Go Back  RCU Forums > RC Boats > Speed - Electric
 PROBOAT APACHE 24 >
PROBOAT APACHE 24
Speed - Electric For all your electric boating needs.
PROBOAT APACHE 24
Old 01-01-2010 | 07:51 PM
  #101
Default RE: PROBOAT APACHE 24
http://www.youtube.com/watch?v=YfbjXaCo_To   This was just playing at about half throttle with my buddies shockwave 26 with him on lipo for the first time.</p>
Old 06-11-2010 | 11:50 PM
  #102
My Feedback: (30)
I just purchased the Proboat Apache and I'm having problems with cooling the motor. I installed a fan on the esc, which is fine but the coil is not keeping the motor cool. I burnt up the stock motor in 10 mins. I installed a 27t motor and having the same  issue. I'm at the point of getting rid of the boat. Any help would be great. Thanks
Old 08-20-2010 | 10:26 PM
  #103
cdlowe try to adjust your water pickup and be sure when your running water is comeing out. sounds like your not picking up water or you have a pinched water line
Old 08-20-2010 | 10:41 PM
  #104
My Feedback: (30)
Thanks for the info. I ending up installing a electric fan on the motor. That seem to take care of the problem. Got rid of the boat any way. Just got another Shockwave 26 again. Also got rid of Aquacraft Supervee 27R. What would be a good brushed motor and battery setup to use with the stock esc. Last Shockwave used Villian 550 motor and purple octura prop with 3 cell. Got approx. low 20 MPH. Thanks for the help.
Old 08-20-2010 | 10:46 PM
  #105
Go to G-Freak racing . com and check them out I have been running castle creations esc and motor in my apache 24  but in my new boat im going to run all g-freak
Old 08-22-2010 | 06:58 AM
  #106
Hi
I can advise you about the props. We do need your propshaft dia though. For your size boat with a ungeared car motor, props from 31mm to 35mm can work. The most used metal prop for this would be a Octura X432. It has a 1/8" drilled hub. A Octura plastic X431 is also good and cheap too. Its good your wires unsoldered form the motor. That likely saved it from burning out the frist two min. you ran it. Also you are overvolting the motor. I will not last long that way.
n.h.schmidt
Old 09-20-2010 | 08:45 AM
  #107
Newbie here, know next to nothing. The manual say to use a 7.2v Ni-Cd battery (on the apache 24), can Iuse an Ni-Mh, and is there an mAh that is to powerful that might damage the electronics?
Thanks in advance.
Old 09-20-2010 | 09:51 AM
  #108
shenlonco's Avatar
Hi you can use any size 6 cell nimh battery pack.
miliamp size does not matter the larger the # the more run time you will get and a little better performance ... try to at least get a 3300mah pack or higher and remember a good quality pack will make your boat run better.
Old 09-20-2010 | 12:12 PM
  #109
Hi there, yet another noob I'm sure you guys are ecstatic. There is so much info on this site and I am having trouble piecing info together to apply it specifically to my newly purchased Apache 24. If anyone is knowlageable on the specific application in mods for this boat Iam all ears. Took it for it's maiden voyage today, it was fun but soon realized Iwant more speed. I've gathered the two obvious things to achieve higher speedsare bigger motor and the right prop.
Icame across a post that saida S-600 could slip in easily to replace the stock 550 without having to recoil a new water cooling system. As of right now I'm wondering can Igain moderate to significant speed with the stock set up by simplygetting the right prop?Would it be worth the roughly $15 to get slightly bigger motor, if Iupgrade the motor does this mean Ihave to pair a prop accordingly or can Iget the same size as stock (metal of course)with a better pitch.
Additionally what is a typical run time for the stock set up. Iran two batteries through it with about a 10-15 min break between the runs, and noticed the amp (or think is the ESC) was real hot. The motor seemed fine as it's water cooled. Is there an if than rule to mods, i.e. if Iupgrade X then Imust upgrade Y?
Thanks for your patients and inputwith this noob and sorry if this presents as a repeat,and Iattempting to search for my answers but there areyears of post on this threadand Ilack the time to go throughit all sonothing Ifound that adressed my specific questions. My appologies for also posting this in the General Boat Discussion, just hoping to get informed soon so Ican put it all together!
