Capiche 140 EX and IC version
#1128
ORIGINAL: Kane C140
hey can anyone here send me a 3D routine in words please i want to practice for the Freestyle comp this year.
That should do
Don't think you are going to get too much help on this one, plenty of other competitors on this forum [8D]
#1132
depends i have 10s on mine but im using the 340mh cells i have some new kokham 2100 cells from ANSA that will handle 1s (yep 1s!!) but 2s would give you 4200 AH and cost you about £500.00. there are cheaper examples (flightpower do some cheaper alternatives but i have not fully tested them yet)
#1133
flight power 5s2p wired to 10s2p is only about 400 quid i think.
Kane, think a bit, im 15 and ive sorted one out, dont have a plane to fly it, or a B test to fly at the comp yet but i did it
#1134
I've got the 10s2p from flightpower. Got the new 5000mah packs they claim they can handle up to 70amps comfortably and peak at 100amp, hopefully I will never get there.
"The boy, whats the all up weight of your C140 with the 1p Kokham packs" must be really light.
#1138
i have never crashed my 140!!
i was testing an electric motor in the garage and the collet prop adapter let go and an 18" wooden prop went bouncing around my workshop at 6000 RPM OUCH
loads a damage to other stuff just the 140 was the only thing strong enough to stop the prop!!
#1146
Kane, i dont fly that often now, I was looking forward to doing some indoor flying but Ali convinced me to have a Funtana 90 and another Composite ARF Extra so i might be doing a bit more!, as for fields i fly at Southend
#1149
ORIGINAL: Kane C140
I want to get a composite extra 2.3 with a DA 50 and JR 8411 sevos
