ESM ZERO BUILD
Old 06-29-2013, 08:36 AM
  #51
carrera mike
Default RE: ESM ZERO BUILD
Vibration absorbers installed.I used the DA-50 mount install template to line up the holes and I think they lined up perfectly with the stand offs.
ID:	1896078   Click image for larger version
ID:	1896079   Click image for larger version
ID:	1896080   Click image for larger version
Old 07-07-2013, 11:04 AM
  #52
carrera mike
more pix of recent work. also some dry fit of the wings again.
Last two items I need that Im waiting for are the custom fit wrap around muffler from that'll for zero cowling and the retracts.
I had to return the first set of retracts 'cause one side stopped working.
Picture of the servo/tank tray below -everything in place for shake down(trial) run. Nothing is permanent for Im sure I have to move things around. The circuit on the left of the fuel tank is the Mini Thor Power Expander Ignition Kill.
ID:	1898367   Click image for larger version
ID:	1898368   Click image for larger version
ID:	1898369   Click image for larger version
ID:	1898370   Click image for larger version
ID:	1898371   Click image for larger version
ID:	1898372   Click image for larger version
Old 07-08-2013, 03:09 PM
  #53
carrera mike
Lining up the wing to center line with laser :-) before I drill the holes for mounting.
Old 07-09-2013, 02:04 AM
  #54
Lifer
Lifer's Avatar
I use a trammel line to measure the wingtip-to-tail dimensions. How does the laser do this?
Old 07-09-2013, 07:12 AM
  #55
glazier808
glazier808's Avatar
I would have to agree. I've built a few ESM planes....I would definitely check the distance from wingtip to tail on both sides to double check.
Casey
Old 07-09-2013, 08:44 AM
  #56
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
Looks good. I want one of these but would have to modify that tail wheel...and make a sliding canopy. I wonder if there's a cockpit kit in the works??
Old 07-09-2013, 09:53 AM
  #57
glazier808
glazier808's Avatar
Ram,
I have one of Earls Zero tail wheels I'm using, They're very lightweight and very well made, and look quite scale.
http://jensen-design.com/2201.html
It the lower unit in the picture.
Casey
Old 07-09-2013, 02:05 PM
  #58
carrera mike
Thanks gents. I'm just waiting for the factory retractable tail wheel. They came out with the mains but the tails are delayed so for now I installed the stock unit. The ones you have above Casey are nice.
Old 07-09-2013, 02:17 PM
  #59
carrera mike
ORIGINAL: Lifer
you don't.. I use the laser to make sure I find the center of the fuselage forward to aft (nose to tail).
Old 07-09-2013, 02:32 PM
  #60
Flyin Hwn
Mike,
Is it my eyes or is the tail wheel mounted too far forward for scale? Is that per the plans? Scale location would put it at the rudder hinge. Just wondering
Old 07-09-2013, 03:49 PM
  #61
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
No, it's not just you... and it's very noticeable. Everything else from a distance looks good though! Thanks glazier808, I think I'll follow your lead If I get one of these.
Old 07-09-2013, 05:41 PM
  #62
carrera mike
waiting for factory optional retractable tail landing gear. temp installed the stock for now.
Old 07-09-2013, 08:16 PM
  #63
oliveDrab
oliveDrab's Avatar
What's the final weight going to be? What did shipping cost from Sarasota, Florida to Virginia? If I bought the ESM FW190 D9 from TBM the shipping cost from Sarasota, Florida to Kentucky is $183.88.....which is a deal breaker. Apparently the D9 comes in a B-I-G box (fuse is 82.5" long).
Old 07-09-2013, 11:50 PM
  #64
rcflying007
WOO, $183.88 for shipping is a lot of money! But the box for the ESM Zerofighter is much smaller than their FW190 D9, should be much cheaper.
Old 07-10-2013, 08:19 PM
  #65
carrera mike
Finally got its legs,, i still need the rear though.
ID:	1899315   Click image for larger version
ID:	1899316   Click image for larger version
Old 07-18-2013, 12:59 PM
  #66
carrera mike
SUFFERED SETBACKS ON THE RETRACTS  Her MLG(Main Landing Gear), the optional factory electric retracts are not performing 100% They would do 4 cycles then 1 side quits working!!. Cant have that when I actually need them to deploy  TBM and I trouble shot both electrical harness and the elec retracts to no avail. so after returning twice for replacement, I just turned in the whole set for refund.
Im now working with Robart to get 631RSE and 671 L&R. Theirs even have down and up locks and as everyone knows been proven through the years.
Old 07-18-2013, 01:08 PM
  #67
Lifer
Lifer's Avatar
Good choice, Mike. The ONLY issue I have had with Robart airs over the years is their plastic "tee's." Other than that, very reliable. And, if you use their airline restrictors, the retraction and extension cycles are realistically slow.
Old 07-18-2013, 01:09 PM
  #68
carrera mike
After checking CG the other a week ago, found out that I'm lucky enough to only need around 1.4lbs of wt up front. Since then my dilemma is where to place/hang the weight since I have the vib aborbers on the engine mount hence making the stand offs carry the extra load is not an option.
I also changed my plan from having a single source of power(LIFE 3200mah) (with the use of 42% Power/ignition expander) to having separate ignition source since I might as well make the weight I need a "useful weight" so I opted for the heaviest reliable A123 battery out there to make as my ginition batteries. "C" cell NIMH.
So after many nights of pondering on where to put the weight(ignition batteries) I finally made this tray below. The plane is upside down in these pictures, so the tray is actually on top of the engine.
ID:	1901865   Click image for larger version
ID:	1901866   Click image for larger version
ID:	1901867   Click image for larger version
Old 07-19-2013, 11:25 AM
  #69
dgiatr
dgiatr's Avatar
why
ORIGINAL: carrera mike
[img][/img][img][/img]SUFFERED SETBACKS ON THE RETRACTS [img][/img] Her MLG(Main Landing Gear), the optional factory electric retracts are not performing 100% They would do 4 cycles then 1 side quits working!!.[img][/img] Cant have that when I actually need them to deploy [img][/img] TBM and I trouble shot both electrical harness and the elec retracts to no avail. so after returning twice for replacement, I just turned in the whole set for refund.
why not use ESM AIR TO AIR RETRACTS for ESM BEARCAT; they are scale too with offset struts and probably the same length too. can anyone verify that;
Old 07-22-2013, 05:50 PM
  #70
carrera mike
Custom made muffler
ID:	1903146   Click image for larger version
ID:	1903147   Click image for larger version
ID:	1903148   Click image for larger version
Old 07-22-2013, 07:34 PM
  #71
glazier808
glazier808's Avatar
Mike,
If you haven't gotten a spinner yet, you might try the one from yellow aircraft...it's nice and heavy and I'm sure this plane needs nose weight.
I picked one up and it's quite nice.
Casey
Old 07-23-2013, 03:28 PM
  #72
carrera mike
ORIGINAL: glazier808
Mike,
Casey
thanks for tips Casey! That is a nice spinner and has the scale look for the zero. YA wants $85 for it. As u know zero and the focke wulf are the only two that have that curves of the spinner.
Old 07-23-2013, 03:31 PM
  #73
carrera mike
thanks for the suggestion but i dont want to mess with tanks, hoses, valves/servo and air. Besides i like the scLe deployment speeed of the electrics. Appreciate it of course.
Old 07-31-2013, 11:51 AM
  #74
carrera mike
Finaly got some reliable retracts!!
Robarts electrics 671RSEs and 671 Struts.
Old 07-31-2013, 11:56 AM
  #75
smkrcflyer
smkrcflyer's Avatar
They look nice. What was the cost?
