Reload this Page >
Top RC Zero from Gator R/C
Old 10-30-2017, 12:16 PM
  #501
jimkron
Report: Flying Sunday with cowl mods went well. Saito FG 84 and Keleo exhaust ran cool in the air with average temps around 177f. Ran two flights without pressure fittings. Everything seemed fine. Still tweaking midrange.
Old 10-31-2017, 04:00 AM
  #502
redjack
redjack's Avatar
Jim, Good to hear you are conquering the heat problem. I have a couple questions.
1. Did you notice the temp when the engine died from over heating?
2. What effects do you think pressurizing the fuel tank did or didn't do?
3. Are you running the Ray English recommended 15.1 mix? And what kind of lube are you using?
Gary
Old 10-31-2017, 06:38 AM
  #503
jimkron
Gary
1. Just a guess...very hot...230f+ in the air. Deadsticks did not have telemetry.
2. Honestly, very little that we could tell after two flights.
3. Yes 15:1. Using 95 octane non-ethanol gas Sunoco Optima. Oil is Morgan synthetic. https://www.horizonhobby.com/hp-lubr...-oil-qt-coo500
Old 11-01-2017, 06:24 AM
  #504
jws_aces
My Feedback: (33)
jws_aces's Avatar
Jim,
I just stumbled across this thread. Be careful with that oil. I exploded (broken rods) with 2 Ray modified 84cc on that oil.Name:  p.jpg
We didn't depart on good terms especially when he question what oil I was using when I returned the second broken one to him..He pretty much called me a liar.
I now a have the stock 84cc living in a topflite fw-190 that has similar cowl airflow issues if not worse that the Zero. I am using the baffles also with on a one hole in the bottom.
I am using redline oil but I have witness the stock motors with over 100 flights using klotz also.
I have figured out the way to make any of them live is the right oil and running rich. I believe the Ray mod allows all cylinders to fire at a much leaner setting but that takes away the lubrication to the rods and internals.
My needles are at 4.5 and 6.5 high side..It will not start and run if I lean either one. I get temps under 200 after a 10 min hard flight in 90 degree weather. I tuned mine using a infrared temp gun with the cowl off. It will cool down going to full throttle..
I have burned at least 10+ gallons thru mine and not a single problem. If you haven't seen the video I also run the 24x12 prop like you and my Telemetry shows it turning over 7600 rpm in the air. Ray told me that the engine wouldn't live pass 6400 rpm. You be the judge for your self. I love the video and the sound of your zero.
Old 11-01-2017, 06:25 AM
  #505
jws_aces
My Feedback: (33)
jws_aces's Avatar
Oh yea I don't chase down the that expensive non-alcohol gas just for this engine.. that is a joke..
Old 11-01-2017, 06:32 AM
  #506
jws_aces
My Feedback: (33)
jws_aces's Avatar
Here is mine last fall and will be flying it this weekend in Ga. at a warbird event
Old 11-01-2017, 06:53 AM
  #507
BarracudaHockey
BarracudaHockey's Avatar
I really wish I could get up there for that
Old 11-01-2017, 06:54 AM
  #508
jws_aces
My Feedback: (33)
jws_aces's Avatar
Yea Rex and Pedro put on a great event.. Love the Friday night steak
Old 11-01-2017, 07:39 AM
  #509
jimkron
Hey Jeff,
How did you hook up the RPM telemetry for the Saito. I've got the little cable wrapped around the cylinder for temp but not sure how to connect to engine for RPM.
jim
Old 11-01-2017, 07:51 AM
  #510
jws_aces
My Feedback: (33)
jws_aces's Avatar
Jim,
I pretty sure I used this with my tach lead from the ignition box.
https://www.horizonhobby.com/ignitio...dapter-evoa107
I see that it has been discontinued. It works just fine and I have the onboard tach to check it against.
Jeff
Old 11-02-2017, 06:25 AM
  #511
Jim Cattanach
Jim Cattanach's Avatar
I received my Zero today & made a start on the wings. After removing the servo hatches, I see that there are no wood mounts fitted to the wings to attach the servos. Did any of you guys have this issue? Perhaps it is a change of design?
I thought about drilling the servo hatches & bolting the servo L brackets to the hatches, or do you think I should make some mounts & epoxy them to the wings?
I am very pleased with the quality of this model.
Old 11-04-2017, 09:23 PM
  #512
Jim Cattanach
I decided to fit the servos, with the metal L brackets to the servo hatches. It seems to be very secure.
