TopRCModel FW-190
Old 01-16-2020, 05:21 AM
  #726
n8622t
My Feedback: (8)
Guns are built now to drill wing placement
Old 01-17-2020, 06:09 AM
  #727
Didier
Originally Posted by totto
My Zero has the FG90 and total weight dry is 15 kg (Without drop tank).
I am very happy with the Zero with the 90. Its a perfect match for this model, and this weight. Good power in all directions. All over a great combo.
My FW had the FG90, and the total weight dry was 17 kg. (Extra paint and without the drop tank)
I have now changed to Moki 180 engine. Total 18 kg dry. (Also without the drop tank). Perfect combo. Just super ! Highly recommended !
I felt that the FW was underpowered with the 90. I would say that the 90 has a limit when the weight is coming up to 16,5-17 kg.
Thanks Totto,
Send you a PM
Old 01-17-2020, 08:43 AM
  #728
DrScoles
My Feedback: (18)
DrScoles's Avatar
Didier, do you like the retracts that come with the zero? Love to put Sierra gear in it.
anyone know if darrel's gear fit?
Old 01-17-2020, 08:50 AM
  #729
n8622t
My Feedback: (8)
Darrells gear fit with some simple shims added
Old 01-17-2020, 08:53 AM
  #730
DrScoles
My Feedback: (18)
DrScoles's Avatar
thanks! are those his FW190 gear? I know those fit, I meant the zero.... I have his gear in my top rc FW
Old 01-17-2020, 09:35 AM
  #731
n8622t
My Feedback: (8)
Yes they are Darrells FW190 gear....I don’t know about his zero gear but surely they are a good fit on that model
Old 01-17-2020, 12:10 PM
  #732
totto
Hello Didier...PM done
Old 01-21-2020, 11:07 AM
  #733
jimkron
Originally Posted by n8622t
Tried some chemicals on the graphics but still had to wet sand
The graphics are coated with a thin clear plastic. Tough to sand or remove with chemicals. I took a razor blade and scraped off the plastic...then wet sanded with 180 & 220. Very easy once I figured out how to remove plastic shield. It will come off is huge hunks once you get the blade underneath a bit. Hope that helps.
Old 01-21-2020, 11:19 AM
  #734
n8622t
My Feedback: (8)
Thanks Jimkron...that’s exactly how I did it
Old 01-21-2020, 09:41 PM
  #735
elmshoot
I ordered mine without decals and if I had to do it again I'd have ordered the plane in primer. You have to wait for the next shipment and pay up front.
Sparky
Old 02-06-2020, 09:09 PM
  #736
n8622t
My Feedback: (8)
Paint is on and graphics are started
Old 02-07-2020, 10:39 AM
  #737
AV8ATOR
AV8ATOR's Avatar
That is looking really good Jimmy!
Old 02-07-2020, 02:17 PM
  #738
n8622t
My Feedback: (8)
Thanks...I didn’t get to work on it today as I had planned but maybe I can get something done tomorrow
Old 02-07-2020, 02:20 PM
  #739
n8622t
My Feedback: (8)
I wasn’t happy with this one vinyl but Callie is doing it over for me
Old 02-08-2020, 09:49 AM
  #740
jimkron
what system did you use for the rivets? they look awesome. Will you have a sliding canopy?
Old 02-08-2020, 03:19 PM
  #741
n8622t
My Feedback: (8)
Rivets are from Chad Viech. Very easy to apply and stick really well. I’m not doing a sliding canopy outside of the original setup
Old 02-09-2020, 12:48 AM
  #742
ptdan
Hi hi
What are the measurers on your wood shims, for the retracts???
Old 02-09-2020, 05:27 AM
  #743
elmshoot
I installed sierra gear and added 1/8 plywood shims so the gear cleared the wing skin in the retraction cycle.
There is some lateral play in the gear as the slot is wider than the gear. Tow-in isn't adjustable with my particular sierra gear so to verify everything I plugged both wings together (with out the fues) and placed them in position than ran a axel size rod between them and set them at 0 degrees tow. It turns out that the blocks were perfect so no adjustment was required and the gear was installed centered in each slot.
YMMV
Sparky
Old 02-09-2020, 08:21 AM
  #744
n8622t
My Feedback: (8)
I put the wings on first then adjusted the shims as needed...what I found is the shims changed the camber and the gear needed to be shifted to adjust the toe in. All this changed the location of the wheels on the wheel well, so your best bet would be to start with the wings on and find that sweet spot with the toe in
Old 02-09-2020, 11:30 AM
  #745
n8622t
My Feedback: (8)
Right side done...started on wings
Old 02-09-2020, 01:48 PM
  #746
n8622t
My Feedback: (8)
Getting a little closer...had to think about how I had these together
Old 02-10-2020, 12:48 PM
  #747
elmshoot
My FW-190 has a white belly so I am busy painting things white. landing gear included and all the ancillary hardware as well.
Today I put the wings on the plane and ran into a problem the wing wouldn't go in completely like it was hanging up on something.....
I think my rear wing tubes are too long. The front wing tube is 21 1/4" long and the rear wing tube is 12 3/8"
Someone measure yours. I can see the rear tube hitting the other tube on the centerline of the fuse. as I tride to slide the wing on the fuse.
Before I cut about 1/2" I just want to double check things.
They slide into the wing a little less than 6" and are symmetrical from the right and left side.
All the normal checks have been done.
Sparky
Old 02-11-2020, 11:34 AM
  #748
n8622t
My Feedback: (8)
One wing down and one to go
Old 02-11-2020, 11:38 AM
  #749
n8622t
My Feedback: (8)
Left side...right side next
Old 02-11-2020, 06:31 PM
  #750
n8622t
My Feedback: (8)
Callie redid these graphics...they’ll go on tomorrow
