 2-56 not 4-40, so I replaced the Nyrod with 2-56 all thread (still too flexible), so I then slid a carbon fiber rod over that. They DO NOT FLEX anymore. Some wax on the slider makes them smooth and easy to slide.
Tonight I'll make the carrier bearing for the jack screw, and go back to work mounting the canopy to the system. I've come up with what I think is a better and lighter way to do that without the brass I was going to use.
#966
Hello,can sombody tell me where to order the Graeme Mears pack whith the hinge covers and so and what did it cost,greetz Bruno
#967
My Feedback: (221)
I'm sure he could help you.
#968
My Feedback: (221)
For a list of everything that Graeme includes in his scale package, please refer back to page 34, post #840 in my thread. It is not cheap, but you get a lot of parts, and in our opinion, top quality scale detail parts for a quality top notch Corsair.[8D]
#969
My Feedback: (158)
It will have the same type control box that all the Down & locked gear have. They are building a special use one just for actuators like this with only one function / output. It will 'see' the load at each end and shut down the motor. Nice thing with this is, should the canopy jam for any reason, it will simple shut down. A re-cycle will send it back the other way. Very simple and reliable.
Gary,
But the way you have it set up, it looks like you could just put a jamb nut on either side of your coupler there and that would determine your stop points too.
Can't wait to see it in person,, Carry on
#971
My Feedback: (221)
Just found out the control box is shipping Monday. I'll also be receiving a a carrier bearing for the end of the jack screw, and we are going from a 600 to a 900 RPM motor. / gearbox. Easily changed out.
As it is, the speed is realistic for a canopy that would be cranked, but a little slow for a free-tracking one. The 900 will fix that, and it is nice to know that if one needs the cracked type action, the 600 is the way to go.
