View Full Version : JR Radio & Spektrum Radios
- Danny - 10X Memory Battery Change...now throttle channel won't work
- DS 8077 servo
- Spektrum
- two batteries setup
- JR 2048 PCM radio???
- 9303 peak charging
- Why do some people twist there servo-extension? Is this necessary?
- 8103 Flap Setup
- wrong polarity
- 9303 question
- Danny, a question re spread spectrum...
- 9303 and DataSafe...
- xp6102 menue hanges?
- Downloadable JR logo
- 9303 Flexibility with mixed equipment
- JR PCM 9xII compatible with Esky Receiver
- JR DS168 servos
- Hitec crystal and JR RS600 rx ?
- JR XS3 Ques?
- 9303 Synthesized Units, Tx/Rx
- XP 9303
- JR XP6102 problems
- Nitrous switch for electric motor, LOL....
- What crystal????
- 610 rx case
- Odd ball 8611
- Crystals for JR Galaxy channel conversion
- Automatic Dual Rate JR X378
- Is X-378 same as XP783?
- Crow flaps on 9303
- Jr 8611 servo jitter.
- 9303 as Slave
- match box needed?
- JR 347
- JR PROPO R-756 / Spektrum R-1 Pro .-Fail Safe(s) stored where?
- 500T Gyro Problem
- 9303 Synthesized, what's the holdup?
- Converting 8411s to 8411sa
- different gear train for 8101
- JR Chargeswitch and Charger Question
- XP652 Help, Crystal Type
- 6102 New Case
- R720 and R790 Receivers....When???
- JR XP652 / JR R600 Compatiblity
- 8103 servo travel
- Lithium Battery Question
- JR-Z1
- JR XP6102 Display Problem
- JR XP783 Radio Manual
- what is the real diffrence in 10sX & 10X transmitter features.
- Spectrum Throttle Hold
- r945s receiver
- X388S MIXING CHANNELS
- XP-652, Nimh Conversion...help
- XP662 & Flapperons
- DS811 servo torque @ 6V
- Trimming Flaperons
- TX close proximity moves servos
- 9303 programming
- JR Datasafe Ultra
- PCM9XV2- Questions
- 8103 Trim and flight problems
- JR 10 sx for flight simulator
- JR 8103 and Ultra Stick Lite
- synthesixed reciever
- Programing the JR9303 transmitter
- 9X II - setting up dual servo for elevator problem
- Batter/servo problem
- Dual RX setup question
- JR 9303 Transmitter
- jrxp9303 lcd screen
- 10X transmitter
- JR Rx antenna
- 9303 BUDDY BOX
- jr 6102 mixing and dual surface assigning question
- JR388s for service
- 8611 upgrade
- 8103 Programming Help
- 8611 servos upgrade to 8611a
- XP8103 TX module PCM / FM questions
- PCM9X to PCM9XII model transfer
- Receiver Compatibility
- jr 6102
- 6102 radio receiver
- 8611a Shaft Slop
- 8103 and lithium battery
- 9303 Delta wing config problems
- 2.4 GHZ TX module for 10X
- 388 Transmiter battery
- JR 10sx lithium battery?
- JR TX compatibility
- Spektrum DX3
- R2100 receiver not working HELP HELP
- HOw to transfer data from my models JR8103 tranny to my new JR 9303 tranny,,,
- JR Programmable Digital Servos?
- JR Galaxy Comoputer 8 PCM Radio-Narrow Band?
- Which receiver do I need
- JR X-378 120* Swash
- 810G strange noise
- Chattering Servos
- servo valtage que.
- JR PCM 10 "z" and module NET-J72P Conflict???
- Synth Module Packaging
- 4131 metal gear set?
- jr 7202
- Throttle Ratchet on SX10
- 10X broken switch.
- 10X timer question.
- Interesting Problem
- 10X Mix Function
- Jr 7202
- Gyro Mounting
- JR500T on T-Rex
- 9303
- No replacement cases for DS 811 servos
- Big Problem with my JR 9X II Radio
- JR 8101 vs 4721 servos
- JR Synthesized RX
- 8103 TX
- Converting modes in JR 9xII
- 8103 w/ flaperons & spoilerons
- 10sx Elevators hunting around center
- XP6102 and Blade CP
- Datasafe
- R770 on 6 meters
- dual servos elevator travel adjustment
- JR PCM rx and Futaba 601 Failsafe issue
- 8103 Support
- Mixing 8611's and 8611a's
- JR RS 310 dropping,loosing signal at 6 feet.
