U Can Do 3D
#754
I went to http://moosecarbonfiber.tripod.com and didn't see anything that matches the UCD dimensions. Tell me a little bit more about which tail gear you are going to use. Im at that step in the building process and don't care for their recommendations.
#755
WV
Originally posted by FalconWings10
A #29 drill bit is .136" in size.
Needless to say I don't have that bit. I'll have to run to lowes or sears and buy that one. lol And like the other guy mentioned, I'm gonna just buy longer screws also and use nuts with thread lock. Thanks.
#756
OK
Just for the data banks, mine weighs 7 and 5 ounces. That's with the Saito 100 w/Perry pump/remote glow connector, Sullivan tail gear and 4-40 rods. All the rest built per. I glued the tail on too. I've got 605's all around and 81 on throttle. I just haven't made time to fly it yet... I did get to run the engine in the yard!
That's 7 lbs 7 ounces .
#759
AZ
#760
WV
What are you guys using to cut the holes out in your cowl? Some of the pictures I've seen on here show really clean cut holes. I'd like mine to look nice too. I've got a dremel tool and a drill. I'm sure I'll need to use the dremel to cut the air intake in the front, but was wondering if a regular drill would work on the round access holes. Sometimes certain bits can tear fiberglass to shreds. I don't want that to happen with mine.
#761
#29 is a wire gauge size. True Value hardware stores around here sell them. Over the years I've accumulated a fair number of them on an individual need basis.
mt
mt
#762
I used a dremel tool with the angled stone bit (looks sorta like an arrowhead with a rounded point). I drilled a hole large enough to accommodate the head of the bit, and just pushed it in slowly, until I got the desired size. I did the same thing with the cooling vents on the nose. Just take your time and let the wheel do the work. Get it close, then take some 400 wet/dry sandpaper and smooth out any edges. That also takes the stray fiberglass shards away cleanly.
I used a new drill bit for the holes for the screws.
#764
FL
Bullet Bits drill nice round holes in fiberglass.
I have these from Black & Decker.
Also, Blair makes hole saws that cut perfect holes. Expensive? Why worry, after all, it is only money and you can always make more!
Allie33
Allie33
#765
WV
For any of you that are using an EZ fueler glow valve are you putting an inline filter between the valve and the carb or between the tank and the filler?
Oh BTW, I used the cone shaped stone with my dremel tool to cut perfectly round smooth holes in the cowling. It worked great.
#766
WV
As per my usual, I've made my agonizing descision on how to route the antenae from the receiver. I internally ran the antenae the full length of the fuselage and on the sloped portion of the fuse near the tail wheel mount I drilled a hole and ran a 2 inch piece of fuel tubing down the hole. I snaked the antenae through the fuel tubing. There was a few inches of antenae that extends out to about the rudder hinge.
I still need to trim the tube and secure it, but I think it will work OK. I'll do a really good range check to make sure. I don't have anything that should interfere. I'm running the 2 elev servos on 2 seperate channels on my 9C.
#767
My Feedback: (50)
CA
coomarlin,
A filter between filler and tank would just catch dirt when you fuel up, then dump it in the engine when running it. A filter should be the last thing the fuel encounters before reaching the engine, so between filler and engine is the correct place. Also run a filter on your filler hose from your fuel storage container.
I ran my antenna through a hole on top of fuse, right behind canopy, down the top of fuse, to the root of the vertical stab.
DKjens
DKjens
#768
I put a video up of the U-Can-Do. Check it out at:
http://www.sanantoniorc.com/page/video1.htm
They are in Divx (www.divx.com) format.
#769
Looking at the picture, I noticed that you draped the antenna inside the spring of the tail wheel. Baaaddd idea!
Trust me. The tip of the antenna should be no where near any metal surfaces, especially that nice looking Sullivan tail wheel that has metal-to-metal connections (spring and brass eyelet). These often can cause glitches, especially when the tip of the antenna is in close proximity. I opt to route all my rcvr antenna outside the fusealage. See http://www.rcuniverse.com/showthread...324#post550408 Better safe than sorry..
#770
WV
Originally posted by TOMAPOWA
coomarlin,
coomarlin,
#771
WV
One last thing to do to my UCD to complete it. I need to install the canopy. I've seen a lot of pictures of some of your finished UCD's and I like the looks of the black canopy. I want to paint it. Any recommendations on a particular type of black paint? Also, do I need to rough up the inside of the canopy with steel wool or anything?
#773
Real easy. Buy yourself a $1.99 can of Black Enamel paint from Walmart (or like). I have a Benny's near me that often sells them for 99 cents. I used glossy. The trick is to completely cover the outside of the canopy so that paint spray won't mess up the outside of the canopy. Using wide masking tape, I tape a "bag" (any type that fits) over the canopy, overlapping the edges with the tape. After all is covered, I simply trim the tape around the canopy edge with a razor. Then simply place upside down and spray as evenly as you can. I often use two to three light coats. I also often attach my canopies with clear silicone along with the supplied screws. Stops rattling and such. With the UCD, mine rattled like crazy (as thin and flimsy as it is).
#774
WV
Coolmarlin,
Coolmarlin,
I figured I'd cover the outside like you said. Trimming the masking tape with a razor knife is a good idea. I'll try it. Thanks.
#775
My Feedback: (9)
Coo,
I just painted mine the other day. Pactra makes a paint for the inside of the lexan rc car bodies. You can't always be sure that spray paint from a hardware store won't attack the canopy. Parma also makes a water based paint for car bodies called Fascolors or something like that.
I shot mine with silver and will trim the glue line with black trim tape. I don't like to glue to paint so I mask off a 1/4" along the inside bottom of the canopy.
My canopy glue is drying now. Now I have to wait on a half way decent day to fly!
basmntdweller
basmntdweller