Old 11-05-2017, 10:02 PM
  #513
jimkron
Originally Posted by jws_aces
Jim,
Jeff
Hey Jeff,
This looks like the replacement or upgrade.
https://www.horizonhobby.com/evoluti...dapter-evoa113
I'm attaching to tach lead on ignition box for Saito FG 84. Will test this weekend with DX18 and 20 channel spektrum receiver with built in telemetry. Is this plug and play or do I have to fiddle with the RPM settings in transmitter?
jim
Old 11-06-2017, 04:51 AM
  #514
jws_aces
My Feedback: (33)
jws_aces's Avatar
Jim,
It's a plug and play, just go into telemetry and select RPM as one of the displays should show up once you do that. Flew mine again in GA at the GMARC Dino war bird event and we watch the display in flight. Saw 7630rpm. love that sound ..
Old 11-06-2017, 05:32 AM
  #515
Hot Rod Todd
Hot Rod Todd's Avatar
That's the old style, similar to what is provided on many Jets. It's not an issue if you have electric power or a smooth twin. I wouldn't do it will a gas engine that vibrates much, I don't think there is a way to mount the aluminum L brackets and keep the rubber mounts on the servos.
Old 11-06-2017, 07:47 AM
  #516
jimkron
Jim,
Jeff,
Wow. 7630 rpm. We're tuning my Saito on the ground to 5800. Figuring the prop will unload to 6500-+ in the air. Your FW must have been screaming!
jim
Old 11-06-2017, 08:08 AM
  #517
jws_aces
My Feedback: (33)
jws_aces's Avatar
Jeff,
jim
Yea there was another guy there with the exact same plane and set up.. using the 24x12 zoar prop. we had a blast flying together. He seem to be turning really similar rpms.
Jeff
Old 11-06-2017, 03:20 PM
  #518
TimD.
My Feedback: (207)
TimD.'s Avatar
Go to your local hardware store and get 3.5x10mm screws. That will allow you to use the rubber grommets. I mounted mine without the wood blocks and straight to the hatch.. Just one less place to have a failure.
Old 11-07-2017, 09:19 AM
  #519
Jim Cattanach
I did not use the rubber servo grommets. I am using a Saito FG 84 I had in a giant Corsair. Had no vibration issues.
The build is going well. Both wing halves are finished.
I bought the kit from Bigplanes in the Netherlands & they supplied electric ESM landing gear. The gear doors were easy to set up using this gear.
Starting on the fuz tomorrow.
I am not a fan of wires for rudder & will use the servo hatch in the tail fin method.
Old 11-13-2017, 04:45 PM
  #520
evileye
Default eVILEYE
Gator Zero arrived Saturday
Considering Saito 90 cc Three cylinder Engine
But have read some post that overheating and engine stopping with dead stick landing
At about 4 or 5 $ thousand this is a no no
Just completing 100 ' Douglas dive bomber and still waiting for Some radio parts for Hanger nine Corsair
7-77 in Corsair 9-99 in Douglas
My son and I are going to war with SBD attached zero and shot down ( Not really Smoke maker on zero)
by Corsair
Well I am 85 and my sons are 60 & 57
Some people fortunately never grow up
Any advise on over heating would appreciated
jeep36 (02-26-2021)
Old 11-14-2017, 08:07 AM
  #521
jimkron
The cowl ring and keleo exhaust block air from exiting...in my opinion. I'm confident we solved the over-heating by opening up the back of the cowl flaps, baffled the engine, and got rid of cowl mounting ring. This is not an exact science...but a start.
Old 12-01-2017, 06:22 PM
  #522
JKreitz
Hey guys, has anyone else had a problem mounting the strut covers on the factory landing gear? With the knuckle on the strut, I don't see how I can mount the cover, have it fit relatively flush with the wing and allow for the knuckle to move without hitting the cover. Any ideas out there?
ID:	2246665   Click image for larger version
ID:	2246666   Click image for larger version
ID:	2246667   Click image for larger version
Old 12-02-2017, 06:21 AM
  #523
MikeJM
MikeJM's Avatar
Default my solution
This is how I did it with the Robart retracts.
Name:	hinge mock up.jpg
ID:	2246680   Click image for larger version
Name:	hinge mock up2.jpg
ID:	2246681   Click image for larger version
Name:	wheel pants mod.jpg
ID:	2246682   Click image for larger version
Name:	wheel pants mod2.jpg
ID:	2246683   Click image for larger version
Name:	hinge mock up3.jpg
Old 12-02-2017, 08:06 AM
  #524
JKreitz
I like it, it always amazes me how creative modelers can be.
Thanks, Mike
Old 12-02-2017, 10:49 AM
  #525
MikeJM
MikeJM's Avatar
Your very welcome
