Reload this Page >
CMP 80" Zero Bash*****
Old 11-12-2012, 06:26 AM
  #251
bicyclemonkey
My Feedback: (7)
bicyclemonkey's Avatar
Default RE: CMP 80
What's the preferred retracts for this plane?  I have one that's been in the box going on two years now.
Old 11-12-2012, 06:51 AM
  #252
glazier808
glazier808's Avatar
Default RE: CMP 80
Looks like CJ has them listed for this model. I have not ran across any others specifically made for it so far. $380.00 for the set, not bad!
http://centuryjet.com/product_info.p...oducts_id/1083
Casey
Old 11-12-2012, 07:02 AM
  #253
BubbasanJohn
BubbasanJohn's Avatar
Default RE: CMP 80
Yeah CJ's retract are droP in place for the cmp Zeke. Thanks for the kind words on the new paint. I am nothing compared to you guys skill level. That's why I fly fast and high, so no one sees my sloPpy work.
Old 11-12-2012, 09:44 AM
  #254
77chickenhawk
77chickenhawk's Avatar
Default RE: CMP 80
I don't understand the whole drop-in thing for the CJ retracts. Because the wing landing gear mounting blocks are in the wrong location so I don't understand how you can just drop those. From my experience No matter what gear you have you have to bash the landing gear section of the wing
Old 11-12-2012, 10:06 AM
  #255
warks62
My Feedback: (140)
warks62's Avatar
Default RE: CMP 80
ORIGINAL: 77chickenhawk
Century Jet maybe making a drop-in replacement with struts that work. I agree that it would be better to put the gear blocks in the correct position for a couple of reasons. One looks better and also the stock gear mounts are kind weak, and would be better to make new ones anyway.
By the way Yellow Aircraft Zero is the same size at 80" wing span so the Sierra gear should be the right size but would need to make new gear mounts to make them work.
Old 11-12-2012, 11:57 AM
  #256
BubbasanJohn
Default RE: CMP 80
really dont know what more to say about the CJ retracts. Bought them in. Installed on rails and done. Dont know If I have a different production version of the CMP 80" than the rest of y'all. was a while ago. Could be worng, but the only time I've ever been wrong whas when I thought I was wrong but I was'nt
Old 11-12-2012, 01:44 PM
  #257
glazier808
glazier808's Avatar
Default RE: CMP 80
BubbasanJohn,
Do you have a shot of yours showing the stance of the CJs installed? The pic you posted earlier just doesn't show the gear.
Casey
Old 11-12-2012, 02:46 PM
  #258
BubbasanJohn
Default RE: CMP 80
Casey, here are two of the best I could find ATM,
ID:	1819803   Click image for larger version
Old 11-12-2012, 02:51 PM
  #259
Check6
My Feedback: (427)
Default RE: CMP 80
I have a CMP Zero that needs a new canopy. Where can I get one? Also my Zeros' wingspan is 82 in. Did they have two sizes?
Fred
Old 11-12-2012, 03:07 PM
  #260
warks62
My Feedback: (140)
warks62's Avatar
Default RE: CMP 80
Not sure because they advertise as a 80" but gives specs of 2100mm which translates into 82" but not a big deal. Wouldn't be the first time.....
Old 11-12-2012, 03:17 PM
  #261
BubbasanJohn
Default RE: CMP 80
Fred, might want to call or contact nitro hobbies. I think spare parts are hard to come by. I emailed CMP about spare parts but never got a reply.
I beleive there is only one size 80 inch zero. 80 or 82, I've never measured.
Old 11-12-2012, 03:54 PM
  #262
Check6
My Feedback: (427)
Default RE: CMP 80
What about a Yellow canopy? Might be very close. I'll try calling Nitro first.
Fred
Old 11-12-2012, 04:03 PM
  #263
Michel
Default RE: CMP 80
Hi 77chickenhawk
I went quickly through youre thread ,....................................... well done ,...................... a dieing breed .
Michel
Old 11-12-2012, 04:21 PM
  #264
Aluminum Overcast
Default RE: CMP 80
Why not vacuum form the canopy in 3 parts? Small work pieces and the option for sliding canopy. Plus less costly and complicated replacement of only the damaged parts not the entire thing should anything happen!