Old 09-21-2010 | 07:46 AM
  #110
shenlonco's Avatar
Try a carbon fiber 40mm graupner prop offshoreelectrics.com sells them.
you may have to buy a prop adaptor to use it ( all it is is k n S brass tubing )
Old 09-21-2010 | 01:51 PM
  #111
OK, so Iwas running the Apache 24 today. Iwas using a new5000 mAh battery. It ran great for about 10-15 min Ichecked for anyover heating and it seemed pretty cool, Ithenran it for about another 5minand all the sudden stopped. Luckily it's a private lake and Ihad a paddle boat to fish it out, but when Igot close it started running in reverse on it's own, subsequently it took on water and went nose up. got it out the prop was still spinning untill Iturned the switch off. Everythinggot wet, Iplan on letting it dry out for a couple days. Is the battery trashed since it's been submerged or should it still be safe after a few days of drying out?Any problem solving on what happend why it ran in reverse on it's own after stopping dead with no sign of the batter being low i.e. no bogging down or reduced speed.
Old 09-21-2010 | 02:33 PM
  #112
shenlonco's Avatar
let it dry out for a few days all should be fine.... look at your throttle trim knob make sure it is set to nutral you may have moved some how and that's why it went in reverse...also maybe you got radio interfearance or something.
Old 09-21-2010 | 05:10 PM
  #113
Shenlonco, Thanks for taking pitty on my dumb arse. If there is anything in the fire arms department Ican help you with let me know.
Old 12-13-2010 | 03:03 PM
  #114
Where did you get the flex shaft? What is the measurement on the flex and prop shaft? Im working on upgrading my apache as well. Any info would be helpful thanks.
<br type="_moz" />
Old 01-23-2011 | 09:21 PM
  #115
wooterair's Avatar
My Feedback: (8)
I went to lube the drive system tonight, stock apache, ran boat 7 or 8 times all in fresh water. Are the set screws on the motor coupler, drive dog and u-joint are royal pain to break loose or did I miss a memo somewhere? I had to drill the set screws and was using a good 1.5 mm hex wrench. Should I have loosened them/retightened them prior to running? Bought boat about ten days ago. Is there a better driveline harware out there without having to add another rudder? Am I correct in thinking if you go with a flex cable, the stock rudder needs to be locked straight?
Old 02-15-2011 | 08:12 AM
  #116
I should be getting an apache in a few days I ordered the new 2.5ghz version , my question is if I put in a castle brushless motor for a car can I run the same coupler and shaft because the shaft on the brushless is the same size as the 550 .
Old 02-15-2011 | 04:01 PM
  #117
The shaft is the same and it should work. But why use a castle motor in it when a cheap $19 one from HK will work. It should move very well with this on 2S [link]http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=6527[/link] or this one if you want to get crazy [link]http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=6530[/link]
I run the 2600 in my Widowmaker on 2S and it scoots along pretty good considering it's such and unstable boat. Here is some video. [link]http://www.youtube.com/watch?v=4UkYONC_OhU[/link]
If you go with a 5MM shaft motor you can use the Shockwave BL motor coupler. I think they're like $3 or so.
Old 02-15-2011 | 04:17 PM
  #118
so the 5mm shaft coupler will work , because I really dont want to change the drive shaft if I dont need to . I dont think the apache comes with a flex shaft
Old 02-15-2011 | 04:24 PM
  #119
which one of those inrunners with the 2mm shaft is good ? Nice video buy the way .
Old 02-16-2011 | 06:53 AM
  #120
Well I was looking at these. Wha are your thoughts
http://www.hobbypartz.com/07e-c-sl-10t-2848-blue.html
http://www.hobbypartz.com/07e-c-seaking-60a.html
Old 02-16-2011 | 09:56 AM
  #121
That motor is too small. It's a 28mm, diameter, motor. Though it might push this light hull around it will draw too much power trying to do so. You're looking for a motor that is 36mm in diameter by 56mm in length, minimum. Anything smaller will be a waste of your money.
Old 02-16-2011 | 11:04 AM
  #122
Thanks for the help how about this?
http://www.hobbypartz.com/3330kv-rc-...car-motor.html
Old 02-16-2011 | 11:08 AM
  #123
Or how's this
http://www.hobbypartz.com/96m10-car-2848-3000.html
Old 02-16-2011 | 11:48 AM
  #124
The first one you posted will not accept a cooling sleeve because of the fins. The second one you posted is a 28mm motor which wont work.
Is there a reason you don't want to use the Hobby King motors I linked you to? I searched that site and other than the boat motors that are backordered, none others will work. Just get the motor coupler for the Brushless Shockwave and you wont need anything else for the drive. You don't have to change the drive wire. Just the coupling.
Old 02-16-2011 | 12:26 PM
  #125
Ok I'll do that than , should I get h.k 120 esc ,? Or is that over kill
