Reload this Page >
B-29 SUPERFORTRESS BUILD
Old 05-26-2013, 12:17 PM
  #201
Warbird Man
My Feedback: (95)
Warbird Man's Avatar
Default RE: B-29 SUPERFORTRESS BUILD THREAD
Unfortunately no. Just haven't had the time. But, as soon as I get the Corsair off the bench and into the trailer it will free up some work space and I'll resume the B-29 build as it takes up a lot of room.
Old 05-27-2013, 12:04 AM
  #202
trisdisp57
I can understand that, definitely is a big bird. I'll be watching hope you continue with the build thread, got some good ideas and techniques from watching you build, newer to the hobby scratch building a C-130 with a 65" wingspan. Hope to build a B-29 after
Old 07-30-2013, 09:35 AM
  #203
robwoody
Have been building a Don Smith 169 inch B29 since Easter, the wing is well on the way. I have fitted the 4 DLE 20cc motors, there is a built in 3 degrees down thrust but I can not find any reference to side thrust. Having built a 14 ft Catalina, both motors 3 degrees thrust out wards & a 12 ft 6 inch Spruce Goose, all zero side thrust (figured if you lost one, there's still 3 so it hardly matters, proved correct). Could someone advise me on this. I was also wondering if 4 bladed props have been used on the DLE20's & what size & pitch.
Old 07-30-2013, 11:46 AM
  #204
acdii
You may want to look at the gas engine thread in regards to the prop on the DLE20.  I can tell you a 3 blade 15x8 MAS puts quite a load on the DLE20, so even if you are swinging a small 4 blade, it may not have enough power.  The DLE20 with a 16x8 has very good power, and a 17X8 is also pretty good, and one of the recommended sizes, so going off those two sizes, you might be able to find something similar. I use an APC for the 16X8 and XOAR for the 17.  Good idle, and good top end.  The 15X7x3 did work, but top end was a bit low, so it "might" work on this model.
Old 07-30-2013, 12:51 PM
  #205
D_wilbur
My Feedback: (8)
D_wilbur's Avatar
Hello Robwoody
I have started building 169" B-29 last year I have the fuse and tail feathers built. started on the wing and noticed issue with the Robert landing gear fitting in the nacel. started removing ribs and formers to correct the issue and lost interest for the time being. I have DLE engines as well. Let me know what you end up doing with the thrust. If I recall correctly I thing the fin is offset to compensate for the engines not having right thrust.
Old 07-30-2013, 02:39 PM
  #206
All Day Dan
All Day Dan's Avatar
The counter clock wise rotation of the engines develops left torque. I do believe that, on the full size, the left side of the B-29 vertical surfaces have a lifting airfoil to offset the torque of the engines. I am not sure about the model though. You can always use the rudder. Dan.
Old 07-31-2013, 08:46 PM
  #207
Warbird Man
My Feedback: (95)
Interesting thought. I haven't found any reference to the rudder or engines being offset. I'll probably off set my engines a degree or two and leave the vertical stab straight. Been working on the bomb bay doors and got them fit. They are removable.
ID:	1905203   Click image for larger version
Old 08-01-2013, 05:04 AM
  #208
acdii
Thrust angles are a good thing to watch for. Reason I say this is my friend built a scale model of his Cessna 140, To scale.  That was his mistake, he didn't offset the engine and cowl, or the rudder angle to overcome the P-factor. His maiden flight ended rather quickly as the plane flew left on takeoff. It flew very nicely straight and level, but to the left. It went behind a tree, and he chopped throttle after he lost sight of it.  Had he kept throttle on it would have circled the tree, flew over the roof of his barn, and he might have been able to recover it.   He doesn't fly much rudder and that I think doomed this flight, he might have been able to straighten it out, since ailerons weren't doing jack other than keeping the wings level.
His mistake was not providing enough offset for the engine thrust, so seeing it first hand, really makes an impression....so did his plane, in the ground.
I have a new 4*120 with DLE20 on it, and noticed that I need to add a couple washers to the left mount to correct the left veer when the tail wheel comes up, I had forgotten about that from the first one when I built this one. It just needs a slight correction to the right.  Maybe when you do taxi tests with it, getting the nose wheel off with mains on the ground will give you an idea if you need to add thrust angles. I dont fly Trikes, so dont know how else you can find out if you need to adjust the thrust.
That does make me wonder though, on a multi engine plane that doesn't have the prop in front of the rudder, how does P-Factor affect it?   If all four engines are 0* thrust, and properly synched, would it even be a factor?  My only experience with twins is my Twin Otter and it came as an ARF.  Would thrust angles be added in the event of engine failure?
Old 08-01-2013, 05:07 PM
  #209
Warbird Man
My Feedback: (95)
The "P" factor is simply the torque of the engine causing the plane to "yaw" to the left. This can be a serious issue with twins if there is no off set of the engines to compensate for it and if you have an engine out. The arf probably has it already built in. I'm sure it will also cause a 4 engine plane to yaw a bit as well. But with the very large vertical stab and long wing span of the B-29, it might not be as critical. I will definitely put a few degrees of right thrust on the engines.
If anyone out there is still flying one, feel free to comment on how the plane acts and if you have any right/ down thrust compensation with the engines and how much.
Old 08-25-2013, 06:52 PM
  #210
Warbird Man
My Feedback: (95)
RUDDER:
Some have asked me in the past how I plan on hooking up the B-29 rudder in a scale manner. The plans show burying the servo in the tail and setting up / attaching the linkage to it before one finishes strip planking the fuse. Also there is the problem of attaching the rudder to the pivot rod the rudder hinges on. I'm not a fan of burying anything and I like to have all components removable if necessary. I also like to keep the tail as light as possible. So this is what I came up with.
