Capiche 140 EX and IC version
#2376
8511's run really well through a regulator. A big difference from 4.8v. However must be through a regulator. Otherwise warrenty is invalid i have been told by LMS. Also had glitching on my 8411's when run on 6v
#2377
Aye you gotta regulate it down otherwise you'll knacker your pots. Mine are reg down to 5V but anything from 5.5V or less should be ok. Your really just limiting the peak voltage of a 5cell pack. Fresh off charge your probably getting over 7V!
Angus
Angus
#2379
No wonder my 3004's seem like 9202's of a fresh pack! Too bad they don't stay like that, it would save me alot of money [X(]
#2382
To those of you on JR 8511, why didnt you just go for the 8611? Was there a reason? 8611 virtually exactly the same size, speed etc just 3kg/cm more torque. Im thinking of getting five of them for Capiche + when i finally do get my long awaited TOC model ive at least got some servos that will suit it.
Angus
Angus
#2384
I think you might be right actually Luke. 8611 quoted as approx 18kg/cm at 6V and 15kg/cm at 4.8V. 15kg is the same as 8511 + there another guy claiming the 8511 is UK version of 8611 here (post 11):
http://www.rcuniverse.com/forum/m_11...tm.htm#1162634
So confusing.
Angus
So confusing.
Angus
#2391
Why change the name in the first place! I see this alot in one country its called something in another something else geeziz...
#2392
heres a few shots off mine, had a good days flying today and well pleased with the weston muffler setup[8D] got to change prop though,gonnaa try the 16x10, apc should be better in the tourqe roll.
#2394
Isn't having two different codes a but stupid, huh
Flair=Giant Scale Planes
Sanwa= Airtronics
etc...
As our Capiche less friends across the pond would say 'go figure'
#2396
Nice one mike gonna have to meet up with you sometime and get of both of them together on the deck
Are you changing to the 16X10 to get more thrust?
#2397
cheers luke,yeah deffinitly have to meet up soon, goona change the prop as you said to try and get more thrust,i did run the 17x8 n on the proto 140 and that was ok so might try that first before 16x10. what are you running now on yours luke?
#2398
The last prop i had on it was the J'en 18x6 carbon. If you like lots of braking and going through the aeros at a slow pace its a sweet prop. I dont need it for a while because im going 160Dz so you can borrow it if you like. Static thrust didnt seem to be much different with that prop to me though. I should be getting some Wildcat 30% in the post which youre welcome to try to see if it makes a difference.
#2399
yeah i got some on order aswell
me engine should be run in now ok so i think the fuel chang aswell is gonna be a big difference, will try that prop though luke