- xp8103
- Hangar 9 Trainer Link Cable for JR/Futaba
- no more 770'S
- JR 7202
- Throttle Curve?
- changing to synth
- Spektrum DX6 Range check
- JR Galaxy 8 Freq / Channel Change
- Mode 1 Mode 2
- What size hammer for installing arms on 8611A's?
- JR sport ST125MG good for large planes
- Info on JR 8425 servos
- 8103 blown fuse
- Three questions X347
- Heavy springs for 9303
- How to program flaperons with 421ex
- ST125MG
- 8700G servo question
- JR Receivers for Giant Scale Planes
- JR Synth Module
- JR radios
- Is PCM 649 better then 549
- JR Metal servo arms on Hitec 5625 Servos
- 8103 Problem
- 9303 Memory Lock?
- 9303 upgrade battery
- 9303 sticking joystick
- Synthizied Module for 9303
- 10X Battery Capacity
- Thinking about some JR 125MG
- Jr 6102
- 9XII doesnt seem to work...
- Servo trouble
- Spektrum Z590M servo
- Dual rate with dual elevator on 9303
- 8103 VS DLG
- Gyro's
- 9303/PCM9XII Flight mode delay (ACRO mode)
- Mode change on X-378
- 9303 Throttle Cut?
- JR PCM data checksum
- JR xs3 and a sail winch servo
- Loose screw JR-9303
- JR vs Futba
- receiver compatabilty
- Flaperons with JR XP642
- rx crystal
- Rudder to aileron mixing on an xp8103
- Ultra Stick & 9303
- 421 EX Soft Ware Issue
- Price question Futaba/JR servos?
- Replacement for X378
- New JR Radio
- Hitech For JR 10SX.
- Change switch assignment
- JR 649 rx max current draw?
- does JR still sell any ZPCM RX ??
- JR Digital vs JR Analog servo use
- r610ul reciever
- R270 FM Scan Select/JR 652 JRPR720
- Aileron channel max. setup
- Curious entry in model setup menu
- JR FX421 Problems
- 9303 Elevons
- turbine crow setting for 9303
- JR 790 synthesized compatibiltiy?
- can you use futaba sevos w/ jr rec and trans
- Aileron deflection change with Flaperons
- XP8103
- 10 servo's off 770PCM RX
- vortex speed brakes w/10x
- JR 8611A servo
- Replacement fuse for TX
- Separate channels for flaps and ailerons
- 6102 v-tail and flaperon settings
- ST125MG problem
- 10x differences between heli and airplane
- replacement switch
- Z-1
- JR 8611 strong servo noise
- XP9303 Question
- Channel 35 on JR 10sx
- Disable gear switch?
- Want to Change to 72.XX0 MHz.
- 10x flying modes
- Differential Ailerons & Flaps
- DZ9000T
- transmitters and receivers
- Oops
- 10X Aileron Programming
- Oops
- JR Service
- Jittery ST47BB
- servo warranty
- Matchbox or Slave?
- Curious markings on JR RX and TX Crystals
- DX6 trainer port output signal
- Danny,
- DS537 VS. 537 VS. ST47BB SPORT
- 6 servo sailplane, 9303tx flap problem
- Crystal change
- JR 8611 jittery
- How to order a CH 58 Crystal with the center dot?
- JR XP6102: Using 2 servos for ailerons
- Dead X-388s
- JR G500T gyro - Set up problem
- Jr Recievers
- jr 9x11
- JR 8103 as Master Trouble
- Elevator/ail. servos without y harness-6102
- XP9303 SW Warning
- 361 (368 in US) servo problem with futaba RX
- Jr 770 with Hitec servos
- 9303 DataSafe 3 error
- st 125mg problems! jitters
- 6102 connector for Tx battery
- Circus Hobbies PCM G Series NER-627X Reciever
- JR receivers??
- JR Apex 8 Computer Radio
