WildHare R/C Support Disscuss WildHare RC products in this forum. Please note, answers may be provided by Tom Fawcett (owner of WildHare RC) or by the general membership.
Composite Sukhoi
Old 04-27-2005 | 07:07 PM
  #76
P-51B's Avatar
Default RE: Composite Sukhoi
ORIGINAL: Aerohead
ORIGINAL: rctom
I do like that tiger scheme, and it's a scale version.
TF
Me too. I usually like the more subdued schemes, but I like that one. It is very creative without using five hundred different colors.
It's 3 or 4 colours, I have to find the bottom pic. I think it is done like the bottom of a tiger on the fuse, but there may be some yellow in the fades...I don't remember.
I imagine it may may be rather labour intensive for Tom to produce though, he would have to comment on that.
Old 04-27-2005 | 09:14 PM
  #77
rctom's Avatar
Before I could even consider it I'd have to have detailed photos of top, bottom and sides.
TF
Old 04-28-2005 | 07:51 PM
  #78
P-51B's Avatar
I haven't found any other good photos. I know Bob Banka has a photo pak of it. It is his #6775/15 on the bottom left side of page 175 in his catalog. I haven't personally ordered it as of this point in time though.
Old 05-23-2005 | 09:12 PM
  #79
My Feedback: (7)
I found some more photos of the tiger scheme for those interested.
ID:	275674   Click image for larger version
ID:	275675   Click image for larger version
Old 05-23-2005 | 09:15 PM
  #80
My Feedback: (7)
Another scheme I think will be good.
Both this and the above scheme over a white base.
ID:	275680   Click image for larger version
ID:	275681   Click image for larger version
ID:	275682   Click image for larger version
Old 05-28-2005 | 07:48 PM
  #81
My Feedback: (13)
Hi Tom, I really like the blue/white/red scheme. I,m very interested in getting one of these planes when they become available. What is the process for getting put on a waiting list for the first batch? thx Dave
Old 06-07-2005 | 06:14 PM
  #82
Too bad its not bigger . Now all we need is a 35% (107") Composite Yak for under $1000
Old 06-07-2005 | 06:47 PM
  #83
The only problem with that size is once you step up to that size the price goes way up having to go up to the 100cc motor and such..
He can probably sell more of the smaller size since they are more affordable..
Later,
Frank
Old 06-07-2005 | 07:34 PM
  #84
Im just not into the smaller planes right now. I know a lot of people are but bigger does really fly better!!
Old 06-07-2005 | 07:46 PM
  #85
Fur sure on that Bigger Does Fly Better!! You can notice that just from flying a 40 size to a 50cc size..
I'm just trying to figure out how most of the BIG plane owners afford to have them.. Must be alot of money circulating around out there.. When you have as much into a model as you can have to buy a car..
I guess I'm just jealous!!! Actually I know I am!!!
Old 06-19-2005 | 09:21 AM
  #86
ben beyer's Avatar
My Feedback: (23)
Will 5646MG's be enough for this plane?
Old 06-23-2005 | 12:20 AM
  #87
My Feedback: (7)
ben,
I'd go with the 5945's
Better centering, smaller dead band, and more power.
Thats just me though.
Old 06-23-2005 | 08:12 AM
  #88
rctom's Avatar
The Sukhoi has giant control surfaces and needs the best servos you can get. I had 5945s on the prototype and was using the plastic wheels with bolt-on arms (because they cam with the plane and I wanted to test them). Both the plastic wheels stripped thanks to Silversurfer's somewhat heavy-handed flying style.
From this I learned that for ailerons I'd suggest at least 5945s or preferably 8611a with metal arms.
Elevators are not as large as ailerons but still impose a huge load, same story there.
TF
Old 06-23-2005 | 10:37 AM
  #89
airborneSGT's Avatar
My Feedback: (15)
Yeah thats what I think did in my Extra 260 in part. I used the nelson servo arms that bolt on to the plastic wheel. One of my outer servos striped the plastic completely. Looks like I'll switch to metal arms too!
Old 06-23-2005 | 02:00 PM
  #90
ben beyer's Avatar
My Feedback: (23)
So DuBro HD arms aren't going to be good enough?
Old 06-23-2005 | 02:37 PM
  #91
My Feedback: (15)
Why loose a plane you have thousands of dollars in over something you can get for like $10 or less? On rudder, aileron, and elevator I would at least use the Air Wild or some type of aluminum arm. It could not hurt to use them on the ailerons as well. Make sure you use some lock tite or you might loose the arms though.
Old 06-27-2005 | 09:33 AM
  #92
avionics12's Avatar
My Feedback: (12)
Having just completed building the Comp Arf 2.6 Yak, the big question for me is: Will we have to cut out each individual engine louver panel to get airflow through or will this be completed at the manufacturing facility. I really like my Yak but those louvers are a pain.......
Old 06-30-2005 | 12:36 PM
  #93
rctom's Avatar
No the louvers are not cut out. It would have cost more and that's a tradeoff decision I had to make.
FYI on the prototype I just cut a couple hoes in the bottom about 1.5x3". You can't see them and they seem to cool real well.
This also seems to force airflow over the cylinder fins, with the louvers cut out there is no way to be sure the fins are getting any air.
TF
Old 07-23-2005 | 02:37 AM
  #94
Sandbag Special's Avatar
Do you think it is ok to use a ZDZ-80 in this plane? I have one sitting around my shop.
Matt
Old 07-23-2005 | 09:51 AM
  #95
rctom's Avatar
Yes, I think that would be OK and performance will be awesome.
TF
Old 07-25-2005 | 07:46 PM
  #96
P-51B's Avatar
Hey Tom,
Did you ever make a determination on the Tiger scheme?
Old 07-25-2005 | 08:47 PM
  #97
rctom's Avatar
Yes, we're getting 5 of them in the 1st shipment due in about 4 weeks.
TF
Old 07-25-2005 | 10:09 PM
  #98
mstroh3961's Avatar
P-51b...looks like its time to spend some money! Tom called your bluff!
ORIGINAL: P-51B
Hey Tom,
Old 07-26-2005 | 09:59 AM
  #99
My Feedback: (7)
Tom,
I've sent a E-mail to you ordering one of the five Tiger Scheme Sukhoi Su-31.
Very nice job.
Got any pics of the bottom, sides, inside, cowling off, ect?
Did you get two hatch covers made to fit the fuse so that the plane can be made into a single or twin seat ?
This should be a good selling plane if you get enough.
Old 07-26-2005 | 11:03 AM
  #100
rctom's Avatar
The pic I posted is the only one I have, sorry.
We do have two hatch covers but they come with the plane so I won't be able to interchange them at first. Maybe later when I get some parts inventory,
TF