On the gear: I bought the Yellow Aircraft ones as the CMP zero is only an inch or two larger so, pretty much the same scale and the struts are very scale in how they work. My build on this model begins this winter. I had to complete my P40 and fly her all last summer. Now that that is out of the way I really can't wait to begin this build. Over the last few years I have acquired all the servos, switches etc. needed..... My ASP 400 Radial is even broken in too!
Old 11-12-2012, 04:25 PM
  #265
Aluminum Overcast
Default RE: CMP 80
Hmm my pix did not attach to my previous post....Here are a few pix of the P40!
ID:	1819826   Click image for larger version
ID:	1819827   Click image for larger version
ID:	1819828   Click image for larger version
ID:	1819829   Click image for larger version
ID:	1819830   Click image for larger version
ID:	1819831   Click image for larger version
ID:	1819832   Click image for larger version
Old 11-12-2012, 04:30 PM
  #266
77chickenhawk
Default RE: CMP 80
Thanks Michael I'm glad you like it Your compliments are much appreciated
Old 11-12-2012, 06:12 PM
  #267
BubbasanJohn
Default RE: CMP 80
Chickenhawk , Ithink I did post it in an ealrier post but I have to say I agree your zero is sweet.
Aluminum Overcast ( any relation to the still flying b-17), your p 40 is simply un-freaking-beleivable!!!!
Old 11-12-2012, 07:44 PM
  #268
Aluminum Overcast
Default RE: CMP 80
Thank you. Just trying few theories about scale representation on a model and personal growth. The P40 has some interesting things like custom machined oleo struts & wheels, functioning gill flaps, custom made exhaust stacks, sliding canopy with the pulleys and recessed mechanism, etc.,. Fun stuff to figure out and execute. All that was is in prep for the CMP Zero build this winter, and that is a prep for something more in line with my Aluminum Overcast handle....If all goes as planned a huge 210" B17 with 4 asp radials so the zero with it's singe ASP radial is a stepping stone as was the P40. The B17 will take a few years to complete so we'll see how it goes. Can you imagine the combined sound of 20 cylinders of 4 stroke music? It's a dream that I would like to realize some day.
link to my ASP break in: love the idle at 9:06 along the time code!
http://www.youtube.com/watch?v=LK1jF...9&feature=plcp
A little more on the P40.... Flying at the beginning of vid then mods begin at 5:37 in the timeline
http://www.youtube.com/watch?v=2Uk0J...1&feature=plcp
Old 11-12-2012, 11:52 PM
  #269
BubbasanJohn
Default RE: CMP 80
Very nice. Cant wait to see the b-17. I was lucky enought o hop a flight on the full sized aluminum overcast when it flew thru california. 4 Wright radials! What a sound.
Old 11-13-2012, 06:28 AM
  #270
bicyclemonkey
My Feedback: (7)
Default RE: CMP 80
Wow, I bet it won't take long to go through a gallon of glo fuel with four of those radials!  What size fuel tank will you use?
Old 11-13-2012, 06:41 AM
  #271
glazier808
glazier808's Avatar
Default RE: CMP 80
Amazing work as always AO. I'm looking forward to your bash on the Zero as well....I must say though....this thread has really set the bar!
I love how he calls this amazing Zero of his " a daily flyer " like its some old beat up foamy lol.
Not saying it won't be a daily flyer, but jeez....my daily beater doesn't look like I pulled it from a historical aviation mag lol.
Casey
Old 11-13-2012, 07:02 AM
  #272
77chickenhawk
Default RE: CMP 80
Aww. Glazer808
You are to kind with your words
Old 11-13-2012, 07:30 AM
  #273
glazier808
glazier808's Avatar
Default RE: CMP 80
I would love to be there when someone asks what kit it is.......
Just tell em....it's just an old Chinese $299.00 ARF!
LOL
Casey
Old 11-13-2012, 07:54 AM
  #274
77chickenhawk
Default RE: CMP 80
Hahaha. That is exactly what I say... LOL and they just look at me with a funny look on their face
Old 11-13-2012, 09:22 AM
  #275
BubbasanJohn
Default RE: CMP 80
You Mean they look at you with their chins dragging on the runway apron! I would. NOT call that funny look but serious envy!