I cut out and made a removable hatch underneath the tail for the rudder rod to slip up from the bottom. I made up a little bracket with a 1/8th wheel collar silver soldered to it that is mounted in the bottom of the rudder. Once the rod and rudder are in place, I can tighten the set screws which secure the rudder to the rod. Then I have a steering arm attached at the bottom of the rod to control the movement of the rudder. The rudder servo is now located in the rear bomb bay with a HD push rod to the tail. Sounds simple enough? See pics.
ID:	1913153   Click image for larger version
ID:	1913154   Click image for larger version
ID:	1913155   Click image for larger version
ID:	1913156   Click image for larger version
Old 09-08-2013, 08:43 AM
  #211
Warbird Man
My Feedback: (95)
The flight control surfaces on the B-29 were fabric covered. (rudder, elevators & ailerons) The kit controls are fully sheeted so to simulated the ribs I added some rib tape to the elevators and ailerons for a little more detail. The rudder when built came out undersized. So I had to add some length to the back. I also added some balsa strips to simulate the scale ribs locations ( see previous post pic) and covered with fabric.
ID:	1917833   Click image for larger version
Old 09-28-2013, 10:10 PM
  #212
Warbird Man
My Feedback: (95)
Well after spending the last couple of weeks of just "prime fill and sand", I finally got the plane back on it's feet. Getting close to painting but first I need to finish setting up all the engines and fitting the cowls. The real trick is going to be how I'm going to fit a fuel tank, ignition module, ignition battery, switch, fueler, and throttle servo in each of the nacelles. Definitely gonna be a tight fit.
ID:	1925751   Click image for larger version
ID:	1925752   Click image for larger version
Old 09-28-2013, 10:26 PM
  #213
Chad Veich
My Feedback: (60)
Looks fantastic WM.
Old 09-29-2013, 01:32 AM
  #214
Lifer
Lifer's Avatar
Very nice!
Old 09-29-2013, 05:09 AM
  #215
tevans55
WM-
I have a very similar setup to yours on my B-25. I have Century Jet retracts with Robart wheels and brakes. They work great together. I set up one battery in the fuse that runs out to a charge/switch on the side of the nacelle and then to the ignition. That saved plenty of room for tank and ignition and allowed for one very large battery. You could use 2 batteries linking your inboard and outboard engines together. That way you only have to charge 2 batteries and they can be charge from either side of the plane. With your removeable wing/engine setup you could put both switches on the inboard nacelle. Just a thought.
By the way, Bruce can easily add an inch to that gear if you need it. Really enjoying your build...lots of good ideas!
Old 09-29-2013, 07:57 AM
  #216
acdii
Awesome. just Awesome.
Old 09-29-2013, 08:31 AM
  #217
Warbird Man
My Feedback: (95)
Thanks guys.
T-55, I thought about that but I'm skeptical of radio interference from running ignition battery leads down the wings. Did you have any trouble with your set up?
Bruce is a good guy to work with but it's way too late in the build to change the length of the struts. The wheels when retracted just barley fit and are 1/16th away from the formers as is. And I would have to put even smaller tanks in the nacelles. Another reason to build the 14' er. over the 12. One should be able to put the tanks in the wings at that size.
Old 09-29-2013, 04:25 PM
  #218
tevans55
WM-
No problems with this setup. The battery is actually in the bottom of the nose gear well and the wires run through the fuse to the wings and then out the wing to the nacelle and plug into the switch and the switch goes to the ignition. the battery/ignition wire also runs together with the choke and throttle servos through the wing. Never a glitch! I'm using a 3500 mAh SR NiCd for nose weight I have 2 battery outputs for the ignitions.
Old 09-29-2013, 04:51 PM
  #219
warbird_1
My Feedback: (61)
warbird_1's Avatar
did you ever consider going electric? i think that would be awesome. loads of power . WB_1
Old 09-30-2013, 06:33 AM
  #220
invertmast
My Feedback: (23)
invertmast's Avatar
Everytwin i have ever built or flown has had 0 degrees side thrust on the left engine(s) and 1 or 2 degrees right thrust in the right engine(s).
You will never be able to get rid of P-factor in the design of a propeller propelled plane, its just not possible (until you go to jets). The only way to limit and counter-act P-factor is by learning to use the rudder, that stick still moves once the throttle gets to full!
Old 10-01-2013, 02:48 PM
  #221
Warbird Man
My Feedback: (95)
I was thinking about the same thing. zero right thrust on 1 and 2 (left engines) 1 degree on 3 and 2 on 4. I'll put 1 degree down on all. (if that make any sense). As far as electrics, that might be easier but just not into them on anything I can fit a gasser on.
Old 11-19-2013, 10:33 AM
  #222
Warbird Man
My Feedback: (95)
Ok, it took awhile but I got all 4 engines mounted with proper thrust angles all centered in the cowls. All 4 cowls mounted, opened up the cowl flaps and made 4 exhaust and choke systems.
ID:	1940596   Click image for larger version
ID:	1940597   Click image for larger version
Old 11-19-2013, 01:27 PM
  #223
acdii
Where did you get that exhaust from? Looks like it was made with copper pipe fittings? Looks really good too.
Old 11-19-2013, 02:22 PM
  #224
Warbird Man
My Feedback: (95)
Thats correct. But one must "braze" not solder them together as silver solder wont hold up to the heat of the exhaust.
Old 11-19-2013, 09:59 PM
  #225
lightning 759
lightning 759's Avatar
What he says looks terrific
Andy
