Is the Traxxas T Maxx reliable?
#102
RE: Is the Traxxas T Maxx reliable?
i think tmaxxas are unbeatable trucks when hopped up and if you are an absolute glwo engine expert, then it should be very reliable but the 2.5 is tricky to tune if new or have even some experience with glow engines. it'll break more often than a stock savage because it is faster and 1/10 scale and lighter. every time i go into my lhs, some hjas there tmaxx in there bein worked on, not a good sign to me. thats just my opinion!
#103
i would ahve to say that it is definitly the BEST platform, for a truck, racing ot bashing. if you know what you are doing then it will be reliable, i have personally had minimal problems and none with the stock engine. the savage might be an easier truck to learn on though. but neither the trx 2.5 or the t maxx are POS's like some claim they are. it is 99% of the time the owners fault.
bubbafien
bubbafien
#104
See thats the thing.....its just like the old tamiya hornets !...they are light and pissing fast with a hot engine(I actually like the TRX2.5, its a diamond/fluke in the rough [:-]....so I have never said a bad word against it .... I think the truck its self is POSish)..... The problem comes when you touch somthing or try to be a little rough with the truck/car it breaks !... sure it can take a few knocks, and survive, or so you think... for now ! The T-Max plastics and driveline are totally tyco/Radioshack/K-Mart type stuff, they suck and break frequently... you really need to spend some serious cash to make it run for more than about 3 gallons, I think that once you hit 3 gallons the crappy plastics, metal gears, bearings, alloy and design will be fully fatigued and breaking like there ain`t no tommorow. Soooo then you go aftermarket .....hop-ups so they say.. more like candy really ! I bet big money that everyone that has said they spent $600 on thier T-Max and now its bullet proof has REALLY spent closer $1000-$1200...and even more !!!, I know whats going on so don`t even try it on for size [X(]...I try to fool myself some times too .
If traxxas(and I have been waiting !) did what just about everybody(including the traxxas forums moderaters !!! Ha !) MUST do to thier T-Max not far down the road from new, and that is put a FOC, better plastic(RPM or proline) suspension, shock towers, body posts, bulkheads(VERY poor design) and then maybe raise the bar even further and fix/improve diff cases, tranny case, tranny gears and better steel&machining in the driveline gears and bearings(up the size and modify truck to suit in the diff side gear area) they would have a serios, serious market share/domination.....and a lot of happy maxers, they could even up the price a fair bit and still have no complaints.
The T-Max is a made in tawian POS.... its a throw away truck and or a money pit. It sounds like you T-Max defenders are yet to learn your lesson... do it the hard way if you must
TM
TM
#106
The thing that makes me laugh is (some) people that have the t maxx will defend it to the bitter end. These people remind me of some kind of old man and his 1928 model T ford saying/babling about how good it is... the model T might have been a good car back then but things change and progress, tech advances and products get better over time. The t maxx had its day and I suspect over time it will wind up in the same place as the traxxas nitro hawk / model T ford.
#108
the gears in diff gears in the maxx are not weak, actually they are stronger than rrp's. i have not broken 1 thing on my maxx and i have roughed it up. (plastic diff cups are a weak link, i have broke those). but are you trying to tell me aht you have your truck (whatever it is) bone stock? no, i doubt you do.
bubbbafien
bubbbafien
#109
The diff gears are stronger than rrp gears..ahahahahahaahaa thats funny ! they may be stronger than some aftermarket crud, but they still suck ! Its the whole diff design that sucks, the bearings and totally inadaquate and not protected from dirt ingres. Is my T-Max truck stock @!.. of course not ! it had to be fixed/improved so I could drive it at all !
j-maxx - yeah maybe if you spend TWICE(or more) the trucks value on parts you could have a good truck....but I`d rather have a buggy, a Savage and an on-road car than a expensive piece of crap T-Max.
Is my Savage stock would be a better question !....and altho I have installed a powerful engine it IS still bone stock otherwise !!!!!! Completely stock and it rocks...and gets the crap thrashed/jumped/crashed out of it and comes back for more.
I can also see it being stock for a long time yet... it doesn`t need any upgrades !
TM
TM
#110
you can ask anyone who has any experience, because you obviously don't. the trx ring and pinion will last longer than rrp.
bubbafien
bubbafien
#111
hahaha Look dude... I know all about the T-Max diffs, and I never said the RRP gear was stronger that the TRX, its actually a higher tensile steel in the RRP gears and thus brittle, so it looses teeth...unlike the TRX which will get worn down eventually. The diff will only survive using the TRX gear sets if you use alloy cases and expensive boca green bearings. My point is that they still suck and will break whichever way you look at it so its still a pile of crap.
The T-max blows chunks
TM
TM
#112
OR....learn to tune your truck! it is called shimming your diffs. if you cant do this then it is likely that you cant do other things as well either.
bubbafien
bubbafien
#114
ORIGINAL: bubbafien
bubbafien
bubbafien
Blow it out your arse, YOU don`t know what your talking about and it sounds like your 12 years old too(no offence to 12 year olds with a decent attitude and that are not in denile about thier T-crap weaknesses).
TM
#115
we are talking about gears not cups. ring and pinion. and we never said anything about a .21, did we? the RING AND PINION will hold up. the plastic cuo and screws wont.
the price you pay for sm parts is not that expensive. it is stronger than anything else on the market, and almost as light as stock.
cvd's are worth the money. 1 set of SM cvd's or fixing MIP 5-6 times, which cost less? exactly...
bubbafien
bubbafien
#120
hey Accident...ever thought it's not the engines fault its not running right, maby its your fault. A good R/C nitro driver can proporly tune their engine. And even if you do have the correct needle settings, it could be from you not treating it right. Overheating, unproper break-in, bad fuel, dirt inside engine...the list is endless
#121
only thing i dont like about it is the dam carb sticking. its because of me when i first got my MS airfilter it fell off when i noticed..it was to late and now i need a new car body thing.....I HATE COMPSITE CARBS!
#122
you probably need a new piston and sleeve also, maybe bearings. ever notice, that the best carbs made are composite? hint: novarossi
bubbafien
bubbafien
