Aquacraft Super-Vee 27 Nitro.
#527
My Feedback: (12)
SC
RE: Aquacraft Super-Vee 27 Nitro.
ORIGINAL: MOVMX Racer
Mine is bent a lot more than that. I don't know how it got bent, and I am not sure where to get another one. I really wan't to get the boat repaired, so if i could get an answer as to where to get one, I get it and have my boat ready for the water again.
#528
My Feedback: (12)
SC
ORIGINAL: ghostracer
Has anyone tryed a .21 engine in the supervee?
#529
My Feedback: (12)
SC
Okay that settles it. I will check my stocks of tubing, and order a couple flex cables. Could I maybe build a fiberglass box? I have stuff i can use for a form to glass, that might work better that wood for me!
#530
I gave my broken radio box to a friend who is going to do a CAD design of it. We may produce them through my sisters company, laser cut in lite ply.
#531
RI
hi guys,, ron i have the same tabs,, but i cant keep it running long enough to adj them lol.. keeps dying after a few min running in the pond.. checked the fuel lines and tank.. all ok.. did find the carb line was kinds close to the motor was thin king the fuel was getting to hot,, moved it but havent had the time to get back to the pond to check it,, any ideas guys?.. anyone else havint the same problems? ... mark
#535
FL
I think the boat has much protental in fort pierce there getting the electric over 60 mph why can't you push the gas that fast I have already got the boat stable as can be but how much can you really push it?
#536
MO
Well, on my bending the tube, I think it was mainly my fault, as it started to pull out when I was trying to remove my flex cable. I tried to push it back in, and it wouldn't budge, so I pulled it out and it was bent pretty bad. Needless to say I was a little... *upset*[:@], so the entire thing, flex cable, shaft and all (excluding prop shaft, prop, etc) is long gone. i will just replace my tube and cable, and be much more careful next time.
#537
JD
#539
RI
ORIGINAL: Ron Olson
If it's stalling after just a few minutes of running, try richening the carb just a little more to see if that helps.
#540
RI
anyone else having a problem with there hull cracking in the right side? about half way down? i looked inside and its where it thins out a lil from the gunnel,, liiks like a desine flaw,,,it goes from bow to stern,,,i was whiping it down to do some flame decales saw it then,,, if it had the stock stickers on it i dont think it would have been seen,,, everyone should check,,,the glass feels real thin there,,,ill mark it with some tape or something and post a pic later,,,its still under warentry but damn whah a pain,,,big pain if they want to old hull
#542
RI
i looked close at it the whole right side is thin,,like its missing a layer of glass,,ill notify them ans see what they say,,,
#545
RI
well ... i went a lil more neg with the strut,, and went one turn down on the trim tabs,,big differance,, got up on plane faster, now remember the pond iam going to is only about, 100 ft long,, best gps was 25.6 today got up to 28.8.. just when she got going had to back off, going to the big pond monday,, and see what i get for a max speed....
#546
MO
I didn't notice any weakness on my hull, but my cowl is now cracked...(I stepped on it...)
I will get some parts soon, but grabbing a renegade rigger may take priority...[X(]
Any news on the new pipes or pill bottle muffler yet?!?!
#547
RI
well fliped her today.. that was exciting lol did another turn down on the trim fins think it was two much was slower than yesterday..git her home ant she started up after two pulls,, so i guess its getting better lol
#548
RI
ok question.... i just joined the RCU vid thing,, i copyed one there easy,, but how do i send to a post here? anyone know? thanks mark
#549
MO
Well, since I got no reply on the muffler question, I made my own, I will test it when I get my boat back together. I cut a 3 inch long piece of 1/2 in. PVC and then made an endcape, not sure what it is, but it was lying around. I then cut a small piece of fiberglass silencer packing (stuff used in dirtbikes, etc., similar to this : http://www.denniskirk.com/jsp/produc...fCatId=&mmyId=) and pulled it apart until it was "fluffy" and stuffed it in there. I then epoxied the cap on, and painted it black. (dont laugh) My only test I could to was yelling into it, and it seems to work well. I will update when I test it.
#550
RI
